Need Tuning? How to tune ??? And run 30%!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> Need Tuning? How to tune ??? And run 30%!
Page: [1]
Login
Need Tuning? How to tune ??? And run 30%! - 8/4/2012 12:38 PM
racin rebel
Score: 100
Last Login: 1/14/2013
Status: offline
First Seal your engine with High-temp RTV, Seal the carb. neck, and the back plate, this will help hold your tune and seal up any air leaks, all engines will have some leaks.plus it will keep your temps low (170-190 ish) next set your needles to stock settings first for the break in (Rich HSN), break in with 20% fuel, 5-6 tanks., after break in, change the glow plug, use a hot plug, (Thunderbolt #3 works best) and get Byron fuel GEN2. Get Byron Race3000, or Pro-driver3000 It's 30%, but don't lean out too much! Always watch for that thin trail of Blue smoke!! at full speed, if there's NO smoke than your too lean, richen the HSN 1/8th turn out. after tuning the HSN(high speed needle), start to tune the LSN, you want your throttle to be quick and instant!, but  NO Bogging up to get to full throttle., it should rev up quick.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: Need Tuning? How to tune ??? And run 30%! - 9/6/2012 10:01 PM
rx7devil210
Score: 105
Last Login: 5/14/2013
Status: offline
Can u post some pics on what to seal? I havent sealed mine but ive ran it pretty hard and did the break in. Did i mess up the engine?
Hide Signatures
(in reply to racin rebel)
       Post #: 2
RE: Need Tuning? How to tune ??? And run 30%! - 9/7/2012 1:25 AM
Anthoop
Score: 121
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: rx7devil210
Do you have a problem with the engine? Is it running inconsistantly?
_____________________________
When I die, I want to go in my sleep like my grandfather,not screaming
like the passengers in his car at the time.
Hide Signatures
(in reply to rx7devil210)
       Post #: 3
RE: Need Tuning? How to tune ??? And run 30%! - 9/7/2012 9:28 PM
rx7devil210
Score: 105
Status: offline
I think i have an air leak because it idles perfect then jumps up and starts idling high and rolls forward. I figured it might need to be sealed. Hopefully i didnt ruin the engine.
Hide Signatures
(in reply to Anthoop)
       Post #: 4
RE: Need Tuning? How to tune ??? And run 30%! - 9/7/2012 10:04 PM
Anthoop
Score: 121
Status: offline
In general an air leak will cause the idle to be very erractic and the engine will be very difficult to tune.
I will hazard a guess that this is a tuning issue.
If the crankcase loads up with fuel it will cause a low idle speed...once this fuel is burnt the idle speed will increase.
Hide Signatures
       Post #: 5
RE: Need Tuning? How to tune ??? And run 30%! - 9/8/2012 2:50 AM
rx7devil210
Score: 105
Status: offline
so what should i do?
Hide Signatures
       Post #: 6
RE: Need Tuning? How to tune ??? And run 30%! - 9/8/2012 10:19 PM
Anthoop
Score: 121
Status: offline
You need to establish if you have a tuning issue or an air leak?
Hide Signatures
       Post #: 7
RE: Need Tuning? How to tune ??? And run 30%! - 9/9/2012 3:10 AM
rx7devil210
Score: 105
Status: offline
I ran it today an i think its just a tunning issue. But dont you think i should seal the engine up anyway?
Hide Signatures
       Post #: 8
RE: Need Tuning? How to tune ??? And run 30%! - 9/9/2012 11:09 AM
Anthoop
Score: 121
Status: offline
...if it ain't broke don't fix it.
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
