This is odd...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> This is odd...
Page: [1]
Login
This is odd... - 8/5/2012 7:07 AM
lexus 300
Score: 100
Last Login: 9/5/2012
Status: offline
Hi everyone,
New member here with a problem I simply cannot find a solution too.
I just recently bought a 1/8 RedCat Rockslide.
I charged the battery for the second time only today, I took it out and the dam steering was reversed !!
The steering is set  to 'normal', however it is steering as if it were reversed. Very odd and I would like
a solution or any theorys please.
Yesterday it was fine. It was set to 'normal' and it was steering the correct way, the same way as the wheel was turned.
But today, it is opposed. Strange.
Thanks for any help it's bugging me
Hide Signatures
       Post #: 1
RE: This is odd... - 8/5/2012 9:20 AM
86MOmo
Score: 100
Last Login: 5/5/2013
Status: offline
Silly question but was the body turned around on the frame?
I can't imagine it just changing direction on its own, but I would check the radio settings and verify that everything is as it should be.
If you look at he LCD readout on the side of the controller, the image of the crawler should indicate which is front and back.  The front should always be toward the top of the radio.  Thus, when you select front steer, the front servo should turn.  I've found it does take some tweaking to get the servos to line up accordingly.
Good luck,
MOmo
Hide Signatures
(in reply to lexus 300)
       Post #: 2
RE: This is odd... - 8/5/2012 10:08 AM
lexus 300
Score: 100
Status: offline
Yes, as mentioned, it was fine yesterday. It has simply reversed itself somehow.
It is steering left, as I turn the control right.
It is steering right, as I turn the control left.
And it is set to normal - not reverse.
It may be hard to believe, but this is how it is.
Any other ideas??
Hide Signatures
(in reply to 86MOmo)
       Post #: 3
RE: This is odd... - 8/5/2012 9:32 PM
nitrosportsandrunner
Score: 296
Last Login: 5/22/2013
Status: offline
the 4 wheel steering button on the remote, do you use that?
is the body on right?
Try reversing the servo function on the radio.
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
       Post #: 4
RE: This is odd... - 8/8/2012 9:54 AM
lexus 300
Score: 100
Status: offline
Yeah everything is normal. Except the wheels turn in REVERSE and the steering switch is on NORMAL.
Very odd. Runs fine with steering reversed, but it shouldn't be like that
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 5
RE: This is odd... - 8/9/2012 2:10 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
you may have hit the servo reverse switch by mistake, some rc's run correct in normal and some in reverse, just depends on the servo wiring but if its working fine in reverse setting then dont worry about it.
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
       Post #: 6
RE: This is odd... - 8/9/2012 4:56 AM
lexus 300
Score: 100
Status: offline
Thanks, yeah running fine in reverse. Guess it'll just have to be.
Just odd that normal was normal the first time I used it.
But if running it reversed works, so be it.
Hide Signatures
(in reply to ehroof)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
