Tx Latency Question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Tx Latency Question
Page: [1]
Login
Tx Latency Question - 8/7/2012 3:33 AM
SeamusG
Score: 199
Last Login: 4/10/2013
Status: offline
I've been told (and I read it on the internet so it must be so) that latency is that time it takes for the Tx to react to a change in one of its controls and respond with some action like send a message to the Rx to move the throttle servo arm to position x. So, a Tx with latency of 11 ms responds twice as fast as a Tx with a latency of 22 ms.
Let's say that I'm taking off and I smoothly move the throttle stick from idle to full throttle in 3 seconds. The Tx would take 11 ms to react to the inital movement of the throttle and send a message to the Rx. My throttle stick is still moving. How long will it take the Tx to send the 2nd, 3rd, 4th, etc. messages to the Rx to smoothly progress the throttle from initial state of "idle" to a final state of WOT?
Finally, what is this frequency of sending continuous messages called?
Hope this makes sense - it did to me when I had my aluminum foil hat on ...
Hide Signatures
       Post #: 1
RE: Tx Latency Question - 8/7/2012 4:03 AM
Charlie P.
Score: 192
Last Login: 5/23/2013
Status: offline
If you have 11ms at the initial movement it's not cummulative.  The topping out of the three second throttle movement will be enacted by the receiver at 3.011 seconds.
What is the frequency of sending continuous messages?  Continuous-time dynamic proportional signals, maybe?
_____________________________
Charlie P. (NY) "Gravity is weak but persistant".
AMA 747089/IMAA 30723
Hide Signatures
(in reply to SeamusG)
       Post #: 2
RE: Tx Latency Question - 8/7/2012 4:26 AM
SeamusG
Score: 199
Status: offline
How many steps between the initial servo pulse message and the final servo pulse message? Will there be a pulse message sent every 11 ms to reflect the new throttle positions?
Hide Signatures
(in reply to Charlie P.)
       Post #: 3
RE: Tx Latency Question - 8/7/2012 4:38 AM
dirtybird
Score: 173
Status: offline
In the 72mhz equipment the frame rate is about 50cps. A new pulse is transmitted in each frame. On the 2.4 ghz equipment the frame rate is the designers choice.
I think you are wondering about things that matter little if you are not a circuit designer.
Go fly your airplane and be happy.
Hide Signatures
       Post #: 4
RE: Tx Latency Question - 8/7/2012 2:35 PM
SeamusG
Score: 199
Status: offline
DB - the more you know the better it gets.
Hide Signatures
(in reply to dirtybird)
       Post #: 5
RE: Tx Latency Question - 8/7/2012 2:58 PM
Four Stroker
Score: 104
Last Login: 3/28/2013
Status: offline
Oddly enough, the ancient AM/FM digital proportional had an average latency of 8~12 ms. This is why old guys kept it long into the PCM era. Early PCM had latencies of 100 ms or more.
Hide Signatures
       Post #: 6
BarracudaHockey
Score: 280
Status: offline
Very few gifted pilots can tell the difference in response between the two. Even then its on high end helis with 8v systems and .10 speed servos.
If you want to learn more, here you go...
http://rc.runryder.com/helicopter/t172571p1/
Don't read it before operating heavy machinery
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 7
RE: Tx Latency Question - 8/7/2012 3:02 PM
Bax
Score: 169
Status: offline
When "latency" is measured, it's measured from initial movement of the stick until the servo actually moves. Latency for most systems is 11-30 mS. More channels in your transmitter, plus more processing, extend the latency period. Newer systems are faster than older ones because their newer hardware is just faster.
If you are a world-class flyer, especially with eCCPM helis, then you may be able to notice differing latencies. However, it's mostly a "I guess it's something to know" for most people, and maybe a source of bragging rights, but it really isn't something noticed by the vast, vast majority of RC users. Manufacturers try to make their top-level systems so that top-level modelers are happy with the results. They're not so concerned with the lower-level, entry systems, other than to make sure reliability and controllability are not compromised.
< Message edited by Bax -- 8/7/2012 8:50 PM >
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
       Post #: 8
RE: Tx Latency Question - 8/7/2012 3:07 PM
Four Stroker
Score: 104
Status: offline
Latency was blamed for (and partically contributed to) the poor CCPM performance of many radios - Futaba 9C, 9Z. Modern radios have channel grouping and such to get around latency issues that actually effect control. The rest is a mind game. You get used to what you fly.
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 9
RE: Tx Latency Question - 8/7/2012 3:36 PM
dirtybird
Score: 173
Status: offline
quote:
ORIGINAL: SeamusG
If you really want to know go get yourself an education in electronics. This is a poor place to get that kind of information.
Hide Signatures
       Post #: 10
RE: Tx Latency Question - 8/7/2012 3:41 PM
BarracudaHockey
Score: 280
Status: offline
quote:
ORIGINAL: dirtybird
quote:
ORIGINAL: SeamusG
Depends on who is answering the question
www.JaxRC.com
Hide Signatures
       Post #: 11
RE: Tx Latency Question - 8/7/2012 4:42 PM
SeamusG
Score: 199
Status: offline
Does this forum allow me to block posters?
Geez dude - why not just skip the thread and keep your "fingers" quiet?
Hide Signatures
       Post #: 12
RE: Tx Latency Question - 8/7/2012 7:02 PM
dirtybird
Score: 173
Status: offline
Yes it does. I just blocked you
Hide Signatures
       Post #: 13
RE: Tx Latency Question - 8/7/2012 7:05 PM
dirtybird
Score: 173
Status: offline
Yes it does. And that is the problem.
Hide Signatures
       Post #: 14
RE: Tx Latency Question - 8/7/2012 7:23 PM
SeamusG
Score: 199
Status: offline
BH - please close this thread. Thx
Hide Signatures
       Post #: 15
RE: Tx Latency Question - 8/7/2012 11:14 PM
eddieC
Score: 249
Last Login: 5/21/2013
Status: offline
I've talked to many world-class pattern pilots, and 3-D and heli fliers whose names you'd recognize. Only the heli guys say it's perceptible, and then only during rapid maneuvers. We've tried comparisons at the field, couldn't tell.  But then again, we're all hacks !
I might not be very good, but I am fun to watch!
Hide Signatures
       Post #: 16
RE: Tx Latency Question - 8/8/2012 1:24 AM
SeamusG
Score: 199
Status: offline
That is really insightful and technically accurate ...
Hide Signatures
(in reply to eddieC)
       Post #: 17
RE: Tx Latency Question - 8/8/2012 3:27 AM
oliveDrab
Score: 105
Status: offline
"No, no, no........you misunderstand. We make nothing but model airplanes"
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
