ESC or Motor problem?(video)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> E-Flight Power Sources >> ESC or Motor problem?(video) Page: [1]
Login
ESC or Motor problem?(video) - 8/7/2012 4:24 PM
DCSouthwind
Score: 100
Last Login: 11/20/2012
Status: offline
My E-Flite Apprentice 15e has a problem I'm not sure if it is the ESC or motor. When you give it throttle the motor flips back and forth instead of turning in one direction. Here is a video. Any ideas?
http://www.youtube.com/watch?v=-xlOe2VINuY
Hide Signatures
       Post #: 1
RE: ESC or Motor problem?(video) - 8/7/2012 7:36 PM
exeter_acres
Score: 116
Last Login: 9/24/2012
Status: offline
could be either....
that is a timing issue...
try to program the ESC to a different timing and see what happens.
_____________________________
Extreme Flight RC tech support
IMAC SE Regional Director|IMAC Sequence Committee|IMAC Judging Instructor|Team Futaba
Hide Signatures
(in reply to DCSouthwind)
       Post #: 2
RE: ESC or Motor problem?(video) - 8/7/2012 7:55 PM
DCSouthwind
Score: 100
Status: offline
Sorry if I show my ignorance here, but, how do you change/program the ESC timing? I'm new to the RC scene. I used to fly some 20 years ago but things have changed a lot since then.
Hide Signatures
(in reply to exeter_acres)
       Post #: 3
RE: ESC or Motor problem?(video) - 8/8/2012 1:15 PM  1 votes
Glacier Girl
Score: 122
Last Login: 5/18/2013
Status: offline
What you are experiencing is called "cogging". You have one phase of the motor out of sync with the other two. Those three leads going to the motor from the esc are what power so to say your phases of the motor. Kinda like spark plugs in an engine, each has to fire in order, for the motor to spin.
I doubt that it's a timing problem, though it is easy enough to check. You should have paperwork on the esc that tells you how to program it. If not let us know what esc you have, and we can find the info for you.
But meanwhile back to your problem. You have a bad/poor connection on one of the three leads going to the motor. First though a piece of advice.
DO NOT KEEP TRYING TO RUN IT THIS WAY! Yep I'm yelling. Cogging is a dead short occurring. Keep trying to get it to run like this and you will eventually fry the motor and or esc.
Go though every connection, esc and motor looking for a bad solder joint, or broken lead, that's what's causing your problem. If need be, resolder every connection. Each solder point should look clean and shiny. Dull or dirty looking and you have a cold solder joint, as in bad connection.
If any of this seems too much for you, stop, do not proceed. Get on the phone to Horizon, if this is their ready to fly or almost ready to fly version, hands down the best customer service out there. Tell em what is happening, and more then likely they'll be able to get you fixed up.
Best of luck.
Missing Man Formation, Looking heavenward you can''t help but shed a tear,mournful, lonesome, a hole that screams out at you
Hide Signatures
       Post #: 4
RE: ESC or Motor problem?(video) - 8/8/2012 6:09 PM
DCSouthwind
Score: 100
Status: offline
Thanks!
I checked the wiring and found the blue wire unplugged between the motor and ESC. Plugged it back in and now it works.
Hide Signatures
(in reply to Glacier Girl)
       Post #: 5
RE: ESC or Motor problem?(video) - 8/8/2012 11:33 PM
Glacier Girl
Score: 122
Status: offline
quote:
ORIGINAL: DCSouthwind
Thanks!
Yep, that will do it.
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
