Bullet Connector Size    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> Bullet Connector Size
Page: [1]
Login
Bullet Connector Size - 8/9/2012 3:00 AM
tewalker01
Score: 100
Last Login: 5/25/2013
Status: offline
For those of you that use bullet connectors between your ESC and motor: Is there some specific size that we should be using or does it vary depending on the ESC / motor combination? I have seen everything from 3.5mm, 4.0mm, 4.5mm, 5.0mm and even 6.0mm. I'm curious if the size and type of connector affects the ESC/motor efficiency.
Hide Signatures
       Post #: 1
RE: Bullet Connector Size - 8/9/2012 3:13 AM
Silent-AV8R
Score: 180
Status: offline
4.0 mm is pretty standard for the connection to the motor. Most motors that have bullets installed use 4mm. I'll use bullets if I expect to have to pull the motor (like to lube and inrunner) otherwise I just solder the wires direct.
_____________________________
Be aware and prepared, or pay the price of ignorance.
Hide Signatures
(in reply to tewalker01)
       Post #: 2
RE: Bullet Connector Size - 8/9/2012 5:14 AM
shannah
Score: 105
Status: offline
4mm is what I use. Pretty standard.
Team BJCraft
Hide Signatures
(in reply to Silent-AV8R)
       Post #: 3
RE: Bullet Connector Size - 8/9/2012 5:28 AM
nonstoprc
Score: 110
Status: offline
4mm. Make sure the wires are soldered properly and the connection is tight.
I have good luck with the 4mm sold by HobbyKing.com.
Where facts are few, experts are many.
Perfection is God''''s business.
Hide Signatures
(in reply to shannah)
       Post #: 4
RE: Bullet Connector Size - 8/9/2012 8:10 AM
Rendegade
Score: 105
Last Login: 5/24/2013
Status: offline
I've really grown to love the Eflite EC5 connectors. Big, solid and nigh on impossible to stuff up, which is important for a spastic like me
It''''s easy to fly, just throw yourself at the ground and miss!
Hide Signatures
(in reply to nonstoprc)
       Post #: 5
RE: Bullet Connector Size - 8/10/2012 7:49 AM
MalteS
Score: 100
Last Login: 5/12/2013
Status: offline
4mm Plugs work.
I went away from single plugs however as I shortened my Batteries a couple of times. I'd recommend to use either these red housings for 4mm plugs or a decent alternative. Decent means protection against shorts and reverse polarity.
I selected the green MPX plugs because of the availability over here (the main disadvantage is that they're not GOLDEN) and I use those for all of my planes from Foamie to the 2m F3A pattern ship.
My first alternative would have been XT60.
My 2 ct.
Ah: this site is in German (Google Translate is your friend) but shows recommended max currents (based on measurements) for the different systems we're using.
http://www.elektromodellflug.de/oldpage/hochstromst/hochstromstecker.htm
Hide Signatures
(in reply to Rendegade)
       Post #: 6
RE: Bullet Connector Size - 8/10/2012 7:58 AM
Silent-AV8R
Score: 180
Status: offline
I think the OP is talking about the connection between the ESC and the motor on the three wires that run between the two and not the connectors on the batteries themselves.
Hide Signatures
(in reply to MalteS)
       Post #: 7
RE: Bullet Connector Size - 8/16/2012 9:14 PM
Walfam
Score: 100
Last Login: 5/18/2013
Status: offline
i noticed tewalker stated he liked the one that were gold plated. That is fine on the male to female plug end, but for soldering where you solder the leads, it is not good. Why; if you do not pre-tin that gold tab, then the gold gets in the the solder jitand actually makes the solder joint brittle, which can make it fail due to vibration, shock, or it will become a high resistance point in the joint and over time cause that joint to go bad. So, always pre-tin any gold connector you are planning to solder too.
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
