Electric Fuel pump fix    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Electric Fuel pump fix
Page: [1]
Login
Electric Fuel pump fix - 8/10/2012 2:36 PM
acdii
Score: 155
Last Login: 5/19/2013
Status: offline
 The other day I noticed that the pump wouldnt draw below a half tank and made some awful noise, so I picked up a new one. The new one wouldnt even prime, which ticked me off, so I took the old one apart and found out how easy it is to fix.  The pump itself is just like an oil pump on a car engine, two gears meshed together.  The problem with mine was the gear attached to the shaft was loose.  What I discovered is both gears are the same, so I switched them around, put it all back together, adn lo and behold, its working again.   Something to think about when yours stops working, took me all of 5 minutes to fix.
Still ticked that the new pump wont prime unless I raise the tank above it, did that and shot fuel all over the place when the return hose popped off the tank once it pressurized.
_____________________________
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
       Post #: 1
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> RC Fuels >> Electric Fuel pump fix
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
