RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84
Page: <<   < prev  1 2 [3] 4 5 6   next >   >>
Login
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/16/2013 7:26 PM
CH Ignitions
Score: 420
Last Login: 5/6/2013
Status: offline
Steve I can do the a overhaul on it, it uses I will say 25% less fuel , does not spits the fuel on exhaust.
Any way for more details just email/PM me , is a FG84 Thread and I do not want to spoil it.
Adrian
_____________________________
www.ch-ignitions.com
Hide Signatures
(in reply to SteveD-RCU)
       Post #: 51
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/16/2013 8:13 PM
SrTelemaster150
Score: 229
Last Login: 5/25/2013
Status: offline
Buy a new FA450R3 for $1400, add $200 for a C&H CDI & run it on methanol.
It will make as much or mre power than this low compression gas version.
The displacement comes out to 180 cylinders on the 150 stroke 27.9cc X 3 = 83.7cc. Unless theu made new, longer rods (I doubt that) it will be about 7.8:1 compression ratio.
I doubt that the 10% increase in displacement will make up for 8N Ford tractor compression ratio burning gasoline.
As far as power, anything the FG84R3 will do, an FA450 on CDI will do better.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 52
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/16/2013 8:36 PM
rcnut101
Score: 100
Last Login: 5/24/2013
Status: offline
I dont think that FG-84 R3 is that slouchy, On the video they are turning a 23x12. Which is not bad, But I would rather have gas as it is easier to come by.
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 53
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/17/2013 5:09 AM
n8622t
Score: 101
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: SrTelemaster150
You can have my whole share of glo fuel....it's all yers
< Message edited by n8622t -- 1/17/2013 9:34 AM >
"Go low if you wanna make a show"
P-40 Brotherhood #49
Hide Signatures
       Post #: 54
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/17/2013 5:14 AM
n8622t
Score: 101
Status: offline
quote:
ORIGINAL: rcnut101
THe new FG-84 should be out around April time with a price around $1650 USD, Which includes ingnition and muffler.
Don't mean to be skeptic but how do you know?
Hide Signatures
(in reply to rcnut101)
       Post #: 55
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/17/2013 8:04 AM
rcnut101
Score: 100
Status: offline
quote:
ORIGINAL: n8622t
quote:
ORIGINAL: rcnut101
I had been given an email addresse to enquire about the evolution radial's but I was more Intrested in this FG-84 since I will be needing 2 of them. We shall see. I'm hoping for the best.
Hide Signatures
(in reply to n8622t)
       Post #: 56
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/17/2013 9:41 AM
n8622t
Score: 101
Status: offline
Ok rcnut101....since you want to keep it all a secret and want it to sound like you are special I will stick with my own information as well
Thanks anyway
Hide Signatures
       Post #: 57
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/17/2013 4:06 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: n8622t
I'll bet a methanol fired Saito engine will outlast a gas vesion many time over.
A 55 gallon drum of methanol is $100 has an almost infinate shelf lifen& doesn't smell. Cheaper, easier to store & less volitile. So what if I burn a little more of it to more power & longer engine life.
The reliability of "gas" engines has nothing to do W/the fuel used. It has everyting to do W/spark ignition.
Hide Signatures
       Post #: 58
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/17/2013 4:08 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: rcnut101
It won't out perform the FA450R3 on GI (as far as power) like people think & will lag behind when CDI is used on the 450.
Hide Signatures
       Post #: 59
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/17/2013 5:27 PM
Flyfast1
Score: 100
Last Login: 5/23/2013
Status: offline
Nice engine. Does anyone have pictures of the muffler? I wonder what it looks like.
-Ed B.
Spitfire Brotherhood #185
Hide Signatures
       Post #: 60
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/17/2013 5:31 PM
BobH
Score: 116
Status: offline
Saito must feel that there's a market for the gas versions of their engines or else they wouldn't make them. So regardless of the discussion about glow and CDI vs gas etc. it is what it is. The good part is that you'll have a choice.. I can't see an issue with that
BobH.
Hide Signatures
       Post #: 61
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/17/2013 8:21 PM
cbooth1979
Score: 100
Status: offline
From what I could see the diameter is 250mm? Is that correct? Im just trying to get an overall size of the motor. I wish it would fit in my Hanger 9 P-47
Hide Signatures
(in reply to BobH)
       Post #: 62
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/18/2013 2:19 AM
n8622t
Score: 101
Status: offline
Yeah just under 10"
Hide Signatures
(in reply to cbooth1979)
       Post #: 63
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/18/2013 2:29 AM
n8622t
Score: 101
Status: offline
quote:
ORIGINAL: rcnut101
And that's why Saito is converting so many glow engines to gas?
Hide Signatures
       Post #: 64
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/18/2013 2:03 PM
Aussie Maddog
Score: 100
Last Login: 5/5/2013
Status: offline
Please correct me if I'm wrong, but don't radial engines have non-symetrical spark firing?
Meaning a 3 cylinder engine does not fire every 120 degrees.
I believe it is to do with how the master rod and other rods interact.
This would be why every cylinder needs it's own magnet to fire?
Hide Signatures
       Post #: 65
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/18/2013 5:11 PM
Tom in Cincy
Score: 110
Status: offline
A cylinder fires every 240 deg. Normally the firing order is 1-3-2. 1 & 3 fire on the first revolution and only cylinder 2 fires on the 2nd revolution. 2 revolutions of the crank complete a firing cycle on a 4 stroke engine. ( I hope )
"Nosen Cessna 310 Club #10"
Hide Signatures
(in reply to Aussie Maddog)
       Post #: 66
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/18/2013 11:53 PM
rcnut101
Score: 100
Status: offline
I'm not sure if any one knows, But here are the specs.
http://www.saito-mfg.com/radial-files/FG-84R3/fg-84r3.html
Hide Signatures
(in reply to Tom in Cincy)
       Post #: 67
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/19/2013 12:57 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: n8622t
quote:
ORIGINAL: rcnut101
You have to give the public what it thinks it wants regardless of practcality.
Should Saito ignored the current gas engine market?
Heck no. People get it in their heads that they want something, they will buy it even if it is not a significant improvement. Might as well give the suckers what they want.
Should Saito have utillized more proven components in their ignition systems rather than trying to utilize "proprietary" components?
Very much so. Most of their single cylinder gas engines are flops & require converting to C&H CDI & ZAMA/Walbro carburators for dependable power. Saito is taking a serious hit in reputation as this unfolds.
Should Saito have redesigned their engines for gasoline fuel?
Yes, but other than increasing displacement & (I assume) lowering CR they have not. Still the same crankshafts & connecting rods on most FG engines. The part #s for the crankshafts differ in that the FG crank has a provision to lock in the prop hub. (another poorly designed part of their ignition systems) No provisions for increased operating tempertures or reduced oiling.
A Saito engine converted to CDI while retaining methanol fuel will make more power than a gasoline conterpart W/less smell. It will run cooler & most likely last much longer. Other than the somewhat reduced operating cost for gasoline, (not taking into account reduced engine life) the CDI methanol engine will have all of the advantages of the gasoline counterpart.
If you want a gas burning 4-stroke engine, buy one designed as such from the get-go.
http://www.rotomotor.cz/rotomotor/en/default.html
All this, mind you, from a rabid Saito fan that has been running CDI W/methanol in my Saito engines since 1997.
< Message edited by SrTelemaster150 -- 1/19/2013 3:07 AM >
Hide Signatures
       Post #: 68
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/19/2013 1:02 AM
SrTelemaster150
Score: 229
Status: offline
Same price, same displacement, same HP as the FG84 at .8# less weight.
Designed as a gas engine from the start.
http://www.rcuniverse.com/market/item.cfm?itemId=884603
Hide Signatures
       Post #: 69
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/19/2013 2:51 AM
Old Fart
Score: 158
Status: offline
Yes but..it's a two stroke.I'd like to see saito go down the same path kolm engines have.
Watch out for the ground eh?
Hide Signatures
       Post #: 70
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/19/2013 2:53 AM
Old Fart
Score: 158
Status: offline
In the bird dog i meant.
Hide Signatures
(in reply to Old Fart)
       Post #: 71
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/19/2013 3:03 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Old Fart
quote:
ORIGINAL: Old Fart
Oh crap! I completely missed that. I was looking for something W/flight footage.
I'll go back & edit in some 4-stroke bench test videos then. The 85cc 4-stroke is what I was comparing to the FG84R3.
Hide Signatures
       Post #: 72
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/21/2013 4:21 AM
n8622t
Score: 101
Status: offline
quote:
ORIGINAL: n8622t
quote:
ORIGINAL: rcnut101
Should Saito have utillized more proven components in their ignition systems rather than trying to utilize ''proprietary'' components?
Wow a certified shrink.....sorry dude I know what I want and it ain't glow
Hide Signatures
       Post #: 73
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/21/2013 6:50 AM
n8622t
Score: 101
Status: offline
Convenience of availability, economical value, and no oily residue of gasoline far far far..... Did I say far.....outweighs the ever so slight loss of power over glow fuel, in my humble opinion
Hide Signatures
       Post #: 74
RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84 - 1/21/2013 11:19 AM
Old Fart
Score: 158
Status: offline
The last thought that came to mind is humble,pm me and we'll go from there.Sr telemaster posts a lot of real good info about this very subject and like it or not it is given.Think about that.;
Hide Signatures
       Post #: 75
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: New Saito 4 Cycle Gas Engine, 3 Cyl FG-84
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
