Metallic Blue P-40's?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Full Scale planes, cars, helis, boats >> Airplanes - Full Scale >> Metallic Blue P-40's?
Page: [1]
Login
Metallic Blue P-40's? - 8/12/2012 11:44 AM
AmishWarlord
Score: 121
Last Login: 5/8/2013
Status: offline
Here is an old pic from Buffalo NY.
These P-40s are under construction in 1941.
In the back ground there are some that look to be painted with a metallic blue paint.
What kind of paint is this or is it some kind of masking film?
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: Metallic Blue P-40's? - 8/12/2012 11:56 AM
guamflyer
Score: 100
Last Login: 4/25/2013
Status: offline
that is really COOL.. i wonder if it was for  the navy at the time..i also wonder if its some kind of prep coat or anodized...when i get a chance , i'll research it also....
Hide Signatures
(in reply to AmishWarlord)
       Post #: 2
RE: Metallic Blue P-40's? - 8/12/2012 12:50 PM
AmishWarlord
Score: 121
Status: offline
No, the NAVY didn't like water cooled planes at all.
Hide Signatures
(in reply to guamflyer)
       Post #: 3
RE: Metallic Blue P-40's? - 8/14/2012 4:38 PM
Chad Veich
Score: 265
Last Login: 5/19/2013
Status: offline
Anodized aluminum for corrosion protection.
Hide Signatures
       Post #: 4
RE: Metallic Blue P-40's? - 8/15/2012 9:02 AM
stuntflyr
Score: 137
Status: online
Darn,
I thought the pics would be a pretty 60's paint job!
Chris...
Hide Signatures
(in reply to Chad Veich)
       Post #: 5
RE: Metallic Blue P-40's? - 8/16/2012 3:14 AM
Chad Veich
Score: 265
Status: offline
Maybe the Blue Angel's started with P-40s??? Not! But you gotta admit that is what it kinda looks like.
Hide Signatures
(in reply to stuntflyr)
       Post #: 6
RE: Metallic Blue P-40's? - 8/16/2012 5:34 AM
cfircav8r
Score: 218
Last Login: 5/17/2013
Status: offline
Back in my old sheet metal days we would spray that same blue color on aluminum so the scribe lines and marks were easier to see, and it cleaned off very easily. This may have been the same idea.
_____________________________
The three most useless things to a pilot, the sky above you, the runway behind you, and the fuel on the ground.
Hide Signatures
       Post #: 7
RE: Metallic Blue P-40's? - 12/27/2012 6:38 AM
Chris Nicastro
Score: 123
Last Login: 5/18/2013
Status: offline
It does look like Dykem Blue layout fluid but the whole plane? To lay out the rivets maybe? Looks neat though, cool photo.
Like a midget in a urinal I knew I had to stay on my toes...
Hide Signatures
(in reply to cfircav8r)
       Post #: 8
RE: Metallic Blue P-40's? - 12/27/2012 12:56 PM
N1EDM
Score: 125
Status: offline
Could that photo have been PhotoShopped?????
Bob
Club Saito #61 Cub Brotherhood #107
Spitfire Brotherhood #143
Hide Signatures
(in reply to Chris Nicastro)
       Post #: 9
RE: Metallic Blue P-40's? - 1/2/2013 5:35 AM
Texastbird
Score: 150
Status: offline
Color shift in the dyes and\or strange lighting in the original. Look at the washed out red in the insignia. You can't really trust old color photos for true shades.
Hide Signatures
(in reply to N1EDM)
       Post #: 10
RE: Metallic Blue P-40's? - 1/2/2013 3:54 PM
hrrcflyer
Score: 121
Status: offline
OK,
I can see that the blue may be part of the anodizing process, but how do you explain the fact that the bottoms of the planes are bright yellow? There is also yellow around the rear of the glass in the cockpits of the blue planes and there is a solid yellow rudder on one of the planes in the background. There also appears to be yellow around what appears to be the very front of some cowl's on the left hand side of the picture. I'd sure like to learn more about this picture as well.
David
Fly Safe and Have Fun ! ! !
Ultra Sport Brotherhood #22
Hide Signatures
(in reply to Texastbird)
       Post #: 11
RE: Metallic Blue P-40's? - 1/3/2013 5:04 PM
Chad Veich
Score: 265
Status: offline
quote:
ORIGINAL: hrrcflyer
...but how do you explain the fact that the bottoms of the planes are bright yellow? There is also yellow around the rear of the glass in the cockpits of the blue planes and there is a solid yellow rudder on one of the planes in the background. There also appears to be yellow around what appears to be the very front of some cowl's on the left hand side of the picture.
Zinc Chromate primer
Hide Signatures
(in reply to hrrcflyer)
       Post #: 12
RE: Metallic Blue P-40's? - 1/3/2013 5:47 PM
hrrcflyer
Score: 121
Status: offline
quote:
ORIGINAL: Chad Veich
quote:
ORIGINAL: hrrcflyer
Oh OK, that makes sense to me. Thanks Chad....................
David
Hide Signatures
       Post #: 13
RE: Metallic Blue P-40's? - 1/17/2013 4:38 PM
proptop
Score: 130
Last Login: 5/9/2013
Status: offline
The blue might be a blue tinted clear coating applied by the Alum. manuf.? (it just hasn't been removed or painted over yet ) It looks like maybe a Wash Primer...? Could be a sprayed on coat of Dykem Blue to help lay out the rivet lines, as stated above...?
The Japanese in the WWII era sometimes used a transparent blue or green "primer" coating...basically just a blue or green tinted clear, or what we might call a "Candy" coat now days. (all a "Candy Apple Red" (or any other Candy color ) is just a tinted clear coat applied over a silver, or gold or other usually metallic base coat...)
Cool picture BTW...haven't seen that one before.
If you see some of the recent pics taken at Boeing factorys, you will see what looks like a clear green coating on the yet to be painted areas of 747's, etc.
< Message edited by proptop -- 1/19/2013 1:00 AM >
It is bad luck to be superstitious...
Steuben Red Barons, Paradise R/C Flyers, RAAM
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.047RCU1
