RE: ys175    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> RE: ys175 Page: <<   < prev  1 2 [3]
Login
RE: ys175 - 9/17/2012 8:15 AM
drac1
Score: 100
Last Login: 5/6/2013
Status: offline
The YS cdi comes with a plastic spiral wrap to put on the high tension lead.
_____________________________
There is no such thing as too much power.
Hide Signatures
(in reply to MTK)
       Post #: 51
RE: ys175 - 9/26/2012 1:09 AM
rm
Score: 100
Last Login: 5/19/2013
Status: online
I've had the ck valve snap off flush at the cylinder head.  According to the parts diagram looks like the nipple is part of the head.  Looks like it threads in but doesn't have a part #.
So I need a new cylinder head?
On the valve springs, you just compress the the springs and the retainer clips will slide out?  Any hints on doing this?
Hide Signatures
(in reply to drac1)
       Post #: 52
RE: ys175 - 9/26/2012 1:27 AM
drac1
Score: 100
Status: offline
The nipple has the injector tube in it and is a press fit into the head. You can have it sent back to YS and they will repair it.
No special way of removing the retainers. Just compress the spring and remove them. Make sure they are seated properly when you reassemble.
< Message edited by drac1 -- 9/27/2012 11:11 PM >
Hide Signatures
(in reply to rm)
       Post #: 53
RE: ys175 - 9/29/2012 1:30 AM
drac1
Score: 100
Status: offline
This is the new YS header fitted to my Valiant. Much easier to fit and will solve the problem of the flange screws coming loose. A very good quality product and very neat. Fits the #821 Hatori muffler.
The Header is available in a 10mm and 20mm rise. The YS header weighs 3 grams less than the Hatori header. I will be fitting the 175cdi as soon as i get a chance.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by drac1 -- 9/29/2012 1:52 AM >
Hide Signatures
(in reply to drac1)
       Post #: 54
RE: ys175 - 9/30/2012 4:28 AM
jkruger
Score: 100
Last Login: 5/18/2013
Status: offline
Where did you get the YS header?
John Kruger
Hide Signatures
(in reply to drac1)
       Post #: 55
RE: ys175 - 9/30/2012 4:50 AM
riot3d
Score: 100
Status: offline
Contact Richard Verano, I got mine from him.
Adrian
Hide Signatures
(in reply to jkruger)
       Post #: 56
RE: ys175 - 9/30/2012 4:51 AM
drac1
Score: 100
Status: offline
Naruke Hobby - Japan.
Hide Signatures
       Post #: 57
RE: ys175 - 10/13/2012 2:19 AM
rm
Score: 100
Status: online
Tried a 21x10 today.  Outside temp was 11 celsius, so had pretty good air.  6300 rpm, 25% coolpower, didn't really play with the needle, just got decent smoke, to cold to fool around for me.  Anyways I absolutely loved this prop.  Pulled verticle forever and downline breaking is really good, you need to be throttling up before you pull out, flying ama masters.  I was able to get a more constant speed throughout the pattern as compared to when I was trying the 20.25 x 10.   I really liked it.  13+ minutes on 20oz tank.
Hide Signatures
(in reply to drac1)
       Post #: 58
RE: ys175 - 10/13/2012 10:41 AM
Torben Parsberg
Score: 100
Last Login: 3/14/2013
Status: offline
Hallo Was it WPN.?
Hide Signatures
(in reply to rm)
       Post #: 59
RE: ys175 - 10/13/2012 11:51 AM
rm
Score: 100
Status: online
Yes.
I should add that it was fairly light winds also,  around 7-8 kts.
< Message edited by rm -- 10/13/2012 12:16 PM >
Hide Signatures
(in reply to Torben Parsberg)
       Post #: 60
RE: ys175 - 10/13/2012 3:51 PM
jkruger
Score: 100
Status: offline
Wich size rise did you use on your Valiant? 10mm or 20mm?
Hide Signatures
(in reply to rm)
       Post #: 61
RE: ys175 - 10/13/2012 10:46 PM
drac1
Score: 100
Status: offline
I previously used the 25mm rise Hatori header, so i usd the 20mm rise YS header. Worked out very well.
Regards
Scott
Hide Signatures
       Post #: 62
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.392RCU1
