HiMax motor mount screw size?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Brushed/Brushless motors, speed controls, gear drives >> HiMax motor mount screw size?
Page: [1]
Login
HiMax motor mount screw size? - 8/14/2012 8:42 PM
skylane42
Score: 109
Last Login: 5/13/2013
Status: offline
HI guys, Does anyone know the screw size for mounting a HIMax HC3510-1000 motor. I am talking about the screws that go into the motor body. I am pretty sure that they are metric.
Hide Signatures
       Post #: 1
RE: HiMax motor mount screw size? - 8/15/2012 1:40 PM
Dr Kiwi
Score: 120
Last Login: 5/23/2013
Status: offline
Probably 3mm....as always, make sure they are not too long (they might get into the windings).
_____________________________
Dr Phil Millener, Chattanooga, TN
Hide Signatures
(in reply to skylane42)
       Post #: 2
RE: HiMax motor mount screw size? - 10/11/2012 1:49 AM
commander dave
Score: 100
Last Login: 12/22/2012
Status: offline
Pulled this info from the MPI Himax web site for your 3510 motor. As said above make sure the screws you use are not too long.
Specifications:
Weight: 89g, (3.1oz), Motor only
Max Power: 250W, (This is dependent on several factors)
Max RPM: 20,000 RPM
Diameter: 35.2mm, (1.39”)
Length: mm, 32.2mm(1.27”)
Shaft Diameter: 4.0mm (.1575”)
Mount Screw Thread: 4-40, max depth 5mm, on 25mm, (1.0”) circle
Maximum Case Temperature: 65
o
C, (149
o
F)
Hide Signatures
(in reply to Dr Kiwi)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
