RE: ARIXTRA Build Thread by ISAAC NAJARY    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> RE: ARIXTRA Build Thread by ISAAC NAJARY
Page: <<   < prev  4 5 6 7 [8] 9 10 11 12 13   next >   >>
Login
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/15/2012 3:56 PM
najary
Score: 100
Last Login: 6/19/2013
Status: offline
Saving 33.4 gram - (53.6-20.2)
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to najary)
       Post #: 176
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/18/2012 3:26 PM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 177
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/18/2012 3:35 PM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 178
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/18/2012 3:37 PM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 179
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/18/2012 3:39 PM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 180
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/18/2012 3:41 PM
najary
Score: 100
Status: offline
More
Click for fullsize
Hide Signatures
       Post #: 181
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/18/2012 3:42 PM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 182
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/24/2012 8:02 AM
gaRCfield
Score: 156
Status: online
Hi Isaac,
Would you mind commenting on how you find the center of the slots for the rudder cable? I see you lay out the cable geometry, which I assume is based on the size of the control horns and the distance between them; what determines the exit location?
_____________________________
Joe Marri
Enjoying all things aviation.
Hide Signatures
       Post #: 183
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/25/2012 8:44 AM
najary
Score: 100
Status: offline
quote:
ORIGINAL: gaRCfield
Hi Isaac,
Hi Joe,
You right, I lay out the cable geometry based on the size of the control horns and the distance between them and the fuselage sides.
Then I measure the distance between the rudder hinges and the meeting point of the cables and the fuselage sides, it is 12.5 cm, see post 180 second picture.
Then I lay out the locations of the cable on the fuselage, sides see post 180 third picture.
Then I lay out the cable exit locations 12.5 cm from the rudder hinges, see post 180 fourth picture.
Best regards,
Isaac Najary
Hide Signatures
(in reply to gaRCfield)
       Post #: 184
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/25/2012 12:31 PM
Jeff Worsham
Score: 105
Status: offline
Isaac,
What kind of switch harness are you using? I've not seen one of those before. Thank you-
Rookie Sportsman
Hide Signatures
       Post #: 185
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/25/2012 3:45 PM
najary
Score: 100
Status: offline
quote:
ORIGINAL: Jeff Worsham
Isaac,
Hi Jeff,
This is a hybridization I made from these two:
http://www.powerbox-systems.com/e/powerbox_systeme/digi_switch/start.php
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJUW6&P=SM
Best regards,
Isaac Najary
Hide Signatures
(in reply to Jeff Worsham)
       Post #: 186
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/29/2012 7:23 AM
najary
Score: 100
Status: offline
Weights before covering:
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 187
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/29/2012 7:26 AM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 188
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/29/2012 7:34 AM
najary
Score: 100
Status: offline
More
Click for fullsize
Hide Signatures
       Post #: 189
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/29/2012 7:36 AM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 190
RE: ARIXTRA Build Thread by ISAAC NAJARY - 12/29/2012 7:40 AM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 191
RE: ARIXTRA Build Thread by ISAAC NAJARY - 1/3/2013 3:53 PM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 192
RE: ARIXTRA Build Thread by ISAAC NAJARY - 1/3/2013 5:28 PM
Jeff Worsham
Score: 105
Status: offline
Coming from the days when color schemes consisted of mainly straight lines (usually only a few small curves to deal with), I'm glad to see how these "new fangled swoopy" color schemes can be accomplished. Never thought of making a template for an entire flying surface. Thanks for showing your process Isaac!
Rookie Sportsman
Hide Signatures
       Post #: 193
RE: ARIXTRA Build Thread by ISAAC NAJARY - 1/5/2013 11:40 AM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 194
RE: ARIXTRA Build Thread by ISAAC NAJARY - 1/5/2013 2:53 PM
can773
Score: 105
Status: offline
Fabulous as usual Isaac! Could you show the weight before and after covering for the wings? I am curious to know the difference.
Hope to see this airplane in South Africa!?
Chad Northeast
Hide Signatures
       Post #: 195
RE: ARIXTRA Build Thread by ISAAC NAJARY - 1/5/2013 4:34 PM
najary
Score: 100
Status: offline
quote:
ORIGINAL: can773
Hi Chad,
See the weights before covering in post 187.
I will post the weights after covering when it will be finish.
I am not so sore about South Africa.
Best regards,
Isaac Najary
Hide Signatures
(in reply to can773)
       Post #: 196
RE: ARIXTRA Build Thread by ISAAC NAJARY - 1/9/2013 8:06 AM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 197
RE: ARIXTRA Build Thread by ISAAC NAJARY - 1/12/2013 5:09 PM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 198
RE: ARIXTRA Build Thread by ISAAC NAJARY - 1/12/2013 5:14 PM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 199
RE: ARIXTRA Build Thread by ISAAC NAJARY - 1/17/2013 3:59 PM
najary
Score: 100
Status: offline
More
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
