Ultra flash or Bandit    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Ultra flash or Bandit
Page: [1] 2   next >   >>
Login
Ultra flash or Bandit - 8/17/2012 10:36 PM
KFX450
Score: 100
Last Login: 5/22/2013
Status: offline
I'm thinking of my next winter project and I'm trying to decide between the two. I had my heart set on a bandit but I was just watching an ultra flash and it made me think twice. Price point being a really good factor. Don't want to start anything here but would like to hear from people on thoughts. I find this a good place to sway my decision. Would like to hear from some people that have flown both. Thanks in advance.
Hide Signatures
       Post #: 1
RE: Ultra flash or Bandit - 8/17/2012 10:55 PM
JackD
Score: 100
Last Login: 5/23/2013
Status: online
Well, you have an electra.... a Bandit is the natural evolution
Disclaimer: Ive never flown a Flash, so my comment is not a comparison... just in case
_____________________________
Jack Gerardo Diaz
BVM Rep, Team Horizon, Team Jet Central
Hide Signatures
(in reply to KFX450)
       Post #: 2
RE: Ultra flash or Bandit - 8/18/2012 12:31 AM
AFTERBURNER1
Score: 135
Status: offline
I've had two Bandits and two Ultra Flashes.... Im still flying my new Ultra Flash and the Bandits have both been sold... Both fly great but I'll take the UF ...
[Photobucket Pictures, Images and Photos]
NOTHING IS BULLETPROOF
Hide Signatures
(in reply to JackD)
       Post #: 3
RE: Ultra flash or Bandit - 8/18/2012 12:43 AM
dbsonic
Score: 100
Status: offline
For my own edu. what will a brand new UF run you RTF (minus the turbine)?
Hide Signatures
(in reply to AFTERBURNER1)
       Post #: 4
RE: Ultra flash or Bandit - 8/18/2012 1:15 AM
dubd
Score: 135
Status: online
Darren, you can build a Ultra Flash without a turbine for about $4500.
Hide Signatures
(in reply to dbsonic)
       Post #: 5
RE: Ultra flash or Bandit - 8/18/2012 6:12 AM
wojtek
Score: 110
Status: offline
I personally think the Ultra Flash is a lot better flying of a jet over the Bandit ... Preference may differ between flying styles. To me the UF is more "snappy" and light feeling, taking tight aerobatics somewhat better. For cruising around with an occasional point roll or loop here or there, the BARF, or any other bandit would be great as well however. I have also seen and herd of several bandits shedding wings, stabs, etc in flight during normal use. I don't believe many (if any) any flashes have been reported to loose parts in flight... , on the other hand, Flashes do have a problem with surface hinging delamanating if not handled carefully on the ground or in transport.
~V~
Nothing can ever be fast (or scale ;) ) enough !!!
www.all-scale.com
Hide Signatures
(in reply to dubd)
       Post #: 6
RE: Ultra flash or Bandit - 8/18/2012 6:41 AM
InboundLZ
Score: 140
Status: offline
We currently have a Bandit and a Ultra-Flash. The bandit is areodynamically perfect and flys about as true as an airplane can get, zero bad habits....but its not the most robust airframe out there and can be a little fragile. The UF on the other hand is about as rugged airframe money can buy. Hard landing, no problem....60G 180 degree turn at 200mph, pfttt child's play... However, the UF does need some mixing in certain situations....
Dollar for dollar, the UF wins hands down. If you want perfection in flight, its the Bandit all the way....
Dave Bottita
evoJet Factory Pilot
Smart-Fly
Hide Signatures
(in reply to wojtek)
       Post #: 7
RE: Ultra flash or Bandit - 8/18/2012 3:08 PM
KFX450
Score: 100
Status: offline
Thanks for the input guys. I appreciate all the responses.
Hide Signatures
(in reply to InboundLZ)
       Post #: 8
RE: Ultra flash or Bandit - 8/18/2012 3:44 PM
sailing1
Score: 100
Status: offline
What are the price points all up for the Bandit less turbine of choice?
Hide Signatures
       Post #: 9
RE: Ultra flash or Bandit - 8/18/2012 4:07 PM
jtlittle
Score: 110
Status: online
Compare the return if you decide to sell each airframe. Consider this in the cost.
Hide Signatures
(in reply to sailing1)
       Post #: 10
RE: Ultra flash or Bandit - 8/18/2012 4:20 PM
dubd
Score: 135
Status: online
quote:
ORIGINAL: sailing1
Around $6500.
I've owned two Bandits (one was Doug's) and two Flashes (classic and ultra) and really liked both airframes. I echo Doug and Dave's opinions on both planes. I loved the precision of the Bandit and the ruggedness of the Flash. The Ultra Flash is almost at the same level as the Bandit in terms of precision, but can take a beating. My only knock on the Ultra Flash are the terrible factory color schemes.
< Message edited by dubd -- 8/18/2012 7:40 PM >
Hide Signatures
       Post #: 11
RE: Ultra flash or Bandit - 8/18/2012 5:57 PM
ozief16
Score: 170
Status: offline
I second both Dantley and Dave's comments after owning both. I lost my bandit due to radio failure and elected to replace it with an UF eventually
Dave
Hide Signatures
(in reply to dubd)
       Post #: 12
RE: Ultra flash or Bandit - 8/18/2012 5:59 PM
KFX450
Score: 100
Status: offline
quote:
ORIGINAL: dubd
quote:
ORIGINAL: sailing1
Around $6500.
I've owned two Bandits (one was Doug's) and two Flashes (classic and ultra) and really liked both airframes. I echo Doug and Dave's opinions on both planes. I loved the precision of the Bandit and the ruggedness of the Flash. The Ultra Flash is almost at the same level as the Bandit in terms of precision, but can take a beating. My only knock on the Ultra Flash are the terrible color factory color schemes.
I talked with Ray Labonte this weekend. He is a CARF dealer. You can order the UF as a custom scheme like the red white and blue on the classic flash. That's a plus because I'm going to have to agree. I don't like any of the schemes on the website.
Hide Signatures
(in reply to dubd)
       Post #: 13
RE: Ultra flash or Bandit - 8/18/2012 8:43 PM
RBardin
Score: 110
Last Login: 5/18/2013
Status: offline
I would be really interested in some substantive details on this, Voy. Please post more info... Most everyone here remembers Adil's issue, but honestly thats the last I've heard or seen of what you describe above, and that one was extremely isolated with many circumstances about it. On what versions comparable to a UF have you seen/heard these issues happen? I have seen a Youtube of a guy who admittedly flew a BARF 100 mph over VNE and destroyed it, but that would fall far beyond the parameters of normal use.
I'm still working on a composite super myself, so if there is anything I need to look out for or be aware of, then I want to know!
Rusty
Hide Signatures
       Post #: 14
RE: Ultra flash or Bandit - 8/18/2012 10:51 PM
wojtek
Score: 110
Status: offline
quote:
ORIGINAL: RBardin
Rusty
Adils wings ripping off is one I have seen blow apart first hand. I saw one at a jet rally in VA with the vertical stab ripping completely off in flight causing a crash. Two have blow apart in the air at a local field in PA that I know of. There are other instances reported here on RCU also. If its gentle pattern aerobatics someone wants, a bandit is great.
The UF is definitely a more robust airframe. The hinge delamination can be a pain, but at least ,it wont likely occur in flight, or cause the airframe to blow apart.
As for the poor paint scheme sellection, well, one can always go custom
~V~
www.all-scale.com
Hide Signatures
(in reply to RBardin)
       Post #: 15
RE: Ultra flash or Bandit - 8/19/2012 2:34 AM
RBardin
Score: 110
Status: offline
Man, I wish you had more details - what specific airframes were the 2 at the local PA airport? How were they powered? How were they flown? And the one you saw in VA, what version was that one, and what was the consensus after it went in as to cause?
After searching RCU itself, Bing and Google as well, all I got was the hit for the one that was on youtube, RCPete's rebuild of Francis' old 500+ flight bird, and Adils old thread. I used several search strings - BVM bandit failure - bandit wing failure, Stab failure, flutter, etc. I'm pretty good at finding old threads and such, but I cant seem to find anything. Post some links, please!
Hide Signatures
       Post #: 16
RE: Ultra flash or Bandit - 8/19/2012 2:43 AM
Cratus
Score: 100
Status: offline
quote:
ORIGINAL: KFX450
Never flown an UF but I currently have a composite Super Bandit with a P-120. The model flies absolutely phenomenal. I tell my friends the jet feels like a sniper’s riffle in terms of precision and reliability. BV builds a great kit. You won't be disappointed.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 17
RE: Ultra flash or Bandit - 8/19/2012 6:57 AM
indubitably
Score: 101
Status: offline
Waiting for the 180RX to put in the Super Bandit.
Hide Signatures
(in reply to Cratus)
       Post #: 18
RE: Ultra flash or Bandit - 8/19/2012 7:20 AM
mr_matt
Score: 116
Status: offline
 I have a super bandit with an original p-180. It was heavy and bent the axles. I have been retrofitting better gear for about 3 years!
I have not owned an UF but have seen many fly. They have a thicker wing I think and they hold more fuel or smoke. I don't think you can get near as much fuel and smoke oil in a bandit. I do think it is easier to put full gear doors on a bandit which helps with top speed when going this fast. And I agree the flash is a tank in terms of toughness. I don't think the BARF is as robust as a normal super but that is just opinion.
Matt
Hide Signatures
(in reply to indubitably)
       Post #: 19
RE: Ultra flash or Bandit - 8/19/2012 11:33 AM
Erik R
Score: 130
Status: online
quote:
ORIGINAL: RBardin
Hi,
They were both mine.They were both classics,and in all fairness, they were flown extremely hard.One had a P-160 turned down to 27 lbs,and the other had a P-120.I bought them both used,and the cause wasn't the design in either case.The first was repaired after a catastrophic pipe failure,and was never the same after that.The second was 10 years old,and had the older style hinge on one of the flaps let go at very high speed. I had a super bandit with hundreds of flights on it before I sold it,and I ran it hard.Just an awesome airplane.You will love it,and it will last a long time unless you hurt it in some way. If you're going to run it hard,make sure you have zero slop in your servos and linkages. I find bandits to be prone to aileron flutter at high speed unless there is zero slop in the linkage/servo.I have no experience with Flashes.Good luck.
Erik
Farviewflyers.net
Hide Signatures
       Post #: 20
RE: Ultra flash or Bandit - 8/19/2012 3:35 PM
AFTERBURNER1
Score: 135
Status: offline
quote:
ORIGINAL: indubitably
D
You were three seconds behind that 160sx powered ultra flash all the time.. I would think 2x before runnin a 180rx in a SB.
Hide Signatures
       Post #: 21
RE: Ultra flash or Bandit - 8/19/2012 3:37 PM
AFTERBURNER1
Score: 135
Status: offline
Look out!!
Hide Signatures
       Post #: 22
RE: Ultra flash or Bandit - 8/19/2012 3:45 PM
Ramz
Score: 106
Status: offline
I only have personal experience with a UF. Can't speak for the Bandit but I love my UF. I fly it hard with a K170F and it takes it well. I have a transport stand custom built for the UF which eliminates the delamination problems from transport as far as the fuselage. As far as the aileron and flap hinges, they are not an issue as long as care is taken during handling. It goes together fast and easy. The fit and finish is fantastic and the paint is equally impressive. The only issue I had with mine so far (40 flights) is the main fuselage tank leaked around the neck during the pressure buildup during the filling process. I put some hysol and cloth around the neck and it solved the problem. I am also going to drop my fuel pump voltage from 6.6 to 3v or 4v. If my UF were to go in, I would replace it with another UF in a heart beat.
Hide Signatures
(in reply to Erik R)
       Post #: 23
RE: Ultra flash or Bandit - 8/19/2012 4:09 PM
indubitably
Score: 101
Status: offline
quote:
ORIGINAL: AFTERBURNER1
D
Not sure what you mean. I have not posted video of my plane. Just wondering if you saw someone else fly the 160 UF. Also, i do not see the Top speed as much faster, just the vertical, and acceleration. Like driving a Veyron, 55mph most of the time. Still with over 1,000 hp fun.
Hide Signatures
       Post #: 24
RE: Ultra flash or Bandit - 8/19/2012 6:40 PM
RBardin
Score: 110
Status: offline
quote:
ORIGINAL: Erik R
quote:
ORIGINAL: RBardin
Hi,
Erik
Glad you chimed in, Erik. I had a feeling there was more to the story. I'll double truss my ailerons and use 8711's.
Rusty
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.031RCU1
