Flight times    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> E-Flight Power Sources >> Flight times
Page: [1]
Login
Flight times - 8/19/2012 4:38 AM
andrewskj
Score: 100
Last Login: 5/22/2013
Status: offline
If you know the amp draw and the battery size what is the formula to get the expected flight times?
Hide Signatures
       Post #: 1
RE: Flight times - 8/19/2012 4:59 AM
jdetray
Score: 115
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: andrewskj
Formula for Run Time
run time in minutes = (Battery Capacity in Ah/Motor Current in A) x 60
This is just a rough guide, and it requires that you know approximately how much current your power system draws. A wattmeter will tell you. The formula also needs your battery capacity in Amp Hours (Ah). Divide mAh by 1000 to get Ah.
The simplest method is to measure your current at full throttle and use that number in the formula. In reality, you probably won't fly at full throttle all the time, so your average current usage probably will be less than the full-throttle value. Also, a power system will often draw less current in flight than it does during ground testing.
So if you use the full-throttle current in the formula, it will generally give you a worst case flight time. Actual flight time will usually be greater.
I've included some examples below.
- Jeff
Here are some examples.
Example 1:
1500 mAh battery
power system draws 12A
1500 mAh = 1.5 Ah
1.5/12 x 60 = 7.5 minutes
Example 2:
1500 mAh battery
power system draws 18A
1500 mAh = 1.5 Ah
1.5/18 x 60 = 5 minutes
Example 3:
4000 mAh battery
power system draws 25A
4000 mAh = 4.0 Ah
4.0/25 x 60 = 9.6 minutes
Example 4:
5000 mAh battery
5000 mAh = 5.0 Ah
5.0/25 x 60 = 12 minutes
_____________________________
My other hobby: www.AstronomyBoy.com
Hide Signatures
(in reply to andrewskj)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.109RCU1
