Pre-Maiden Jitters    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Aviation Design Super Scorpion
Seller:  Modellbau USA
Details:   $6,750.00   |  5/24/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> Pre-Maiden Jitters
Page: [1] 2   next >   >>
Login
Pre-Maiden Jitters - 8/19/2012 7:25 PM
Microz
Score: 120
Last Login: 5/3/2013
Status: offline
 Hey guys. Im about ready to RE-Maiden my Parkzone P47, and am very, very nervous. I crashed my P47 last time because i was so nervous, that i just kind of pulled down elevator without even thinking. What do you guys do to cope with those "pre-maiden jitters"?
_____________________________
Planes:HBZ Champ, Micro T-28, Ember 2, UM Stryker
Cars: Traxxas Rustler, ECX Circuit
Hide Signatures
       Post #: 1
RE: Pre-Maiden Jitters - 8/19/2012 7:34 PM
Mr67Stang
Score: 155
Last Login: 12/14/2012
Status: offline
Your kidding right? That's why we buy so many planes. So we keep getting that rush.
Take a few deep breaths and just do it. You almost never make the same mistake twice.
He who dies with the most toys wins!
Hide Signatures
(in reply to Microz)
       Post #: 2
RE: Pre-Maiden Jitters - 8/19/2012 7:58 PM
Microz
Score: 120
Status: offline
Well no im not kidding...see, im a micro flyer, and those are just awesome fun especially since if you crash, its no big deal since theres a small chance of hurting it. With these big ones...well....not so much.
Hide Signatures
(in reply to Mr67Stang)
       Post #: 3
RE: Pre-Maiden Jitters - 8/19/2012 8:55 PM
jester_s1
Score: 233
Last Login: 5/25/2013
Status: offline
A plan helps a lot. Work out in your mind what your flight path is going to be and what maneuvers you're going to do. Also decide ahead of time what you are going to do if the wind throws you off course. Pick a day to fly when the wind is light so you know you'll have a predictable plane.
The second thing that really helps is getting a more experienced pilot to fly it for you the first time. That way you know you're starting with a properly trimmed plane and you can see it fly right before you get on the sticks.
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
       Post #: 4
RE: Pre-Maiden Jitters - 8/19/2012 9:10 PM
Microz
Score: 120
Status: offline
Thanks Jester! Yeah I'll see if there are any other pilots there who are experienced...winds are very low today so it should be good.
Hide Signatures
(in reply to jester_s1)
       Post #: 5
RE: Pre-Maiden Jitters - 8/19/2012 9:58 PM
DavidAgar
Score: 146
Status: offline
You said in your first post that you pulled down. Most planes are set up so that when you pull the stick, the plane climbs and when you push the stick, it will come down. Just a thought and Good Luck, Dave
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
Hide Signatures
       Post #: 6
RE: Pre-Maiden Jitters - 8/19/2012 10:04 PM
KitBuilder
Score: 131
Last Login: 5/22/2013
Status: offline
Jitters... they never go away.. as you get experience they just present themselves differently.
I'm coming to close on a 8 mos. WW1 1/6 scale bipe build. Lots of time invested so I'll be anxious more than nervose... My jitters over time have turned to a "bring it' attitude..... a sort of turning nervous energy into positive excitement.... I can't wait to see her sitting on the runway.... the 4 stroke ticking over like a clock... .advancing the throttle... the tail coming up.... is there anything better !! See a positive outcome.. see a positive experience in your head....having confidence is more than half the battle.
Mike -
I was born a pilot... 100 years to late.
Hide Signatures
(in reply to DavidAgar)
       Post #: 7
RE: Pre-Maiden Jitters - 8/20/2012 5:13 AM
jester_s1
Score: 233
Status: offline
I can say I've made that same transition, Kitbuilder. I get a little bit of the jitters when I take out a new plane or one I haven't flown in a while, but it's mostly just a little bit of anxiety of wanting to do a good job. For me it took a long time for me to really try to learn any maneuvers because I had a strong phobia of the plane just falling out of the sky or getting into a weird position all on its own that I couldn't figure out how to save it from. It didn't help that my first model was a Cessna that could be unpredictable. But some stick time and some simulator time gave me my confidence, and then flying an Ugly Stick gave me a lot more.
FWIW, plane setup is a huge part of being comfortable in flight. If a plane is twitchy and you find the plane overreacts to your controls, making you have to do constant corrections, then your throws are too hot. That was a major problem I had with the Cessna, but no one told me any different. If the plane doesn't land on a smooth glide slope with at least a little elevator control all the way to the ground the CG is wrong.
Microz, if you take a flight or two with a known good plane that helps a lot too. Your Champ is a great wind indicator, so if you don't have much trouble controlling it the warbird should be fine too. Were you able to get someone to help you get it back in the air?
Hide Signatures
(in reply to KitBuilder)
       Post #: 8
RE: Pre-Maiden Jitters - 8/20/2012 2:04 PM
Chevelle
Score: 110
Last Login: 5/5/2013
Status: offline
Jitters?  What jitters.
Just kidding.  We all have them, always with new planes.  Everyone is different but for me, it isn't about flying skill.  Not that I'm an expert or first class pilot.  Quite the contrary but my style has little pucker factor.  I comfortably stay within my capabilities.
For me, the jitters come from the "what did I forget" category.  It is the fear that during the build process, I made some horrible mistake that unbeknownst to me, there is a fatal flaw in the plane that has rendered it completely unflyable.  Of course the only way to know that is to fly it.  I'll have this vision that as soon as the wheels lift off, the plane with flip over on its back and splatter into a zillion pieces.
The good news is that has never happened.  Checking, rechecking, re-rechecking has helped keep my maidens pretty uneventful.
I guess the point is that if you are like most of us, the jitters come with the territory.  Just work through them and quell them as best as you can.
Salute!
Hide Signatures
       Post #: 9
RE: Pre-Maiden Jitters - 8/20/2012 2:51 PM
Sherv
Score: 100
Status: offline
quote:
ORIGINAL: jester_s1
Yea this is exactly what I do, on maidens I just take off and correct my settings then practice a few passes then practice landing and take offs.
I feel I need to be comfortable with landings and take offs before I start to test a plane. Because in the event I lose power I need to be able to land confidently. So I practice take offs and landings first then when everything checks out and I'm comfortable to land... I start to play around a bit getting more and more ballsy until after 10-30 flights BAM crash :P
MGT 4.6 w/ JP-3 (In the future)| MGT 3.0 | OFNA DM-1 Pro (future) | Savage Flux 2350 | Associated T4 FT CL | Lots a Planes!
Hide Signatures
       Post #: 10
RE: Pre-Maiden Jitters - 8/20/2012 3:37 PM
Microz
Score: 120
Status: offline
thanks guys. I ended up not going to the field yesterday because it began raining. Oh and when i said i pulled the stick down, I meant that i pushed it up to get the plane to come down hehehe. Hopefully sometime this week i can take the P47 out.
Hide Signatures
(in reply to Sherv)
       Post #: 11
RE: Pre-Maiden Jitters - 8/21/2012 12:01 AM
countilaw
Score: 219
Last Login: 5/24/2013
Status: offline
The best way to get rid of the   maiden flight jitters is to learn to fly,   and learn to fly correctly.   Too many  new pilots  get planes that are above their  ability  to fly.     I see too many  new  comers buying   mustangs,  P-40s,  and the like thinking they can fly them.
It's best to start with a trainer and getting good with it.   Then moving to a more  intermediat plane and getting good with it.    Once you are good at the controls and you have cofidence in your ability,  the jitters go away.    You then  experience  "excitment".
Frank
It''s a hobby, not a job.
Hide Signatures
       Post #: 12
RE: Pre-Maiden Jitters - 8/21/2012 12:29 AM
Jacobs Jasta 7
Score: 115
Last Login: 9/5/2012
Status: offline
quote:
ORIGINAL: countilaw
It's best to start with a trainer and getting good with it.   Then moving to a more  intermediat plane and getting good with it.    Once you are good at the controls and you have cofidence in your ability,  the jitters go away.    You then  experience  ''excitment''.
Frank
I agree to a point Frank, everyones learning curve is different, and it's not up to anyone to say if he or she is ready to handle whatever plane IMO. I've seen newbies on a warbird the second year in, and not crash it. I've been flying about 10 years and I still get the jitters at times. Also I fly scale and some of my planes have taken a year to build.
Also every first flight of every Spring my hands start to sweat a little. So to the OP I say you are right where your supposed to be and it is OK. I read somewhere someone older with a heart condition got a heart attack flying his RC airplane for the first time. He started feeling pains in his chest, managed to land the plane safely then dropped dead. It's rare, I wouldn't worry about it. Just focus on your airplane and watch what it does. Practice keeping your wings level and practice keeping your turns smooth. Remember to be nice and easy with your control movements (keep it smooth and gental). If it seems too much, just yell and have someone take over that has more experience. Another thing you can do is teather up with a instructor just in case.
Me if I get stage fright at a big event, I just try to picture everyone naked.
Pete
Hide Signatures
(in reply to countilaw)
       Post #: 13
RE: Pre-Maiden Jitters - 8/21/2012 12:56 AM
jetmech05
Score: 133
Status: offline
ever hear of self fulfilling prophoeceies? ( i guess that's spelled right) any way being nervous of crashing makes you crash....
I guess the best way to control that is not so much a flight plan...as a mission plan...ie I want to take off, set trims, check CG, see how it stalls, shoot some approaches then do a full stop. I can modify my plan at will depending on the situation. Perhaps I'll enlist the aid of a co pilot to stand next to me on the spot
I know how to fly, so I will, and the outcome is gonna be ok...I'm not going to loop or roll that will come later. Instead I am going to check the air worthiness of my ship.
Go get em
Hide Signatures
(in reply to Jacobs Jasta 7)
       Post #: 14
RE: Pre-Maiden Jitters - 8/21/2012 1:02 AM
flyntruk
Score: 105
Last Login: 4/1/2013
Status: offline
  I love that feeling . because it reminds me that I'm alive .  I recently maidened my GP WACO ,, I turned down some earlier attempts  because things just were'nt right ..   But one of the things I do is I bring a friend with me who is very experinced , and is very calm when things look  ike they may go bad .  My maiden went off like a good dream ..   every thing went right . but , I did have to sit down for about 10 min afterwards . Love them jitters ..
spitfire brotherhood #47 West Coast Squadron
Hide Signatures
       Post #: 15
RE: Pre-Maiden Jitters - 8/21/2012 2:14 AM
countilaw
Score: 219
Status: offline
I've newbys  flying  pattern in their  second year also.      But they didn't start flying pattern ships in the first  6 months of flying either.    They started out with the proper training,  the proper plane and the proper  technique.      You must learn to crawl before you can walk.     Too many newbys  start out with planes that are too far advanced for their owners  capabilities.
When I am going to maiden a new plane  I  know it's  straight and balanced.  I know it's going to take off level and climb out straight.   I know that my installations are correct and air worthy.    I have confidence in my ability to fly the plane.   Therefore, I am  excited to fly it.
With the world of   ARF   where someone else built the plane,  you don't know what's going to  happen when the plane leaves the ground.   But with close inspection and measurements,  you can take some of the guess work out of the results.
How many people have we seen or heard of that purchased a    RTF and took it to the school yard or park and tried to fly it with no instruction?  Quite a few I'm sure.     They crash the  toy plane,  it breaks and they walk away saying, " Well,   there's a shot  $200.   They drop it in the trash and go play video games.   If they had purchased the correct plane, had so instruction,  and learned the correct technique, they would probably be enjoying a great hobby now.
I am sure there will be some people pop on here and   claim that they taught themselves to fly.   Well good,  but at what costs?  How many planes did you go through?   How long did it take you?
This is the internet,   so   everything you read here is always the truth and no one lies about their experience and how great they fly or how long they have been flying.
Frank
Hide Signatures
(in reply to flyntruk)
       Post #: 16
RE: Pre-Maiden Jitters - 8/21/2012 5:26 PM
DadsToysBG
Score: 125
Status: offline
I've been flying 30 years and still get the jitters on a first flight. That's why I enjoy it so much. Nothing is more fun then the first flight.
My suggestion to to have two planes. One flying and one being fixed.
Hang in there it get easier, I promise. Dennis
DadstoysRC. I fly what I sell
CD Vette City Big Bird
Hide Signatures
       Post #: 17
RE: Pre-Maiden Jitters - 8/21/2012 6:02 PM
Luchnia
Score: 193
Status: offline
I am sort of the opposite as I do not enjoy the jitters and am not one of the jittery types. If I am nervous or jittery, I usually choose to not fly. Nervousness when flying a new plane has only happened to me a few times and I have learned that if I am nervous there is something else wrong and it is not the best time to maiden a plane. I will usually land the plane immediately and take a break. I may be too tired, or need to chill out or something else is affecting me.
Sometimes I think we over set our expectations and we can cause ourselves issues. Anticipation can play into this as well. If you have flown and are reasonably decent at it you should be able to maiden a plane. I have maidened several now and have not had but one catastrophic event and that was my fault because my ailerons were reversed. I would still have that plane had I been observant and checked behind myself. I was not nervous at all though when I took off. I was somewhat disappointed that I lost the plane.
When I maiden a plane I am very confident in my setup and usually no issues occur. I do check my ailerons better now One thing that I find is very important is once you have maidened the plane is to do post flight checks. Things can get loose and that is when a thorough checkover can expose something that will save your plane.
Some guys maiden anyone's plane. I don't feel comfortable maidening anyone else's plane, much less my own. I do admire the guys that can maiden anything though. Some guys can fly an inner tube
Hide Signatures
(in reply to DadsToysBG)
       Post #: 18
RE: Pre-Maiden Jitters - 8/21/2012 6:44 PM
Chucksolo69
Score: 169
Status: offline
quote:
ORIGINAL: countilaw
Frank
So I take it to mean that everyone that is self taught is lying or has spent a bunch of money on wrecked planes? Not necessarily so, but that subject has been beat to death in other threads.
To the OP I say, most everyone gets nervous on the maiden of a new plane. My knees were almost knocking when I put my Flyzone Focke-Wulf FW 190 in the air the first time. Same with my Parkzone T-28 Trojan, but since then, no nerves with these two. However, I have a Flyzone Cessna 182 Skylane Select Scale that I know I am going to be nervous putting her up the first time. Although I probably won't be as nervous as the first time I put my HZ Super Cub up, my second plane overall. Being nervous is just being human. On the other hand, I know two fellows that have bought planes and are terrified to fly them, who knows why. Anyway, get out there an fly, if you crash, so be it. She'll fly next time.
Hide Signatures
       Post #: 19
RE: Pre-Maiden Jitters - 8/21/2012 7:29 PM
countilaw
Score: 219
Status: offline
No,  If I meant to say ,  " everyone that claims to be self taught are liars"   I would have said it in the same paragraph.        There were three questions asked,  how long,  how much and how many .
The next paragraph  is a warning and a fact.       This is the internet,   you can't believe everything that you read.      Is there anyone here that will disagree with that?
Frank
Hide Signatures
(in reply to Chucksolo69)
       Post #: 20
RE: Pre-Maiden Jitters - 8/21/2012 8:52 PM
Chucksolo69
Score: 169
Status: offline
You are right of course. But believe me, there are many people who fly RC that have never had formal instruction and do just fine. It just rubs me the wrong way when people say it isn't possible to learn to fly RC without formal instruction.............poppycock.
Hide Signatures
       Post #: 21
RE: Pre-Maiden Jitters - 8/23/2012 3:19 AM
JollyPopper
Score: 158
Status: offline
We have kind of an unwritten rule in our group. Somebody else checks the plane, especially for controls going the correct direction, and then somebody other than the owner flies it the first time. The owner of the airplane obviously has to trust the guy flying the plane but it seems that by the time the owner of the plane takes the controls, the jitters are pretty much gone. Sometimes that happens in the middle of the first flight, sometimes not. But we've been pretty good at picking up on reversed controls and successful maidens because someone who is not emotionally vested in the plane checks it and flies it first.
I realize that is not going to work with all personalities, but it is working in our small group. Bear in mind that ours is a very small group, only about a dozen fliers, and we are pretty close knit.
"In theory, there is no difference between theory and practice; In practice, there is"
Hide Signatures
       Post #: 22
RE: Pre-Maiden Jitters - 8/23/2012 5:15 AM
countilaw
Score: 219
Status: offline
quote:
ORIGINAL: JollyPopper
Now that's  proper technique.          You guys sound like you've got a plan.
Frank
Hide Signatures
(in reply to JollyPopper)
       Post #: 23
RE: Pre-Maiden Jitters - 8/26/2012 4:31 AM
adamle
Score: 101
Status: offline
 I make a preflight checklist. Things like balance cg, check throws, batteries charged and about 20 other items. It helps me feel confident that my plane will not surprise me. Then I take a few deep breaths.
Hide Signatures
       Post #: 24
RE: Pre-Maiden Jitters - 8/26/2012 1:35 PM
jetmech05
Score: 133
Status: offline
There's no way someone other than me is going to fly my new airplane....you can look her over if you want to...flying her is my job
Hide Signatures
(in reply to adamle)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.895RCU1
