Glow engine woes...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Glow engine woes...
Page: [1] 2 3   next >   >>
Login
Glow engine woes... - 8/19/2012 7:37 PM
acerc
Score: 221
Last Login: 5/23/2013
Status: offline
A friend has asked me a question that I can't answer. How about you guy's. The engine is a Magnum 120 4stroke. When started upon removal of the glow plug the rpm's increase. What would cause this?
_____________________________
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 1
RE: Glow engine woes... - 8/19/2012 8:16 PM
Cobra1
Score: 100
Last Login: 5/22/2013
Status: offline
The only thing I can imagine is that the timing changed for the better. When using the glow battery the timing was too far advanced, pre ignition. When removed it retarded and more energy used to push piston down instead of trying to keep it from coming up.
Hide Signatures
(in reply to acerc)
       Post #: 2
RE: Glow engine woes... - 8/19/2012 10:02 PM
jeffie8696
Score: 120
Last Login: 5/15/2013
Status: offline
Glow heat affects timing, if the glow plug is too hot the ignition will occur too soon and lower the power output. This can also be affected by higher nitro and higher compression. With the glow igniter attached you are artifically making the glow plug hotter.
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
(in reply to Cobra1)
       Post #: 3
RE: Glow engine woes... - 8/19/2012 11:00 PM
Cub Flyer Fresno
Score: 115
Status: offline
Hey guys, I'm the friend acerc is referring to.   I'll give you a little more information:
First of all, as stated, I have a Magnum FS-120.  It will only run at idle with the glow igniter attached.  It runs well at around 1/2 throttle and higher, but below that, will die.  At the lower RPM's, when the igniter is removed, is when the RPM's increase.  I've tried opening the low speed needle until it was too rich and would load up quickly.  I leaned it up until it was too lean to run at idle.  Right in between is where it runs best, but again, with the igniter attached.  There is no happy medium without it.
I agree with both Cobra1 and jeffie8696.  That's the only thing that made since as to why it would speed up.  However, it won't keep running unless I'm at 1/2 throttle or higher.  I have considered running with an On Board Glow, turning on under 1/2 throttle, but I'd rather fix the problem instead.
So, with that said, does anyone have any other suggestions?
By the way, thanks Ace for getting this started!
Take care,
David
Cub Brotherhood #65
Hide Signatures
(in reply to jeffie8696)
       Post #: 4
RE: Glow engine woes... - 8/20/2012 12:23 AM
P-40 DRIVER
Score: 105
Last Login: 2/14/2013
Status: offline
Check your cam timing, your valve lash and the Oring at the intake manifold to carb for proper seating, also check your idle mixture screw. Probably cam timing, mark should be inline with pushrod tubes or straight down depending on engine at TDC. Put a fresh OS F plug and try different fuel also. The Magnum 120 will idle all day at 2000 rpm if properly tuned and broke in and turn 8000-8500 rpm peaked with MA 15/8 prop.
Hide Signatures
(in reply to Cub Flyer Fresno)
       Post #: 5
RE: Glow engine woes... - 8/20/2012 12:30 AM
Cub Flyer Fresno
Score: 115
Status: offline
Thanks P-40.  I'm running the MA 15x8 now and the same fuel mix as the guy who owned it before me.  He recently examined the engine himself, so I'll relay this info to him to see if he checked all that before I tear into it.
Hey, sorry Ace!  Didn't mean to hijack your thread!
Thanks again!
David
Cub Brotherhood #65
Hide Signatures
(in reply to P-40 DRIVER)
       Post #: 6
RE: Glow engine woes... - 8/20/2012 12:50 AM
freakingfast
Score: 118
Last Login: 2/28/2013
Status: offline
This could just be a bad glow plug. The plating on the element is gone or the element is contaminated. As already suggested, try a fresh OS "F" plug before anything else.
Oooh eee oooh ah ah(the crowd) ting tang walla walla bing bang!(the plane crash)
Hide Signatures
       Post #: 7
RE: Glow engine woes... - 8/20/2012 12:54 AM
Cub Flyer Fresno
Score: 115
Status: offline
Oh, forgot to say I already tried that.  It ran the same as with the original plug.  And I did get the OS "F" plug as well.  Guess it wouldn't hurt getting another just in case it was two bad plugs in a row.  Hmmm...
Cub Brotherhood #65
Hide Signatures
(in reply to freakingfast)
       Post #: 8
RE: Glow engine woes... - 8/20/2012 2:09 AM
Hobbsy
Score: 650
Status: offline
When the timing changes for the better when the glow power is removed, that is an indication that it is too lean. If it were too rich it would slow upon removing the glow power. Try richening the LS needle about .5 turn, then peak the HS needle and see how it does. Then go back and reset HS needle for your normal setting.
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
       Post #: 9
RE: Glow engine woes... - 8/20/2012 2:13 AM
Cub Flyer Fresno
Score: 115
Status: offline
Thanks Hobbsy, I'll give that a try... in a day or two.  I'll let you know what happens.
Cub Brotherhood #65
Hide Signatures
(in reply to Hobbsy)
       Post #: 10
RE: Glow engine woes... - 8/20/2012 3:27 PM
KW_Counter
Score: 141
Last Login: 5/19/2013
Status: offline
Does the original owner live near you?
I had a similar sounding problem after moving from the
Imperial Valley, below sea level, to Lake County, above 1,000 feet.
When I switched from 10% nitro to 15% the problem was solved.
Good Luck,
KW_Counter
Hide Signatures
       Post #: 11
RE: Glow engine woes... - 8/20/2012 3:48 PM
Cub Flyer Fresno
Score: 115
Status: offline
Thanks KW_Counter.  Yes and no, but the important part is we live at pretty much the same elevation.  However, the blend of the fuel (he mixes his own) may have something to do with it.  I'll check to see what % this is and maybe try some 15% out just to see if that does the trick.  A hotter burn just might work, makes sence anyway.  Once again, I'll let you know.
Take care,
David
Cub Brotherhood #65
Hide Signatures
(in reply to KW_Counter)
       Post #: 12
RE: Glow engine woes... - 8/20/2012 7:01 PM
Cub Flyer Fresno
Score: 115
Status: offline
I checked with the original owner, it is 15% fuel.  We're now thinking that since it had been sittting awhile, maybe the intake O-ring could be bad.  I may get a kit just to fix that.  Does anybody know where I could get an O-ring other than from Global Services (not that they're bad, just like to find a local source)?
David
< Message edited by blw -- 8/21/2012 12:20 AM >
Cub Brotherhood #65
Hide Signatures
(in reply to airraptor)
       Post #: 13
RE: Glow engine woes... - 8/20/2012 7:23 PM
jeffie8696
Score: 120
Status: offline
Auto parts store?
As an aside, I am not a huge fan of Magnum engines but I have a 52 FS on my Escapade and have flown it for several hours now with great success.
It took a long break in but it runs like a champ now. It lacks the refinement of my Saitos but it also lacks the price tag.
I purchsed a Saito 62 to replace it but to tell the truth I am so happy with the Magnum 52 that I am dragging my feet swapping it out (that and I am a lazy SOB lately).
I landed some 30% nitro fuel for cheap, and the 52 LOVES it  !!
Hide Signatures
       Post #: 14
RE: Glow engine woes... - 8/20/2012 9:15 PM
Cub Flyer Fresno
Score: 115
Status: offline
From what I've heard (may not be true) the Magnum will run on straight nitro, not sure about that!
I would agree with the price tag!  And, a side note, from what I've heard (here we go again) Magnum is made by OS!  (Thanks for that info Ace!)
Anyway, I'd like to eventually replace this with a gasser to save money in the long run.  But for now (until I can save up the money, maybe in a few years ) I'll keep this one running.  Or I guess I should say "get this one running"!
Take care,
David
Cub Brotherhood #65
Hide Signatures
       Post #: 15
RE: Glow engine woes... - 8/20/2012 9:44 PM
landeck
Score: 137
Status: online
Magnum Engines are clones of older OS engines made in China. I just went blank on the manufacture-old age. They are good engines and are great for the price.
Bruce
Bruce L. AMA# 54227
Ultra Sport Brotherhood #15
Hide Signatures
       Post #: 16
RE: Glow engine woes... - 8/20/2012 11:19 PM
P-40 DRIVER
Score: 105
Status: offline
You can use high temp gasket sealent ( the orange stuff) if you don't want to fiddle with getting the carb Oring. worked like champ on my 120.
Hide Signatures
(in reply to RCPAUL)
       Post #: 17
RE: Glow engine woes... - 8/21/2012 12:23 AM
blw
Score: 655
Last Login: 5/21/2013
Status: offline
I deleted a childish comment and had to also delete a couple of reasonable replies since they had quotes of it.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
       Post #: 18
RE: Glow engine woes... - 8/21/2012 6:01 AM
Ernie Misner
Score: 130
Status: offline
Did you mean you heard a Mag. could run on straight methanol? (not nitro!)
They slow down when you remove the glow driver if it needs more nitro. So speeding up could indicate needing less nitro possibly.
Hide Signatures
(in reply to blw)
       Post #: 19
RE: Glow engine woes... - 8/21/2012 6:39 AM
jeffie8696
Score: 120
Status: offline
There is no reason it wont run on FAI fuel, but how well is another story.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 20
RE: Glow engine woes... - 8/21/2012 8:28 AM
heavydriver
Score: 100
Status: offline
The manufacture of Magnum , ASP and some Thunder Tiger is Sanye Motors. These motors are great sport motors that put out plenty of power for the average guy. The designer of these motors worked for OS and they had an ugly parting of ways so the story goes. He took his designs to Sanye as a parting shot. I have quite a few of these motors and i've found that they like 10-15% nitro with some castor (Omega) and a good quality OS F plug. They run like clockwork on that combo. Some guys like to bad mouth them and say they're no good and should buy OS only. Ya, the machine finish is not OS quality, but that cosmetic stuff doesn't make any difference how they run if they're set up correctly. -sorry for bad sp and grammer-new ipad user
Hide Signatures
       Post #: 21
RE: Glow engine woes... - 8/21/2012 10:22 AM
pe reivers
Score: 646
Status: offline
apart from the plug heat range and mixture issues, idle also may be unreliable when the carb is not clean, down around the needle tip.
15% nitro fuel should give reliable idle unless the engine is mounted inverted. In that case adding idle glow will allow lower idle rpm.
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to heavydriver)
       Post #: 22
RE: Glow engine woes... - 8/21/2012 1:27 PM
Sport_Pilot
Score: 233
Status: offline
quote:
I wouldn't think someone would pay monthly storage charges unless there was quite a bit of valuable items inside.
That is why the guys running low nitro will often use very hot glow plugs.  Unless it was made for no nitro then you may have to use a cool plug.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 23
RE: Glow engine woes... - 8/21/2012 1:30 PM
Sport_Pilot
Score: 233
Status: offline
No, Sanye simply bought a few OS engines and measured all of the parts and did some hardness testing, etc. and copied them.  The story you mentioned was that the designer went to Thunder Tiger.  That company then made original designs that were very similar to OS but not exact copies, thus many parts do not fit.
Hide Signatures
       Post #: 24
RE: Glow engine woes... - 8/21/2012 1:34 PM
Sport_Pilot
Score: 233
Status: offline
Most are good, but some I have, had  soft or brittle parts.  The metal is not as good as an OS.  The quality goes a little deeper than the finish.  Unlike others such as Enya, Fox,. a few Rossi models, and many gas models that have little finish work, some with an industrial look, but are actually made well.
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Glow engine woes...
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.969RCU1
