novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-ROAD ENGINE    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SCT Combo - RTR
Seller:  Callifas38
Details:   $100.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-ROAD ENGINE
Page: [1]
Login
novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-ROAD... - 8/19/2012 9:46 PM
roadrunner ss
Score: 100
Last Login: 5/23/2013
Status: offline
i have a project coming up real soon with on is better to get
The AXE Motor Rossi COBRA TRUGGY Model 223R25 specs are:
DISPLACEMENT: 4.1cc
HORSE POWER: 3.86 HP
RPM: 42800
BORE: 17.00 mm
STROKE: 17.40 mm
PORTS: 7 + BUSTER EXHAUST SYSTEM
CRANKSHAFT & TYPE: Æ 14 SG + INSERT
GLOW PLUG: TURBO
WEIGHT: 340 gr
vs
Medium sized image of the ROMA.25 engine.
Novarossi Roma .25 Truggy Engine
NN.ROMA.25
The Roma .25 truggy engine is the ultimate powerhouse to propel your 1/8 truggy at high speeds and blast out of corners like a buggy.
.21 vs .28 in a truggy has been a long debate with no clear winner, the .25 uses the best of both worlds making it the best choice available.
FEATURES:
• Light cooling head.
• 7 Port sleeve with booster ports.
• Large 25.8mm rear bearing diameter.
• Turbo type glow plug.
SPECIFICATIONS:
• Displacement: 4.04cc
• Practical Range: 6000 - 42,100rpm
• Bore x Stroke: 17.1 x 17.6mm
• Transfer Ports: 7
• Bearings: Steel Front & Rear
• Crankshaft: 14mm SG
• Carburetor: 9mm Slide Type, Plastic, Single A
_____________________________
IM JUST GETTING STARTED ON UR CANDY AZZ
Hide Signatures
       Post #: 1
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/20/2012 5:36 PM
Anthoop
Score: 121
Last Login: 5/22/2013
Status: offline
If you offered me either engine then I would choose the Nova.......I have no experience with either engine but base my choice on what I have read and the fact it is a Nova....oh and it looks pretty with that lowerd head.
I would post this question in the engine forum where "supertib" will see it, he has experience of the NR and maybe the Axe too.
Do we get an insight into your project? As you posted in the on-road forum then I guess the engine is not for a truggy. Dependant on what you are planning maybe the NovaRossi 28-7T or a Fusion X28?
When I die, I want to go in my sleep like my grandfather,not screaming
like the passengers in his car at the time.
Hide Signatures
(in reply to roadrunner ss)
       Post #: 2
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/20/2012 9:51 PM
roadrunner ss
Score: 100
Status: offline
alot of people telling me to go with a high rpms 21 engine
Hide Signatures
(in reply to Anthoop)
       Post #: 3
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/21/2012 5:18 PM
Anthoop
Score: 121
Status: offline
If we all had the same opinion the world would be a boring place.
The .21 vs .28 debate has been going on for years and there is no definative answer, some will say "the comparitive .21 will rev higher than the .28 thus reaching a higher speed" whilst others will say "the .28 has more torque enabling you to use a lower gear ratio....the faster you go the greater the drag".
Hide Signatures
       Post #: 4
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/21/2012 6:14 PM
HerrSavage
Score: 318
Last Login: 5/4/2013
Status: offline
From those two I would take the OS.. Easier to break in, cheaper, rep for reliability and ease of tuning, plugs are easy to come by, lots of pipes probably work well, etc.. I've read elsewhere of NR having crappy bearings..
Nitro > stamp collecting, watching grass grow, cleaning room, etc.. > electric.
Hide Signatures
       Post #: 5
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/21/2012 7:15 PM
roadrunner ss
Score: 100
Status: offline
so it better to get a 28 then
Hide Signatures
       Post #: 6
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/21/2012 7:53 PM
HerrSavage
Score: 318
Status: offline
Depends on the car and what you want to do..
Hide Signatures
       Post #: 7
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/21/2012 8:03 PM
roadrunner ss
Score: 100
Status: offline
I GETTING A JATO REAL SOON IN MY SETUP IS A 30/36 SOON TO BE 30/34 I NEED A MOTOR THAT GOING TO PULL THIS GEARING WHIT ON IS BETTER A 21 OR A 25 OR A 28
Hide Signatures
(in reply to HerrSavage)
       Post #: 8
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/23/2012 2:46 PM
supertib
Score: 302
Status: offline
my pick would be a modified Novarossi 28-7........... I have run and owned pretty much every worthwhile nitro engine oin the market, and this 28 is unlike any other 28 I have encountered yet.................it is not a punched out 21 like the other 28's, it is a dedicated build .28 with its own unique casing and connecting rod............The engine is larger in size then other 28's...which allows it to run a very long connecting rod to offset its long stroke.... what this does is reduces the rod angle which reduces the vibration on the engine..... Thw final result is this engine will rev out just like a .21, but has the monster power of a 28..........It is a 7 port sleeve design similar to a onroad design.......17.6 mm stroke and a 32.5 mm rod....in stock trim the engine has low timing, so its not overly powerful, however once the timing is brought up the engine becomes a monster unlike anything else I have seen...........
Neal Smith..owner Clockwork Racing Engines
Hide Signatures
       Post #: 9
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/23/2012 6:04 PM
Anthoop
Score: 121
Status: offline
Any idea if there internal dimension differences between the 528 and the 28 7T crankcase Neal...and would you have any sleeve pictures there please? I can see that the crank/rod/piston/button are the same between the 2.
Hide Signatures
(in reply to supertib)
       Post #: 10
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/23/2012 6:40 PM
roadrunner ss
Score: 100
Status: offline
i hear alot about that novarossi 28-7 alot of people say it a beast
Hide Signatures
       Post #: 11
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/23/2012 11:17 PM
supertib
Score: 302
Status: offline
quote:
ORIGINAL: Anthoop
it is all the same as the 528 except the sleeve design...the 28-7 has larger ports and more port volume..........
Hide Signatures
       Post #: 12
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/24/2012 2:58 PM
roadrunner ss
Score: 100
Status: offline
i seen that video of the novarossi 28-7 that thing is powerful in fast got to get one of those
Hide Signatures
       Post #: 13
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/24/2012 3:28 PM
Rac3rX
Score: 112
Last Login: 5/10/2013
Status: offline
Nova is a Monster, every one I see is nutso.
Not going with your Mod ZR30X or RB mods engine you have on the way. Man you must be stacking up on modified engines by now and going for more.
BTW, you said you had a RBModified 28 ordered, what engine did you get modified by RBMods? Is it a Picco? With a LRP, & Nova a Mod Picco would make a great trio to compare performance. Id love to see the 3 swapped in the same truck for direct comparisons, are you planning to test all 3 then run the fastest one? I have my money on the Nova.
Hide Signatures
       Post #: 14
RE: novarossi roma 25 vs AXE ROSSI 25 COBRA TRUGGY OFF-... - 8/24/2012 5:56 PM
Ttowntoolman
Score: 159
Status: offline
Neals mod 28-7 is a BEAST of an engine........nothing else close......you never could imagine this kind of performance from one of these lil engines.
Hide Signatures
(in reply to Rac3rX)
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.172RCU1
