HK-450GT CCPM Alloy T-Rex compatible - Part III    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> HK-450GT CCPM Alloy T-Rex compatible - Part III
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/19/2012 10:19 PM
ahamay
Score: 105
Last Login: 6/19/2013
Status: offline
This is a continuation from part II thread which can be found here -> http://www.rcuniverse.com/forum/m_11007850/anchors_11198232/mpage_116/key_/anchor/tm.htm#11198232
_____________________________
Tarot 500 FBL ZYX-S, Tarot 450 PRO V2 FBL ZYX , Tarot 450 PRO V2 FBL ZYX-S , MCPx V2, Nano CPx
Hide Signatures
       Post #: 1
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/19/2012 11:08 PM
ahamay
Score: 105
Status: offline
This was my last post from the old part II thread which is not working properly again.  Thought I would post it again.
Yes the phoenix organised sim session on saturday was cool, but it would have been much better if I had a microphone.  I will for next time.
Well I have some paypal credit from the parents as it's my birthday next week so the 450GT has been officially retired.  I have a new build starting soon.  I've ordered the kit but still deciding 100% on other bits for it.  This is what I have so far:
Tarot 450 PRO V2 FBL (I will have two of them, slightly different spec)
  • Turnigy Plush 40amp
  • Turnigy HeliDrive SK3 Competition Series with 13t
  • Hitec hs-5065MG or Ino-Lab 202hb cyclic (have not decided on these yet)
  • Align DS520 rudder
  • Orange rx 6 channel - had no problems with this on the GT
  • Tarot ZYX v1 - also from the GT
Jonesy
Hide Signatures
(in reply to ahamay)
       Post #: 2
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/19/2012 11:11 PM
hugj
Score: 100
Status: offline
yes thanks this one loaded quick i hope everyone will follow
  Hugh
Hide Signatures
       Post #: 3
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/19/2012 11:32 PM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: hugj
  Hugh
Yeah, looks good from here as well.  Think that's done the trick again.
Jonesy
Hide Signatures
(in reply to hugj)
       Post #: 4
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 1:30 AM
mnemennth
Score: 100
Status: offline
Dangit - I broke the internet again. Should I get some superglue?
quote:
ORIGINAL: ingleburn
Well yesterdays sim time did me the world of good.
went out this morning and had a great time flying a lot smoother and getting further away.
The dreaded right turn curse returned though when I started flying faster and you could hear the tail blades protesting.
Time to sit down and check everything over again but I did notice a bit of slop between one grip and the hub so for a start Im going to replace it with this. www.rc711.com/shop/metal-tail-holder-set-for-alztrex-450-sport-p-4558.html
Other than that might play around with the software and see if I can get it sorted out.
One other thing I just thought of was Im using these tail blades. www.hobbyking.com/hobbyking/store/__14935__450_Size_Heli_White_Plastic_Tail_Blade_pair_.html
Wonder if I should try a pair of the stock ones and see if it makes a difference.
burn-
The tailrotor you linked to is a 450Pro style unit. The blades you linked to are also 450Pro; length from pin to tip should be +/- 63mm. These blades have approx 40% more surface area than the V1/V2 tapered style, most of it at the tip, and they aren't feathered. They are gonna howl like a SOB in comparison under heavy loading, because they're moving almost twice as much air. This can cause your belt to skip too, if you've gotten lazy about checking belt tension, which can also make an obnoxious racket. Don't ask how I learned THAT lesson.
If you're going to use the 450Pro tailrotor, make sure you use a tail servo rated for at least 1.8KG pull; between the larger blade area and the increased rotational massof the 450Pro tailrotor's gyro weights, that tail needs a lot more torque to push it around. Align used a DS520; it's rated 1.9/2.5KG at 4.8/6.0V.
[EDIT]
Looking at the photo, I can't say the CNC quality of that particular tailrotor looks any better than what I've gotten from LeadersHobby; they have a complete Pro tail for $4.99 here: https://www.leaderhobby.com/product.asp?ID=9394001220449 Unless you're set on that color it seems like a better deal, and they're both coming from China. Better hurry, though; only 2 left in stock. Myself, I'd just replace the bearings unless the rotor I had was already damaged.
On a side note; did you see that Goblin-clone canopy/fuselage kit? http://www.rc711.com/shop/alzrc-devil-450-fast-fuselage-converter-kit-p-6590.html
Good hunting,
mnem
I forgot.
< Message edited by mnemennth -- 8/20/2012 4:05 AM >
*DH9118/HK450GTV2/Hausler450V2/EXI450Pro/HDX450/S107G/V911/GeniusCP/TGY-9X/DEVO-7*
Hide Signatures
       Post #: 5
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 1:42 AM
pushinoldrc
Score: 105
Status: offline
quote:
ORIGINAL: hugj
  Hugh
Looks ok from here also.
Carl Goldberg Ultimate 10-300 Brotherhood. #23
Hide Signatures
(in reply to hugj)
       Post #: 6
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 1:52 AM
ahamay
Score: 105
Status: offline
Does anyone use a servo tester, or have a recommendation for one ?  I know some radios have servo testing functionality, mine doesn't.  I want to be able to run servos on the bench for a time period before installing them.
Jonesy
Hide Signatures
(in reply to pushinoldrc)
       Post #: 7
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 4:05 AM
Ddaddy
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
Jonesy
The Tarot ZYX programer does an amazing job IMO.  You can stress them by automaticallyu running them as well as test the speed (this is how I found out my 510's don't perform to spec :  ( but my 65's do better than spec ;
So if you have a zyx, a great addition, if you don't have a fbl, then a great time to get a zyx!
Cheers,
Ken
MCX, MSR, BOL, Blade SR, franKENblade 400, FBL 450, mCPX, FBL 500, AXN FPV
Hide Signatures
       Post #: 8
mnemennth
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
Jonesy
Jonesy -
What are you looking to do? Are you just looking to do some cycled sweeps to burn in the servos, or are you looking to measure servo speed to make matched sets?
If the former, the HK & Turnigy cheapies work well; I have both.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14774
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11780
Try & catch them on a swarm at RC International ; I got both mine half price that way.
If you want to do actual speed tests and accuracy testing, I haven't seen anything out there that looks as promising as the AEO-RC Servo Doctor; it will probably be my next bit of kit since I'm looking into going FBL and will want to make matched sets. I was hoping to find it back in stock at HobbyPartz since they show it on sale; but it's been OOS for a month now.
http://www.hobbypartz.com/88e-aeds400-s1-servotester.html
Here'es the link to the manual:
http://www.aeorc.com/download/manual/Electronic_Product_User_Manual/S1_Dr.Servo_Manual%20%28ENG%29.pdf
Hey, it looks like HK has it rebranded here: http://www.hobbyking.com/hobbyking/store/__10572__Hobby_King_S1_Servo_Doctor_w_Gyro_Sensor_.html
Not as cheap as HobbyPartz, but I suspect that once they have it back in stock the price will go up again anyways.
mnem
What, no pickle?
Hide Signatures
       Post #: 9
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 4:08 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: Ddaddy
quote:
ORIGINAL: ahamay
Jonesy
Cheers,
Ken
Yeah, I have zyx v1 and zyx-s, but not the programmer box.
Hide Signatures
(in reply to Ddaddy)
       Post #: 10
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 4:10 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: mnemennth
quote:
ORIGINAL: ahamay
Jonesy
Jonesy -
mnem
What, no pickle?
Dont really care for speed testing etc... just want to run up new servos to make sure they are not going to fail in the first 5 minutes.  Rob had a radio, i think it was a JR that ran the servos contoniously at different speeds or random to run them in and test them etc.
Hide Signatures
(in reply to mnemennth)
       Post #: 11
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 5:35 AM
mnemennth
Score: 100
Status: offline
I would recommend the Turnigy 760HV then; the HK one is single speed on the continuous sweep function and only good to 4.8V. The plastic printed sheet wrapper is pretty cheesy and it falls off all the time; it's only worth getting if you can pick it up on the swarm for $2 like I did.
I got the Turnigy for a robotics project; It will run on up to 3S input for testing HV servos, plus it has variable continuous sweep cycle speed and 4 buffered signal outputs. Plus, its 1520uS/760uS switchable pulse width is ideal for testing higher end digital servos. Just remember it sends out the same voltage to the servos as you power it with, so don't plug a 3S pack into it and test 6V-rated servos; you'll let the magic smoke out of them.
mnem
Tested. Rejected. Married.
Hide Signatures
       Post #: 12
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 6:24 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: mnemennth
mnem
OK, thanks I'll check it out.
Hide Signatures
       Post #: 13
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 8:04 AM
Flying Fiz
Score: 100
Last Login: 5/30/2013
Status: offline
Hi Jonsey,
The new 450 project sounds good.
I can recommend this servo tester;   http://www.hobbyking.com/hobbyking/store/__17047__Turnigy_Digital_Anolog_Servo_Tester_.html
I also note that Hobby King now sell a 550 size heli, is anyone going to be the test crash dummy, it may be OK!!! Maybe time for you to get a 500 size heli in the air Jonsey, you will love it!
Hi All,
I haven't flown anything (except the 130X in the backyard) for 2 weeks due to very blustery conditions in Sydney for last few weekends. When I go out now I want to fly both helis and planks, and the planes are more susceptible to wind than the helis.  My 130X continues to power on, and I have put it into a treee and the ground, both full bore, no damage or issues whatsoever, just pick up, check over and fly again!
I've also started riding on the weedend with a couple of mates (non powered variety), to keep fit without ruining the joints jogging, so I'm now officially a MAMIL.
Also work is very busy, I'm bogged down doing some M&A activities, lots of long hours!
best to all
Phil
Lots of Planes, (no trains or automobiles), and lots of helis and not enough flying time!
Hide Signatures
       Post #: 14
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 8:08 AM
ahamay
Score: 105
Status: offline
Has anyone tried these yet ?  They look like an ideal rudder servo:
http://www.hobbyking.com/hobbyking/store/__22687__TGY_306G_Ultra_Fast_High_Torque_MG_Digital_Alloy_Cased_Servo_3kg_06sec_21g.html
Hide Signatures
       Post #: 15
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 8:17 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: Flying Fiz
Hi Jonsey,
Hi All,
best to all
Phil
Thanks for the link, I'll check it out as well.
I'd love to have a 550 but at this point I can't afford to keep a unit like that in the air as well as a 450.  I could probably just have one 550 and no 450's but who wants just one heli   One day it will happen.  If I have two of the same Tarot Pro's then at lease I only need to have the same spares for both.
Im ordering a few batteries for my mcpx which I have not flown for about 2 months as all my nanos died.
My mate got to fly his 130x and he loves it.  He mentioned it had a bit of wobble when decending but it holds very solid. The guy at the local hobby shop here rekons the tail blades on some of them are not balanced properly which is causing a vibration in some units.
The weather has been crap here as well the last week or so.  I've been busy at work as well and with all 3 of my birds down it's good timing.
Jonesy
Hide Signatures
(in reply to Flying Fiz)
       Post #: 16
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 9:28 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: mnemennth
quote:
ORIGINAL: ingleburn
burn-
[EDIT]
Good hunting,
mnem
I forgot.
You got me thinking thats for sure.
The new tail rotor and grips didnt fix the problem as it was the same today after another 3 flights.
Its really protesting doing right turns.
Checked the belt tension and its fine, no slipping at all.
So that leaves me with your other suggestions. I have a new stock tail setup and will replace the cheap HK bearings with new ones and put the stock blades back on as well.
If that doesnt fix it then looks like the DS420's arent up to the task and will try a 520.
If thats the case Im stuck with 2 useless servos as the pro has one on it as well
Or maybe Ill just maiden the pro and see if it suffers the same.
@ Jonesy. The new thread is loading a lot quicker. Like the specs for the new pro.
@ Phil. Yeah the weather has been terrible but Ive got more flying in the last week than Ive had for months.
Hide Signatures
       Post #: 17
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 9:44 AM
Kozzy_98
Score: 100
Status: offline
About the TGY-306G servo, im gonna place an order from HK for glue and various other bits and pieces for a scratch built quad. I have also been thinking about the servo, and I will be sure to tell you how it goes...
Helis: HK450GT - Typhoon 2215+Spektrum AR6200X, HK450G/MT - Typhoon 2218+Orange6chRX, MCPX
Hide Signatures
(in reply to ingleburn)
       Post #: 18
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 11:18 AM
hugj
Score: 100
Status: offline
Off to work thismorning not much flying yesterday maybey this week if weather permits
Hugh
Hide Signatures
(in reply to Kozzy_98)
       Post #: 19
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 1:30 PM
Edmund2
Score: 100
Status: offline
Hi guys back in the modern world again. Did get some time to fly the mcpx and it was a joy doing so. Had to make some repairs to the canopy after a few hard landings but it is still flying great.
Have a great picture (5.8Meg in size) of my son's BOL making a crossborder flight - suppose it can officially be considered an international air space violation-  from the Namibia to the  Angola side of the river. Did not land it as any perception problem may have caused it to topple over on the grass 150 meters away on the other side even if I had the bino's on it most of the time. We did a range test before we tried it and had a full lipo in it.  We were about 25 meters higher in Namibia and on the way back power had to be increased constantly to get the lift. Likely the first BOL to fly in Angola but can obviously not confirm that.
Edmund
Esky Belt CP V2, Esky Belt CP V2 CX, BIG Lama, Ultimate Big Lama, Lama 4, DX6i, Align TREX 550E, Blade mCPX
Hide Signatures
(in reply to hugj)
       Post #: 20
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 4:18 PM
Ddaddy
Score: 100
Status: offline
quote:
ORIGINAL: Edmund2
Edmund
Welcome back.  Sounds like you had a blast!
Hide Signatures
(in reply to Edmund2)
       Post #: 21
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/20/2012 8:16 PM
mnemennth
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
Jonesy -
That looks suspiciously like the MKS DS95 I was drooling...err, looking over when RikeyBob first got me thinking about the FBL thing...
http://www.mksservosusa.com/product.php?productid=5&cat=6&page=1
Specs are suspiciously similar too. I wonder if it's a clone, a rebrand, or if HK is just buying the ones that don't quite meet MKS standards. I see it comes up at $21.77 if I wait... *wibble*
[EDIT]
Uh-Huh. And here's the rebranded MKS DS92A, which are highly recommended as FBL Cyclic Servos... $22.23 if I wait. *Wibble-ibble*
http://www.hobbyking.com/hobbyking/store/__24764__TGY_306G_HV_High_Voltage_Ultra_Fast_High_Torque_MG_Digital_Alloy_Cased_Servo_3_7kg_05sec_21g.html
And here are the rebranded wing servos:
http://www.hobbyking.com/hobbyking/store/__23340__Turnigy_TGY_777MG_Alloy_Case_Digital_Slim_Wing_Servo_Metal_Gear_5_5kg_10sec_23g.html
http://www.hobbyking.com/hobbyking/store/__23341__Turnigy_TGY_778MG_Alloy_Case_Digital_Slim_Wing_Servo_Metal_Gear_5_5kg_10sec_23g.html
Good thing my credit cards are already maxxed out; I'd be looking at a FBL rebuild on my HDX450. And maybe a new scratch-built EDF Jet with gyro too...
Hi Jonsey,
(SNIP)
best to all
Phil
Phil -
Have you used the Speed Test function on that unit? How does it monitor the arm motion to verify actual speed?
Hmmm... I wonder if it monitors current draw; that would at least tell it when the servo stops driving the motor because it THINKS it has arrived at 60°. That doesn't necessarily mean it actually HAS traveled that far or that fast though...
[EDIT]
quote:
ORIGINAL: ingleburn
Hmmm... How's your headspeed? If you're running slightly high pitch/low headspeed, the servo's gonna be pushing full pitch on the tailrotor, but still unable to counter the mainblades. Sure, you'll be able to get it up in the air, but you won't be turning the tailrotor fast enough to do its job, even at max pitch. Also, when you say it's "protesting" you mean a lot of noise but it turns OK, or both not wanting to turn and making lots of noise? I'd also check my slider travel on the tail rotor, make sure you have your limits set correctly on the gyro so it's not bottoming out. This can make your servo complain, though I don't know that I believe it would be loud enough to hear over the rest of the heli...
mnem
*DANGER!!!* Engineer thinking *DANGER!!!*
Click to see fullsize image.
Click for fullsize
< Message edited by mnemennth -- 8/20/2012 9:56 PM >
Hide Signatures
       Post #: 22
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/21/2012 12:20 AM
rikybob
Score: 105
Status: offline
Hiya Kidz!
Hated that I missed the Phoenix party but really enjoyed my five day camping/boating event!
As I was reading I laughed at the obviated point that Jonesy the IT guru couldn't scare up a mic. Sometimes comedy writes itself!
The RC711 Goblin clone stuff was interesting!
The HK550 looks cool but I am not into the flybarred heads anymore.
I have to say, the 550 size is really optimum in my world, when you step up in size to the 600 EVERYTHING is more expensive!
Off weekends for the next three weeks and intend to enjoy every one of 'em!
Prolly slip out to the flying club Thurday!
All the best!
b
PS Welcome back to the real world Edmund!
Align 500CF FBL, MCP X BL, MQX & DX7, Gemini 600 Cat, Swamp Dawg Airboat, Nirvana II, Dumas Big Swamp Buggy, Slow Stick!
Hide Signatures
       Post #: 23
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/21/2012 12:58 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: Kozzy_98
I just ordered one of these on a  buddy code for $18.54. I was going to get another ds520 align but this is 1/3 the price and all reports I've read it's a solid unit, plus I won't be buying any more align servos.  I'm not happy with the metal they are using for the gearsets on the 410/415's.  The 520's I think are ok as they are not mg.
Jonesy
Hide Signatures
       Post #: 24
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/21/2012 1:17 AM
ahamay
Score: 105
Status: offline
2 New noisy gassers available in Phoenix update (20/8/12)
Phoenix R/C 4 updates available now
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
