RE: HK-450GT CCPM Alloy T-Rex compatible - Part III    Gallery
Logged in as Guest
Users viewing this topic: Ddaddy
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> RE: HK-450GT CCPM Alloy T-Rex compatible - Part III
Page: <<   < prev  28 29 [30] 31 32 33 34 35 36 37   next >   >>
Login
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/4/2012 8:49 AM
ingleburn
Score: 100
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: ahamay
Everything on the nano is smaller including that spindle, it's very thin and easy to bend which is bad...but makes it easier to straighten it.
Are they as much a PIA to change. It drives me mad trying to get that small screw in.
Hide Signatures
(in reply to ahamay)
       Post #: 726
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/4/2012 9:03 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: ahamay
Much easier than mcpx, even though it is a lot smaller.  One end of the shaft has a d or flat side and the other end has a nut with the same flat spot.  They give you two plastic keyed tools that slide in the grips to undo it and tighten it etc.  The nut has a bit of rubber cement on it to stop it from unwinding.  I just used a small bit of hot glue.
The mcpx should have been like this with a nut.
_____________________________
Tarot 450 PRO V2 FBL zyx , Tarot 450 PRO V2 FBL zyx-s , MCPx V2, Nano CPx
Hide Signatures
(in reply to ingleburn)
       Post #: 727
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/4/2012 11:24 PM
ingleburn
Score: 100
Status: offline
Hi guys, went out again today to get some more practice with the MCPX.
Its getting easier with each battery and not so many dumb thumbs.
After 5 packs practicing inverted and flips I took the 450 up and struggled with it so called it a day before I broke anything.
Anyway this video makes up for my last attempt which was awful.
I see where Jonesy and Rob are coming from as its made harder by the fact that the tail wanders so another thing to worry about as if there isn't enough going on.
Broke the TX aerial at the end trying to be smart and catch it at the end. Serves me right but popped it back on and will have to order a new pin.
Hide Signatures
       Post #: 728
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/5/2012 5:40 AM
Edmund2
Score: 100
Status: offline
Thank you all for the "condolences" regarding me being grounded. Did a number of packs on the mcpx on Saturday and some muscle memory are returning. Will be watching Simon's vides tonight as I did not log in over the weekend to check posts. Perfect weather here today but all flying stuff at home.
Edmund
Esky Belt CP V2, Esky Belt CP V2 CX, BIG Lama, Ultimate Big Lama, Lama 4, DX6i, Align TREX 550E, Blade mCPX
Hide Signatures
       Post #: 729
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/6/2012 5:33 AM
ahamay
Score: 105
Status: offline
Had a great early morning flying session this morning before work.  Got all my packs done and even a few flights on the nano whilst the wind was dead calm.
Here's a Nano and a 450 flight as it's been a bit boring around here of late....
Hide Signatures
(in reply to Edmund2)
       Post #: 730
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/6/2012 8:01 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
http://www.youtube.com/watch?v=7z4La46ZLBQ&list=UU-LHgZeFvtPme6g4Ua07ajw&index=2&feature=plcp
http://www.youtube.com/watch?v=C8-7wAivuCE
Yeah its been really quiet in here. After the weekend it usually comes to life.
Nice flying Jonesy, comments on YT.  Youve nearly talked me into getting one.
Tracking shows my Tarot will be here tomorrow but I couldnt wait so I started the setup already. This is what a heli looks like without all the fancy bits.
Hide Signatures
       Post #: 731
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/6/2012 8:10 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: ahamay
Nothing like getting a head start .  Those 306g servos are great on the rudder, I have them on both of mine.
Hide Signatures
       Post #: 732
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/6/2012 8:37 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: ahamay
Im trying out the Inolab servos Simon uses on the cyclic. I wouldnt use the Align 415's again even if someone gave them to me.
These look interesting.  www.hobbyking.com/hobbyking/store/__23466__TGY_211DMH_Metal_gear_Coreless_Digital_Servo_w_Heat_Sink_2_3kg_10sec_16g.html
Hide Signatures
       Post #: 733
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/6/2012 11:57 AM
Rob2160
Score: 183
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: ahamay
Great vids and good info about the wobble in the Nano..
Today I picked up my 2nd Nano CPX  (need one for the road...)
Out of the box it was way out of blade tracking.. by at least 8 mm...
I swapped blades, tried changing sides and blade type, and even swapped each of the plastic blade linkages.. nothing fixed it..
Then I compared the two side by side and the new one had a good 1mm of play in the blade holders (IE the spindle - feathering shaft had not been tightened correctly)
I then discovered why they include two small plastic drivers.... it needed a full 360 degrees of tightening.. no play and the blade tracking is perfect..
1st Nano has over 100 flights and 20 hard crashes, 2nd now about 10 flights and nil crashes, almost no noticable difference between the two... (the 1st is down about 5% on power but makes no difference)
It is a super awesome little helicopter..
..... frakkin cylons...
Hide Signatures
       Post #: 734
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/7/2012 12:14 PM
rikybob
Score: 105
Status: offline
Hi all!
Another cold front pushes high winds into my area (on my day off.....grrrrrr!) so no flying today. Will see about tomorrow!
Ingleburn, Great viddys and great blather and enjoying the posts, in particular the "heli guts" post!
Jonesy, all the best on the upcoming "bub"!
All, I hope you are doing well and in good health! For those of us in the states the decision has been made and God Speed!
All the best!
b
Align 500CF FBL, MCP X, MQX & DX7, Gemini 600 Cat, Swamp Dawg Airboat, Nirvana II, Dumas Big Swamp Buggy, Slow Stick!
Hide Signatures
(in reply to Rob2160)
       Post #: 735
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/7/2012 12:27 PM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: Rob2160
I think my Nano is a bit down on power from when I first got it as well but the tail still holds right to the end of the pack no problems.  I tried the bullet blades on it the other day when I had it down at the field and it's not as nice doing the flips and stuff but it's a quick little sucker doing fast forward flight.  I was surprised that a small light heli like the nano could get up so much speed.
Hide Signatures
       Post #: 736
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/7/2012 12:32 PM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: rikybob
Hi
b
Thanks everyone for the well wishes for the pending child... it really is getting close and exciting now.  I've been trying to get as much flying in as I can before I have to ship all my helis over to Brian
This was my last pack at lunch time today...sorry no blather, but I"m really happy I've been able to transfer some of the things from the nano over to the 450.
Hide Signatures
(in reply to rikybob)
       Post #: 737
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/7/2012 6:41 PM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
quote:
ORIGINAL: rikybob
Hi
b
http://www.youtube.com/watch?v=Dzq1My7cJn8&feature=youtube_gdata
The only thing you have to remember is that the 450 isn't unbreakable like the nano.
Great flying though and I see youre letting it get closer to you all the time. You will be getting free hair cuts in no time.
In reply to your comment on YT yes I got my kit yesterday. And it really is a kit. Nothing is built except the head and tail and most of the screws I looked at were loose.
A good thing because at least you dont have to struggle to undo them only to loctite again. Quality looks great but havent checked the TT or main gear yet.
What I did find interesting was that it came with extra parts and some upgraded ones.
An extra set of canopy mounting pins and grommets and 2 sets of landing gear.
A new style main shaft with collar, Adjustable linkages, CF tail control rod and even loctite and grease.
The head, tail and swash look awesome as well. Very impressed and cant wait to start the build. Great set of instructions included.
Also tried out the Bluetooth adapter for the ZYX and connects to my tablet and phone great. No more wires.
Keep us all informed about the pending arrival and looking forward to all the OT discussions.
@ Brian. Welcome back and my voice is nearly gone so get out and fly so I can have a rest.
Hide Signatures
       Post #: 738
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/7/2012 9:02 PM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: ingleburn
That's good news re the extra and upgraded parts...sounds like they have updated the kit since my last one.  Collar on the mainshaft is the same but the CF tail control rod is new.
Yeah, there's no threadlock on anything wich is great, even all the balls on the swash have none...don't forget them.   You'll have fun building this one without any phillips screws to strip out.
Look forward to the maiden
Hide Signatures
       Post #: 739
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/7/2012 10:43 PM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
Did you use the thread lock that came with it or your own.
Seems a bit thicker than the stuff I'm using which seems better to me. Re the balls yeah I can undo them with my fingers.
Hide Signatures
       Post #: 740
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/7/2012 11:09 PM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: ahamay
No I've never used the threadlock or the grease they provided. I've always used my own loctite 243 (blue) on everything.  It's probably fine to use, but I would go with what you know.
Did you end up with the black one or the silver one ?  What colour canopy did you get ?
Jonesy
Hide Signatures
       Post #: 741
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/8/2012 3:06 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: ahamay
Jonesy
I got the black one and the canopy is like this one but the colors are a bit different.
Hide Signatures
       Post #: 742
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/8/2012 9:59 AM
ingleburn
Score: 100
Status: offline
Well the first night of the Pro build didnt go according to plan after this hit.  news.ninemsn.com.au/national/2012/11/08/18/13/hail-strong-winds-hit-western-sydney
Garage got flooded and water came through the ceilings in the bathroom and lounge but not to bad and all good now.
Might try again tomorrow.
Hide Signatures
       Post #: 743
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/8/2012 12:02 PM
rikybob
Score: 105
Status: offline
@ Ingleburn - Sorry to hear about the Wx! Glad to hear damage was minimal!
@ Jonesy - Looking forward to a package!!!
@ All - Going to slip down to the field in a few and fly the beast, come back home and wash/wax the other "beast" (the big ole camper)!
Hope all is well in YOUR worlds!
PS Hope to get some good out of frame viddy for ya!
PSS Scratch the flying today as wind is WHIPPING! Grrrrrrr
Hide Signatures
       Post #: 744
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/9/2012 11:15 AM
rikybob
Score: 105
Status: offline
Hmmmm???
Odd, I just got a note from AU post with a tracking number???
In a related story I swear I can hear a baby crying???
b
Hide Signatures
       Post #: 745
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/9/2012 11:20 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: rikybob
Hmmmm???
b
LOL... no such luck...yet.... post office is closed
Hide Signatures
       Post #: 746
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/9/2012 12:51 PM
ahamay
Score: 105
Status: offline
This guy has a death wish.....looks like he needs some expo lol
Hide Signatures
       Post #: 747
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/9/2012 1:02 PM
rikybob
Score: 105
Status: offline
quote:
ORIGINAL: ahamay
I think what's funny is, is he finally uses a helmet!
b
Hide Signatures
       Post #: 748
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/10/2012 12:34 AM
Ddaddy
Score: 100
Status: online
quote:
ORIGINAL: rikybob
quote:
ORIGINAL: ahamay
b
FINIALLY!  I found it on HK....order placed....hope it gets here before Christmas
MCX, MSR, BOL, Blade SR, franKENblade 400, FBL 450, mCPX, FBL 500, AXN FPV
Hide Signatures
       Post #: 749
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 11/10/2012 8:38 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: rikybob
Hmmmm???
b
Nope thats just Jonesy crying over his stalled RC heli career.
No point sending them to you anyway, I hear you have forgotten how to fly.
The Pro build is going slowly but surely. Up to routing the wires and it doesnt get any easier.
But the build has been without dramas apart from having to enlarge the elevater servo holes a fraction to line up the holes. It is a great kit.
Edit. I did replace the TT and one way bearing case with Aligns because they werent the best.
Hide Signatures
       Post #: 750
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.125RCU1
