RE: HK-450GT CCPM Alloy T-Rex compatible - Part III    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> RE: HK-450GT CCPM Alloy T-Rex compatible - Part III
Page: <<   < prev  39 40 [41] 42 43 44 45 46 47 48   next >   >>
Login
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/12/2013 4:32 AM
rikybob
Score: 105
Last Login: 5/19/2013
Status: offline
Mnemenenen,
What a joy!
Hope you get it sorted soon enough and don't have any axillary issues again!
My day was nice. I worked then off by mid afternoon was off. Looked at an
new" pontoon boat trailer that didn't fit my bill but, however put a new Rx in my Nirvana II sailboat!
I put in the AR6100e and it worked a treat!
Soon after we attended a "tractor pull" and watched "Blade Runner" on blu ray!
(sigh)
Work tomorrow (and perhaps a lil sailing)!
All the best!
b
_____________________________
Align 500CF FBL, MCP X, MQX & DX7, Gemini 600 Cat, Swamp Dawg Airboat, Nirvana II, Dumas Big Swamp Buggy, Slow Stick!
Hide Signatures
(in reply to Kozzy_98)
       Post #: 1001
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/12/2013 10:20 AM
Kozzy_98
Score: 100
Status: offline
Well I am now uploading my videos from today.
Just a question about the videos and codecs.. I edited one (added credits to and cut out a little) in Adobe Premiere Pro CS3. Original size of the file was 190MB, after rendering it was 1.37GB. If anyone does use Premiere Pro, can I have their rendering settings?
Everything is sloooowly uploading to youtube, should finish sometime tomorrow
Helis: HK450GT - Typhoon 2215+Spektrum AR6200X, HK450G/MT - Typhoon 2218+Orange6chRX, MCPX
Hide Signatures
(in reply to rikybob)
       Post #: 1002
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/12/2013 12:12 PM
sgbfly
Score: 100
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: Kozzy_98
There are several ways but this is the simplest.
Select your sequence
Go to File -> export -> Adobe media encoder
Adjust all setting to be like the attachment and your well on your way.  I'm very busy today but can help more tomorrow.
Simon
Click to see fullsize image.
Click for fullsize
FBL FTW!
Hide Signatures
       Post #: 1003
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/12/2013 12:43 PM
ahamay
Score: 105
Status: offline
Recieved the turnighy plush 40amp BESC on Friday and I"ve just run it up on the bench with a spare rx and spare motor to test the soft start and low and behold it's working great, so that's good news.
I just checked one of my helis that the soft start is not working on with the programming card and it's definately set to very soft.  Before I transplant it out of the heli, I'll try setting it back to defaults and set it up again.  Might just get lucky.
Jonesy
Tarot 450 PRO V2 FBL zyx , Tarot 450 PRO V2 FBL zyx-s , MCPx V2, Nano CPx
Hide Signatures
(in reply to sgbfly)
       Post #: 1004
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/12/2013 8:47 PM
Kozzy_98
Score: 100
Status: offline
Here are the videos!
Sorry about my speech in the maiden flight and how none of what I said made any sense! I was trying to make sure I didn't crash a maiden on camera
Hide Signatures
(in reply to ahamay)
       Post #: 1005
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/12/2013 9:25 PM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
Jonesy
Let me know how you go with the ones that dont work because neither of mine work.
Also what do you set your timing to? Mine are set to medium but not sure of the difference.
Hide Signatures
       Post #: 1006
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/12/2013 10:10 PM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: ahamay
Jonesy
Just transplanting the new one in and the old one out.  Stuffed around with all the settings on the old one, defaults..changed a few things, soft, instead of super soft etc...no go. The esc works perfect, except for the soft start, but it's too easy to strip a maingear without it imho so it's gone.
I'm running mine on the defaults low timing.  I tried middle and high way back when I was building the GT.  The motor ran hotter on high timing (or could have been coinsidence), but there was no noticable power increase between the three so i've left it on low and had no issues. If I had to take an uneducated stab in the dark I"d say there's no difference between the 3.
Hide Signatures
(in reply to ingleburn)
       Post #: 1007
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/12/2013 11:37 PM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: ahamay
Jonesy
Yeah Ive noticed my motor runs pretty warm on medium but if the soft start doesnt make a difference then maybe the timing doesnt either.
Im used to being careful when spooling up but its still a pain.
Took the Tarot out yesterday and it flys great again. Started playing with the gains and got them up to 45 and still no wobbles.
Dropped the tail gain to 68 as it was wagging coming out of right turns.
Time to read up a bit more on tuning. Simon has been giving it to me for making him try inverted and thinks its my turn.
Hide Signatures
       Post #: 1008
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/13/2013 2:26 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: Kozzy_98
[youtube]http://www.youtube.com/watch?v=Dowo_bZNt7M[/youtube
[youtube]http://www.youtube.com/watch?v=ma505i4BbO8[/youtube
[youtube]http://www.youtube.com/watch?v=ZdMjrbIbydU[/youtube
[youtube]http://www.youtube.com/watch?v=cc3AX9uBMfU[/youtube
Seems quite stable Kozzy.
Why dont you put a spectrum receiver in it and use the DX6i. That way you can set it up to have the same responses to stick input as the 450.
Might make it easier when you move between both of them. I know I struggle when I take the nano out as its really twitchy.
Hide Signatures
       Post #: 1009
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/13/2013 4:37 AM
Kozzy_98
Score: 100
Status: offline
Yeah, that sounds like a good idea.
Phil gave me a Orange 9ch FullRange DSM2 Receiver which I think would be suitable.
I took a few more onboard videos and there is a very noticable jello because I haven't balanced the props and motors yet, even though I have placed foam tape on the carrying shelf.
Still waiting on my 450 Parts from China, but I don't mind the wait as I have the quadcopter to fly
Hide Signatures
       Post #: 1010
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/13/2013 5:09 AM
mnemennth
Score: 100
Status: offline
Kozzy -
I've looked into the er9X firmware; I'm no stranger to flashing processors. I Even have a few MAX232 based TTL converters I've built over the years, and a SiLabs programming stick and an ATMEL programming shield from my development days. BUT... and this is a big but... I still don't understand enough about what I'm doing to figure out the mixing for the head, and from what I can understand reading the documentation, er9x DOES NOT have preprogrammed profiles for Heli or Elevon or V-Wing like the original firmware does.
ALSO... HK has recently stolen... err, borrowed that entire bit of kit from the er9x gang (It IS open-source, after all) and incorporated it into a new update to the 9X called the 9XR with ubgraded gymbals, which includes the usual hacks we've been doing on the 9X - LiPo battery, backlight, modular antenna connection in the modular RF bay, Futaba & JR trainer ports, as well as a pre-installed programming header and a modified er9x firmware. They're selling it with no RF module or RX for $50/$70 shipped; not a bad deal if you're already heavily invested in the er9x and/or SmartieParts ecosystem. If you're getting into it from startoff, you need to add $40-$60 for module & RX, $20 for the programming stick cuz HK NEVER has it in stock, and $10-$20 for a LiPo or sacrifice a 1000-2200 mAH 3S pack; it takes power off the balance connector to make that easy.
Once you get into THAT kind of money, I'm looking at a Devo6S or 8S with the Deviation firmware... it's color touchscreen, plus it binds to a dozen different brands of
RX now just via firmware, no modules required. :P Oh, and your programming interface? The mini-USB cable that came with the radio.
http://www.deviationtx.com/
Oh, hey... how do you balance your motors?
On my 450-sized motors, I'll typically run a new motor for a pack or two to get the bearings nice & loose; then, since they have a shaft that's long enough to reach both bearings, I'll turn the stator around and use its own bearings as the head to balance against. I then mark the top side & tape bits of 1mm lead solder between the magnets at that location until I get no discernable heavy spot. I then weigh the lead, mix up 1/4 gram or so of epoxy, cut out an equivalent amount of the lead, and epoxy the lead in place where it was taped previously. After it cures, I can typically get it dead-on by adding a few drops of epoxy to or cutting away from that mass with a Dremel and diamond bits. This process is time-consuming, but usually necessary with even some of the best name brand motors.
I dunno how I'd do it on a motor with a short shaft or where the prop adapter is on the bell end, and I'm always looking for a better way of doing things.
mnem
*Slightly imbalanced*
*DH9118/HK450GTV2/Hausler450V2/EXI450Pro/HDX450/S107G/V911/GeniusCP/TGY-9X/DEVO-7*
Hide Signatures
       Post #: 1011
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/13/2013 8:49 AM
Kozzy_98
Score: 100
Status: offline
I will probably use mum's smartphone and place it on the arm of the quadcopter. I already know that there is an app that uses the accelerometer to display the vibrations. Then it will be a test of trial and error with some vinyl electric tape. Then I will statically balance my props. If that doesn't work (ie there is still jellos) I will use the app again, instead with the propeller attatched to it on a separate motor mount. (I have alot of DT750 mounts now )
I have seen videos of just spinning up the motor on a desk and listening to the vibrations, but I have tried that with the DT750s and I didn't really end up balancing them well...
That being said a way that seems nice is to use a flexible motor mount and a mirror and using a laser. Spin up the motor and shine the laser onto the mirror thats attatched to the flexible motor mount. No vibes = Dot on the wall, vibes = line on the wall.
Thing is, I haven't got a mirror that I can fit onto the arm, and I haven't got a laser pointer.
Plus, HK has given credit to the er9x developers, but they really did cause a stir when they left out the acknowledgements till a few days later after it was released...
That being said though, who can complain for a radio that costs $50 thats based on a radio that would cost $150 after the mods?
Hide Signatures
(in reply to mnemennth)
       Post #: 1012
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/13/2013 11:51 AM
Kozzy_98
Score: 100
Status: offline
Just a quick update...
So far I have balanced my motors. What is interesting is that the new ones produce very little vibrations where as the older motors that survived from the previous crash required balancing.
Even so, the worse motors produced little vibration. This means that I will need to balance my props as well as I can in order to reduce further vibration.
If the weather is good tomorrow morning I will take some onboard footage before and after I balance my props.
Also did some reading on the P,I and P/I gains for the quadcopter but I don't understand all of it. I will try one pot at a time until I get an oscillation or the quadcopter gets hard to control.
Hide Signatures
       Post #: 1013
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/13/2013 11:57 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: mnemennth
mnem
Wow, I'd probably buy a sailboat and go sailing with Brian before I went to that much trouble.
Hide Signatures
       Post #: 1014
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/13/2013 12:30 PM
rikybob
Score: 105
Status: offline
Hiya Koz! Great viddy entro's! I enjoyed them very, very much! Rob was right, you're a nice young man and very industrious! The onboard viddy was great too! As for the "p" settings" I have read, read, and re read about them through the years and it's all Greek to me too! Many thanx for sharing!
@ Mnennenenne - I'm glad I take the time to read your posts thoroughly in that little gems that are relevant to me pop out at times. I've never liked Walkera as a whole in that I've always felt that they were all "form and no substance". Further, Phil who is now MIA from the forums was actually injured by their products in that QC is not their bigger suit. Still though I've been ashamed to say, even though their engineering sucks (why not just steal from other folk and stop making crappy helicopters) I'm ashamed to admit I like the "blingyness" of their products. I've even coveted their RTF Quads but didn't like the fact that I'd have to get another radio too (an expensive one at that) to enjoy their product. Hmmmmm? Now they are making a radio that will "do" Spektrum"?? Interesting. It's funny now b/c it doesn't do DSMX yet but it does DSM2! I've always thought the difference would be lost on my skill level anyhow! Just glanced at Walkers RTF Quads.....niiice blingy! Plus, I can get a radio that does all my models AND theirs too?? Naaaah, not right now!
@ Jonesy - You would be surprised at how nice it is to sail!
All the best!
b
EDIT: Drool > Walkera Quad
Hide Signatures
       Post #: 1015
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/13/2013 2:01 PM
rikybob
Score: 105
Status: offline
Da Fleet (sans the Nirvana class sailboat)!
b
Click for fullsize
Hide Signatures
       Post #: 1016
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/14/2013 5:24 AM
mnemennth
Score: 100
Status: offline
Bob -
Most Walkera vendors offer an upgrade in the neighborhood of $30-50 for their bundles which will get you a Devo 6S or Devo 8S (Telemetry enabled) TX which will ALSO run the open-source Deviation firmware. Makes that Storm Drone a little more enticing, I would think...
Jonesy -
It's not as drawn-out as it sounds; it's a good afternoon's bench work since I'll usually wait til I have 3 or 4 to do it, but it's no more tedious than stick-building a wing or fuse. And just as satisfying to me. :P
mnem
Don't git any on ya.
Hide Signatures
       Post #: 1017
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/14/2013 5:54 AM
Edmund2
Score: 100
Last Login: 5/17/2013
Status: offline
In great anticipation on Saturday morning I started my PC at home to watch the videos posted last week, only to find big gaps on my screen where the videos are supposed to be, not even a little crossed out block I would sometimes get at work. Anybody with some advise as to why it would not display as I never had that problem before?  Did not try it later on the weekend again.
Then finished the todoos and took a drive to the club where I found only two die hards waiting for a lull in the wind as the windsocks were straight. Saw some great flying when they eventually took to the air but also noted the effect the wind had on their 700's. DId not even plug in my lipo on the 550E as my skillset would not have handled the changing wind.
Had to settle for some indoor mcpx flying when I returned home.
Edmund
Esky Belt CP V2, Esky Belt CP V2 CX, BIG Lama, Ultimate Big Lama, Lama 4, DX6i, Align TREX 550E, Blade mCPX
Hide Signatures
       Post #: 1018
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/14/2013 11:08 AM
rikybob
Score: 105
Status: offline
Hiya Mnnmemenenenne - Me thinx I will sit and wait. I don't have the patience that Kozz and the like do to build a quad. I want to buy an ARF (at a decent price) down the road a piece that is fairly dumb a s s proof to fly and had the Fat Shark thing going so's I can fly around and violate a half dozen laws! I suspect I'm about a year or so away from one that does all that! In the mean time......
"....Come sail away, come sail away, come sail away with me ladd..."
Hiya Edmund! Dunno about the Youtube issue. Never heard of it! As for winds, yah when it gets up to 15kt at the field, i don't fly!
Work today, then off in the afternoon and will slip over to the lake and sail a bit. Funny, I was getting comfy with the range of the radios because I let the airboat get out about 75 yards. Then I heard a malfunction. Was able to limp in and found that the motor came loose from the mount. Grrrrrrr! almost cut a motor line in two and stranded me boat.
Closer inspection for that the picture in the HK Swamp Dawg advert incorrectly shows the motor mount orientation. It is backward! DOH!
Fun stuff and hope all your Mondays/Tuesdays are nice!
b
Hide Signatures
(in reply to Edmund2)
       Post #: 1019
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/14/2013 9:55 PM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: Edmund2
Edmund
Usually means that flash player has crashed. Closing it down and opening it up again usually fixes it but Im sure IT guru Jonesy will know a lot more than me.
Shame about the wind, its been like that here for the last day or two.
Hide Signatures
       Post #: 1020
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/14/2013 9:58 PM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: rikybob
b
Time for some loctite then Brian.  No nice Tuesday for me. Back to work after 4 weeks off.
Hide Signatures
       Post #: 1021
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/14/2013 10:03 PM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: Edmund2
Edmund
Yeah upgrade your flash version or your browser may have disabled it.  Google chrome is always a good browser to test to see if somethings broken in your main browser.
Hide Signatures
       Post #: 1022
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/14/2013 10:23 PM
ahamay
Score: 105
Status: offline
Heads up for the AU guys, we've been smashed with spam and a trojan claiming to be from telstra.com billing yesterday and today.  IT contains a zip file and the email looks word for work the same as the legit telstra email bill.  Watch out for these.  Legit telstra email bills have the PDF bill attached not a zip file with a trojan inside. None of the mainstream anti-virus products have updated signatures yet to detect this variant.
Jonesy
Hide Signatures
       Post #: 1023
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/14/2013 10:56 PM
rikybob
Score: 105
Status: offline
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: rikybob
''....Come sail away, come sail away, come sail away with me ladd...''
b
Hiya Ingleburn.
Yer prolly ready to got back to work?
Yeppers, I turned the mount around on the air boat and Loctited every thing!
Ran like a scalded dog!
What a nice way to blow an hour and a half!
Here's my new "HD" cam!
b
http://www.youtube.com/watch?v=e1WCjrSLrUk&feature=youtu.be
Hide Signatures
       Post #: 1024
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 1/15/2013 1:21 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
Jonesy
Thanks for the heads up Jonesy. Havent seen it yet but will keep an eye out.
Hide Signatures
       Post #: 1025
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.672RCU1
