RE: HK-450GT CCPM Alloy T-Rex compatible - Part III    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> RE: HK-450GT CCPM Alloy T-Rex compatible - Part III
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/23/2012 11:08 AM
sgbfly
Score: 100
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: Kozzy_98
Does anyone have any suggestions on a very efficient 450 motor that would give long run times? Something to learn hovers on, then I can swap it for a spare 2218 that I have. I heard that esky make a very efficient motor, but cannot recall the motor specifically...
Long flight times is what I am after @ my stage.
The Esky EK5-0006 3800KV motor is very smooth and efficient - it should give an extra couple of minutes flight time over the 2218H.  It requires an 11T 2.3mm pinion gear.  Most pinions of this size are press on that you will have to use stud-lock or even solder in place.  Hobbyking sell a grubb screwed version which is what I'd buy or look out for.
_____________________________
FBL FTW!
Hide Signatures
(in reply to Kozzy_98)
       Post #: 51
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/23/2012 11:11 AM
sgbfly
Score: 100
Status: offline
quote:
ORIGINAL: Ddaddy
Phoenix Blathering Duex!
This Friday, same time, place and password. I am changing the audio to "direct sound" though.  Hope to balther and fly with you then!
Cheers,
Ken
Howdy Ken!
I'd love to join you in this.  I don't have Phoenix yet but maybe a future meet....!
FBL FTW!
Hide Signatures
(in reply to Ddaddy)
       Post #: 52
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/23/2012 11:18 AM
Kozzy_98
Score: 100
Last Login: 5/19/2013
Status: offline
How would the Esky EK5-0006 3800KV motor compare to the 2215 in efficiency and that is the motor that I have in both of my completed helicopters. Hopefully if it is more efficient I will use it in my #3 along with the TGY306G servo..
Finally managed to break one of the canopy posts on my MCPX, lucky it was the one that points towards the nose!
Helis: HK450GT - Typhoon 2215+Spektrum AR6200X, HK450G/MT - Typhoon 2218+Orange6chRX, MCPX
Hide Signatures
(in reply to sgbfly)
       Post #: 53
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/23/2012 12:28 PM
sgbfly
Score: 100
Status: offline
quote:
ORIGINAL: Kozzy_98
How would the Esky EK5-0006 3800KV motor compare to the 2215 in efficiency.
There is not much in it versus the smaller HK motor tbh
FBL FTW!
Hide Signatures
       Post #: 54
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/23/2012 12:38 PM
ahamay
Score: 105
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: Kozzy_98
Not sure if hunting down a more efficient motor over the 2218 you already have is going to be worth it in the end.  As soon as your past the hovering stage the longer flight times are going to be out the window anyways.  I think you would benefit from spending the extra money on a few extra batteries.
Jonesy
Tarot 450 PRO V2 FBL zyx , Tarot 450 PRO V2 FBL zyx-s , MCPx V2, Nano CPx
Hide Signatures
       Post #: 55
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/23/2012 12:41 PM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: sgbfly
quote:
ORIGINAL: Ddaddy
Cheers,
Ken
Howdy Ken!
I'm out on this one as well, gotta work Friday.
Jonesy
Hide Signatures
       Post #: 56
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/23/2012 12:54 PM
sgbfly
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
quote:
ORIGINAL: Kozzy_98
Jonesy
That's right.  Defo more bang per buck by buying extra lipos!
Simon
FBL FTW!
Hide Signatures
(in reply to ahamay)
       Post #: 57
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/23/2012 12:55 PM
rikybob
Score: 105
Status: offline
quote:
ORIGINAL: rikybob
It's kinda funny, I crash mine ever other battery for a total of nearly a hundred crashes. I have never replaced a main gear, F/S etc. I finally DID manage to kill the actual frame!
Conversely a certain stodgy friend of mine from an evil empire has prollly only crashed his 1/2 dozen times. I don't know how he does it!!
Headin' out to the Flyin' Club tomorrow and look forward to gettin' shum schict time!
I cut off those big red connectors from my new 3000 batteries and soldered on my favorite XT connectors!
This gives me 7 batteries for the 500 size heli!
As for the blather fest on Friday, the irony that the ''blathermeister'' himself will have to absent is not lost on me!
I am attending a fundraiser for the neighbor across the street as having cancer is VERY expensive!
So instead of hanging out with you lovely folk I will be at an art gallery that has a cash bar
All for a good cause and will get to see the ladies dressed up!
All the best and look forward to a blatherfest in the future!
b
Vein attempt to coax bear out of cave, must try another tactic!
b
Align 500CF FBL, MCP X, MQX & DX7, Gemini 600 Cat, Swamp Dawg Airboat, Nirvana II, Dumas Big Swamp Buggy, Slow Stick!
Hide Signatures
(in reply to rikybob)
       Post #: 58
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/23/2012 1:00 PM
sgbfly
Score: 100
Status: offline
quote:
ORIGINAL: rikybob
quote:
ORIGINAL: rikybob
b
3 crashes actually
FBL FTW!
Hide Signatures
       Post #: 59
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/23/2012 1:06 PM
Edmund2
Score: 100
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: rikybob
quote:
ORIGINAL: rikybob
b
b
Now I did bring some very good honey home from Namibia that may just get that bear out of the cave!!!! COme on weekend I got used to not to work.
Edmund
Esky Belt CP V2, Esky Belt CP V2 CX, BIG Lama, Ultimate Big Lama, Lama 4, DX6i, Align TREX 550E, Blade mCPX
Hide Signatures
       Post #: 60
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/23/2012 1:12 PM
sgbfly
Score: 100
Status: offline
quote:
ORIGINAL: Edmund2
Edmund
Lol, that would do the trick!
Congrats on your sons epic international BOL voyage!  To celebrate I flew mine on Tuesday!
Simon
FBL FTW!
Hide Signatures
(in reply to Edmund2)
       Post #: 61
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/23/2012 1:33 PM
Edmund2
Score: 100
Status: offline
He left his BOL with me when he moved to Namibia and as I had space in the vehicle asked him if I should bring it along. Now at my place there is limited space and as it is he can outlfy me on precision flying with a BOL any day and I am pretty good at that. When he lifted off on a virtual windless day with more space then he ever had to fly in, it was a joy to watch. Straight line and 180 degree turnaround on the same line at almost FF. I was later watching his face rather than the BOL as that wide grin told me that I did the right thing to bring his toy to him. Left him with lots of spare blades and referred him to Spiros' way of taping the fuse. That crossborder flight was great to watch and he did it like a pro.
Edmund.
Hide Signatures
       Post #: 62
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/24/2012 1:22 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
quote:
ORIGINAL: sgbfly
quote:
ORIGINAL: Ddaddy
Cheers,
Ken
Howdy Ken!
Jonesy
Yeah I'm out too. Working but have fun guys.
Hide Signatures
       Post #: 63
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/24/2012 6:48 AM
mnemennth
Score: 100
Status: offline
quote:
ORIGINAL: Kozzy_98
I've been flogging a couple of these I got from the Miami warehouse a couple months ago for $8 ea (sold out now in both US warehouses); they're a solid motor once you balance 'em, but they DO need to be balanced. Or at least, both of mine did. Now, I'm running one on an el-cheapo 30A ESC and it never gets warm; I'd say the current draw is reasonably low. I need to hoe out some space on my outside bench and I'll try and come up with some stats for ya.
https://www.leaderhobby.com/product.asp?ID=9394001225754
If ya don't have the patience or knack for balancing, or if you don't really need more motors (like I really did) then I'm gonna agree with Jonesy - you're prolly better off spending yer money on a few extra packs. Did I mention the Turnigy Nano-Tech 3S/2200/25-50C packs are $10.19 ea on the swarm right now? LOL.
mnem
Zzzzt.
*DH9118/HK450GTV2/Hausler450V2/EXI450Pro/HDX450/S107G/V911/GeniusCP/TGY-9X/DEVO-7*
Hide Signatures
       Post #: 64
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/24/2012 11:35 AM
rikybob
Score: 105
Status: offline
Happy B'day Jonesy!
b
Hide Signatures
(in reply to ingleburn)
       Post #: 65
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/24/2012 12:19 PM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: rikybob
Happy B'day Jonesy!
b
Thanks mate.... just installing my hitec servos that I got today.  All 3 of them work which is a good start
Hide Signatures
       Post #: 66
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/24/2012 12:30 PM
rikybob
Score: 105
Status: offline
Had a great time at the flying club yesterday!
Here is an AMAZING flier!
b
Hide Signatures
       Post #: 67
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/24/2012 1:18 PM
pushinoldrc
Score: 105
Status: offline
Comments on YouTube
Carl Goldberg Ultimate 10-300 Brotherhood. #23
Hide Signatures
       Post #: 68
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/24/2012 7:59 PM
mnemennth
Score: 100
Status: offline
quote:
ORIGINAL: rikybob
Happy B'day Jonesy!
b
Hippo Bathday dude!
May the wind be elsewhere and your batteries full!
mnem
Umm... you gonna eat all that cake?
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 69
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/24/2012 8:19 PM
mnemennth
Score: 100
Status: offline
quote:
ORIGINAL: pushinoldrc
Comments on YouTube
Comments on yer comments. And stuph.
mnem
I shall eat lasagna.
Hide Signatures
(in reply to pushinoldrc)
       Post #: 70
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/24/2012 9:44 PM
sgbfly
Score: 100
Status: offline
Jonsey, Am I too late to wish you a happy birthday?  From where I'm sat I'm just about ok
Hi to all and a couple of flight videos to share.
I enjoyed some fast flying and some big power loops.  It's a bit same old same old but here goes...
I'm starting to get back into this now after my hols!
Best to all!
Simon
FBL FTW!
Hide Signatures
(in reply to mnemennth)
       Post #: 71
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/24/2012 11:43 PM
rikybob
Score: 105
Status: offline
Grrrrrr!
Hide Signatures
       Post #: 72
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/24/2012 11:46 PM
rikybob
Score: 105
Status: offline
quote:
ORIGINAL: sgbfly
Best to all!
Simon
Snappy comments on YT!
b
< Message edited by rikybob -- 8/25/2012 4:03 PM >
Hide Signatures
       Post #: 73
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/25/2012 12:39 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: sgbfly
Best to all!
Simon
Nope, it's saturday morning here and it's today so thanks for the birthday wishes.
Hide Signatures
       Post #: 74
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 8/25/2012 12:40 AM
ahamay
Score: 105
Status: offline
Just flew two packs on the new hs-5065mg servos I installed last night and they are great.  I'll upload a vid later on as I"ve got to goto someone elses birthday party now ( can you believe it)
Jonesy
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.109RCU1
