RE: HK-450GT CCPM Alloy T-Rex compatible - Part III    Gallery
Logged in as Guest
Users viewing this topic: rikybob, Bpar4
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> RE: HK-450GT CCPM Alloy T-Rex compatible - Part III
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/4/2012 7:03 AM
Ddaddy
Score: 100
Last Login: 5/18/2013
Status: offline
I'm a little surprized there's not been much response on RCG about the 3.5 pitch especially since Simon's vid's are refferenced so much. I'm not experiencing it on my 3.5 but it's on a 500 and it's had other issues ($) I've been working through. My 450 has original cx1000 and I'm not touching it!
It is clear there's a problem though from watching the vids.
Goodnight everyone,
Ken
_____________________________
MCX, MSR, BOL, Blade SR, franKENblade 400, FBL 450, mCPX, FBL 500, AXN FPV
Hide Signatures
(in reply to ingleburn)
       Post #: 151
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/4/2012 10:59 PM
rikybob
Score: 105
Status: online
quote:
ORIGINAL: ingleburn
 @  Joaquin. Hope you get some flying in soon.  I know how work gets in the way.
@ Brian. Glad you enjoyed your weekend. I had the same thing in Thailand but I think the wants might have been a bit different.
Hate to say it but Ill be glad when your walk of shame starts. Been a bit quiet in here and your blather will be welcome.
@ all.  Went out again this morning and found a bigger patch of ground to fly on. Weather was great and really enjoyed it.
Vids uploading now but no blather as I was kinda expecting a crash as Im going a bit beyond my comfort zone.
Sorry to report no crashes but on the last flight it glitched again so Ill upload it for you to take a look at.
Seems to be the same symtoms as Simons, flying into the wind and giving elevator it just takes off.
Luckily Im only trying to level out not do a loop as Simon is when it glitches.
Yah, one last weekend off for a while will be spent on Florida's Treasure coast watching sunsets!
I secretly look forward to having Mon/Tue off for a month in a measure to blather you folk again!
Many thanx!
b
PS Good viddys, need more blather!
PSS Watch out for the fence!
Align 500CF FBL, MCP X, MQX & DX7, Gemini 600 Cat, Swamp Dawg Airboat, Nirvana II, Dumas Big Swamp Buggy, Slow Stick!
Hide Signatures
       Post #: 152
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/4/2012 11:02 PM
rikybob
Score: 105
Status: online
quote:
ORIGINAL: Ddaddy
Goodnight everyone,
Ken
Odd isn't it???
As for me I own two CX1000's and of course with my "Fish tankin'" I like 'em JUST the way they are!
The next one I get is a BeastX clone!
All the best!
b
Hide Signatures
(in reply to Ddaddy)
       Post #: 153
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/5/2012 12:05 AM
hugj
Score: 100
Status: offline
I have a cx1000 on my 450, gaui 425 a beastx clone on the trex 500 and a beastx on the swift 550.
the only issues i had were with the cx1000 on the gaui droped the gains and flys great.
 both the clone and orginal beastx work great i like them better beceause you can program them with out a computer.
 I got the 550 back in the air this last weekend flew great. I'm a little gun shy though come to find out the tail linkege is a weak link
I can upgrade to cnc but it is $$$$ also i may convert it to the gaui design if it will work tail shafts are the same size.
I think i will take one off and see if it will work, if it does i can get a cnc gaui set up for less money.
   Raining again so i think a little mntc. is in order.
  Hugh
Hide Signatures
(in reply to rikybob)
       Post #: 154
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/5/2012 12:29 AM
rikybob
Score: 105
Status: online
quote:
ORIGINAL: hugj
  Hugh
550 ( drool )
Whats mntc I wunder??
b
Hide Signatures
(in reply to hugj)
       Post #: 155
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/5/2012 12:44 AM
hugj
Score: 100
Status: offline
Don't drool too hard with bigger birds comes bigger cost's!!!!!!!
Hide Signatures
       Post #: 156
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/5/2012 7:11 AM
Kozzy_98
Score: 100
Status: offline
I assume mtnc = maintenance...
Finally got my big box full of parts for the quad copter. 11x4.7 props are deceptively big, as too the DT750 motors off HK!
Will hopefully program the quad board and also wire up the escs.
Helis: HK450GT - Typhoon 2215+Spektrum AR6200X, HK450G/MT - Typhoon 2218+Orange6chRX, MCPX
Hide Signatures
(in reply to hugj)
       Post #: 157
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/5/2012 9:44 AM
Kozzy_98
Score: 100
Status: offline
Hey guys, having a bit of a problem as far as my MT kit goes...
Just spooled up the motor to check if it was spinning in the right direction, and something didn't sound right. It sounded as if something was restricting the movement of the motor and the motor RPMs were going up, then down even though my stick was in the same position.
So I checked the belt tension, all good. Meshing between the pinion and main gear was good. However I am not sure about the meshing of the tail drive gear and tail belt gear. This seems to be the problem because when I spin the head in the opposite direction, it is not smooth unlike both of my GT frames. A tad frustrating, but oh well...
Hide Signatures
(in reply to Kozzy_98)
       Post #: 158
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/5/2012 10:17 AM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: Kozzy_98
I'll throw a few suggestions...something may help.
- Watch out for soft start on ESC...this can be a little confusting if your giving throttle and nothings happening then it revs up.
- Take your main gear off and spool the motor to check to see if it's free and working as per normal.
- Check you have not overtigtened the main gear bolt as this will warp your tail drive gear (autorotation gear) and it will have a tight spot with your tail belt gear.  You may just have a warped gear which is highly likely.
Sounds like the problem is the mesh between the autorotation gear and the tail drive gear.  These gears tend to be warped and will wobble a bit but still maintain good contact with the tail gear.  It's when it's warped the othe way (ie oval instead of round) that you get a tight spot.
Hope that helps
Jonesy
Tarot 450 PRO V2 FBL zyx , Tarot 450 PRO V2 FBL zyx-s , MCPx V2, Nano CPx
Hide Signatures
       Post #: 159
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/5/2012 1:03 PM
Kozzy_98
Score: 100
Status: offline
3rd point helped me, thanks Jonesy!
Night to all.
Hide Signatures
(in reply to ahamay)
       Post #: 160
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/5/2012 1:23 PM
rikybob
Score: 105
Status: online
quote:
ORIGINAL: Kozzy_98
I assume mtnc = maintenance...DOH!
Hide Signatures
       Post #: 161
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/5/2012 2:28 PM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
quote:
ORIGINAL: Kozzy_98
Hope that helps
Jonesy
Ive been pretty lucky with mine but the last one was warped, wobbled and ovaled so I threw it out and put a complete Tarot set on it. Problem fixed.
Think the GT needs some mtnc as well  but will have to wait till after tommorows flights.
Trying to get this glitch sorted as I dont want to go back to the other firmware.
Hide Signatures
       Post #: 162
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/5/2012 10:27 PM
jnail
Score: 100
Last Login: 9/12/2012
Status: offline
Hey guys, I haven't been around much lately due to life....
I know its a late invite, but our flying club is hosting our anual fall fun-fly this weekend. I would like to invite anyone who is anywhere near northen MN to attend. It is usually a really fun event for both plankers and heli pilots. I think the highlight of the weekend this time though will be the full-contact foamy delta combat. We are hoping to start with at least 30 airplanes, and end with 1! You can find the info on the link I posted, or PM me, and I will give you more info.
On a more somber note, for me anyway, I have found out that my job is ending at the end of this month after 10 years of loyalty. So I am kind of in freak-out mode over what to do next. Hopefully I will be able to keep something in the air during this time to help fend off the depression. I will try to keep in touch with everyone, but keep me in your thoughts.
Jeff
Hobby King HK-450GT w/ tarot zyx fbl, MCP X, 2 Slow Sticks, china clipper, Hk Vampire, HL F-86, .32 Float plane.
Hide Signatures
       Post #: 163
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/5/2012 10:37 PM
Ddaddy
Score: 100
Status: offline
quote:
ORIGINAL: jnail
Jeff
Jeff,
No reason to freak out.  I was just let go after 21 years. And I am enjoying my free time :
Wish I could join you but a little far ;
Best,
Ken
Hide Signatures
(in reply to jnail)
       Post #: 164
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/5/2012 11:47 PM
hugj
Score: 100
Status: offline
sorry to hear that Jeff I do know where you are at!
 Keep the faith and remember you were looking for a job when you got that one.
Just fly and enjoy life! It may be gone in a instant.
  Hugh
Hide Signatures
(in reply to jnail)
       Post #: 165
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/6/2012 6:41 AM
mnemennth
Score: 100
Status: offline
quote:
ORIGINAL: Edmund2
Mnem, where did you get Kakked in the English vocabularly? Great version of an Afrikaans word (my language) and  reading your sentence the meaning (end result) is exactly the same when we ad the "ked" to it. Implication being not good quality and it got busted.
(SNIP)
Edmund
Hmmm...
while it does appear that what is now the most popular usage of that slang is derived from the Africaans word for dung, my exposure to the term as a youth in 1980s Pittsburgh, PA was as an  onomatopoeia for the sound a cat makes when coughing up something dead or otherwise nasty. However, I do know that I've seen the word "kakk" used by several Brit friends online, and it was always in similar context; I always assumed they meant the same thing I did, but it is more likely it was adapted from the Africaans.
quote:
ORIGINAL: ahamay
quote:
ORIGINAL: Kozzy_98
Hope that helps
Jonesy
Another thing to be very careful of is the one-way bearing; especially on these econo-kits, they cheap out big time on 'em. If you take your auto drive gear off the hub, then put the hub on a fresh bearing sleeve, then either chuck that up in a prop balancer or spin it on a mainshaft in an empty chassis, you will often find that the hub is crooked as hell. Another thing they'll do is run true in ONE spot on the sleeve; once you let it freewheel to a new spot, it'll be crooked again. I always thought it was poor manufacturing on the hubs, until I got the Align bearing press (K10273) and some Align one-way bearings (HS1229). EVERY ONE of those hubs ran true with the Align one-way bearings.
If you can't be arsed to press a one-way bearing, genuine Align hubs (HS1228) with the bearing installed are only $12-ish. Get yourself one or two and some new Align sleeves (HZ026) and go through all your "warped" gears again; you'll be amazed at how many run true. The one-way bearing will make the Auto gear run crooked; a poorly made sleeve can make both gears run crooked. Also, it is VERY easy to overtighten the jeezus bolt that runs through the main gear; if you do, you deform the main gear and the sleeve, causing these problems as well.
This bearing/hub is one of the biggest causes of harmonic vibration in these little birds; especially if you get a high-frequency vibration at a specific RPM regardless of blade pitch, look here and at your motor's balancing.
I know some models of FBL units have data logging, and that they can monitor vibration levels in the heli. Can the BeastX and clone do this?
mnem
I'm bearing the load okay.
*DH9118/HK450GTV2/Hausler450V2/EXI450Pro/HDX450/S107G/V911/GeniusCP/TGY-9X/DEVO-7*
Hide Signatures
       Post #: 166
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/6/2012 9:29 AM
Edmund2
Score: 100
Last Login: 5/17/2013
Status: offline
There are about 1 ex South Africans in London and about half that in Aus. So yes that word has gone around a bit.  RAIN  wonderful rain over here. now I will get mud on my shoes and no more dust!!!!
Edmund
Esky Belt CP V2, Esky Belt CP V2 CX, BIG Lama, Ultimate Big Lama, Lama 4, DX6i, Align TREX 550E, Blade mCPX
Hide Signatures
(in reply to mnemennth)
       Post #: 167
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/6/2012 11:52 AM
ingleburn
Score: 100
Status: offline
quote:
ORIGINAL: Edmund2
Edmund
In Australia we use it as well. But as usual we add a bit so to us its cactus. Well I thought it was spelt that way but maybe its kaktus?
Hide Signatures
(in reply to Edmund2)
       Post #: 168
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/6/2012 12:39 PM
Edmund2
Score: 100
Status: offline
quote:
ORIGINAL: ingleburn
quote:
ORIGINAL: Edmund2
Edmund
Kaktus in our language is the same as Cactus in English, being a spiny succulant plant, A short little story about our three letter word. Many years a go I had a new manager coming to SA from the UK. At a shopping mall be buzzed into a parking lot with his car and as a vehicle pulled out he zipped into the parking space not realising that another vehicle with it's indicator on was waiting for car one to pull out before she could pull into it. The lady driver then told him in Afrikaans "Gaan kak meneer" translated meaning, Go and have cr.p sir, that was the first Afrikaans words spoken directly to him and we had much joy in explaing to him what it meant.
Edmund
Hide Signatures
       Post #: 169
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/6/2012 10:34 PM
ahamay
Score: 105
Status: offline
Another new heli from blade.  The Nano CP X.  Smaller than mcpx but runs same motors apparently.  Look like a neat bird for inside.
http://www.bladehelis.com/Products/Default.aspx?ProdId=BLH3300
Hide Signatures
       Post #: 170
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/6/2012 10:58 PM
rikybob
Score: 105
Status: online
@ Jeff - As we spoke privately GO HOME! There is NO ONE in a land as COLD as where you live. Russians aren't that cold!
@ All - Got HOSED out of flying today due to work and look forward to getting back out into the field next week!
All the best!
b
Hide Signatures
       Post #: 171
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/7/2012 2:56 AM
mnemennth
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
 (SNIP for brevity's sake)
Mmmhmm... This is looking an awful lot like my 4Ch Xieda 9958's design; looks like it uses the same landing gear and similar chassis. It even has the same horrible, horrible linear servos. Ughh. I wonder if they contracted to manufacture it?
Manual is here, with exploded view:
http://www.bladehelis.com/ProdInfo/Files/BLH3300-Manual.pdf
mnem
Bent, not broken.
Hide Signatures
       Post #: 172
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/7/2012 12:25 PM
Kozzy_98
Score: 100
Status: offline
Hey guys, I have a small issue to which I am absolutely perplexed!
I have a HK401b Cyro and a HXT900 servo for the tail. When I give right rudder, it piros left and vice versa. If I flip the Direction tab, it piros out of control because it is compensating in the wrong direction...
Hide Signatures
       Post #: 173
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/7/2012 12:37 PM
ahamay
Score: 105
Status: offline
quote:
ORIGINAL: Kozzy_98
Reverse the rudder channel direction in your tx.
Jonesy
Hide Signatures
       Post #: 174
RE: HK-450GT CCPM Alloy T-Rex compatible - Part III - 9/8/2012 4:59 AM
mnemennth
Score: 100
Status: offline
quote:
ORIGINAL: ahamay
quote:
ORIGINAL: Kozzy_98
Jonesy
You know, for the longest time I had all mine set up like that, because I instinctively "flew the tail" and it just seemed the natural way to set it up. It wasn't until I bought my first RTF that I realized I had it bass-ackwards.
mnem
"mumblethatandaboutamillionotherthingsmumble..."
"What was that honey? I can't hear you."
"NUHH-THING!!!"
Hide Signatures
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
