RE: EME60    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: EME60
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: EME60 - 10/7/2012 6:59 PM
ramoooo
Score: 100
Last Login: 5/15/2013
Status: offline
by the way    Milehighrc.com  sells these engines and he is a great guy. I have bought several items from him.
he is also offering 30 days guarantee and service on the engines. thats cool
< Message edited by ramoooo -- 10/7/2012 7:24 PM >
Hide Signatures
(in reply to ramoooo)
       Post #: 26
RE: EME60 - 10/7/2012 9:38 PM
john911
Score: 100
Last Login: 4/10/2013
Status: offline
no dead sticks this engine has been great so far.
Hide Signatures
       Post #: 27
RE: EME60 - 10/8/2012 1:38 AM
closetguy
Score: 166
Last Login: 5/22/2013
Status: offline
thats good to hear,can't wait till i can get some flying time with the new engine. and FB ring to see some rpm numbers.
Hide Signatures
(in reply to john911)
       Post #: 28
RE: EME60 - 10/8/2012 6:07 AM
Ernie Misner
Score: 130
Last Login: 5/20/2013
Status: offline
Frank's rings average around 11 bucks I think. I think gasser rings are easier to install than glow because all you have to do is pull 4 bolts and pull the jug off.
Hide Signatures
       Post #: 29
RE: EME60 - 10/8/2012 6:18 AM
ramoooo
Score: 100
Status: offline
does he have a website ? i couldnt find any
Hide Signatures
(in reply to Ernie Misner)
       Post #: 30
RE: EME60 - 10/8/2012 6:34 AM
Ernie Misner
Score: 130
Status: offline
No web site. Email him at: ringmaster46@msn.com
He'll answer your questions and send you a bunch of information through your email.
Hide Signatures
       Post #: 31
RE: EME60 - 10/9/2012 11:02 PM
closetguy
Score: 166
Status: offline
ramoooo, the EME has jap bearings,my self not realy worried about the crank bearings,it's the lower rod bearings and the crank pin that i think may fail just like DLE55.
but as long as i can get parts from MileHigh rc and they said they will stock parts for it that is all that concerns me.
just got word from Frank Bowman and cylinder and piston is on it's way back,won't be long now to see what it will do.
Hide Signatures
       Post #: 32
RE: EME60 - 10/12/2012 7:53 PM
closetguy
Score: 166
Status: offline
Hide Signatures
(in reply to closetguy)
       Post #: 33
RE: EME60 - 10/12/2012 8:04 PM
closetguy
Score: 166
Status: offline
trying to up load pic's of eme60, before i put the new ring in,it's not going good.[image][/image] here is another thing i just notice,no pulse line going to carb.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by closetguy -- 10/12/2012 11:36 PM >
Hide Signatures
       Post #: 34
RE: EME60 - 10/13/2012 3:04 AM
Ernie Misner
Score: 130
Status: offline
In the 1st shot what is the ring with dots around the combustion chamber?
Hide Signatures
       Post #: 35
RE: EME60 - 10/13/2012 11:48 AM
closetguy
Score: 166
Status: offline
thats just part of the casting in the cylinder,or tooling marks.there is a vedio of them with one chuck up in a lathe cutting the bore,it may be that?
Hide Signatures
       Post #: 36
RE: EME60 - 10/14/2012 8:08 AM
Ernie Misner
Score: 130
Status: offline
Well all be. If there are any sharp edges on those marks in the combustion chamber it could cause hot spots and preignition. I've never seen anything like it.
Hide Signatures
       Post #: 37
RE: EME60 - 10/14/2012 8:31 AM
ramoooo
Score: 100
Status: offline
closetguy,
looking nice, keep us updated. if they run great and reliable I will be one 60cc and one 120cc.
do you notice less vibration over the  DLE55 ?
Hide Signatures
       Post #: 38
RE: EME60 - 10/14/2012 12:43 PM
closetguy
Score: 166
Status: offline
no sharp edges Ernie,there not even small holes,the round marks are flush with the surrounding surface.
i talk to john911 before i bought this one and he said no more vibes or shake than any other engine.
i have not ran the engine yet,putting on a roof,when i do i'll post the rpm's with the props.be interesting to see the numbers with a Bowman ring,compared to john's engine.
just so you know Franks ring had less than .002 ring gap,thats the smallest gauge i have and it was a tight fit.
Hide Signatures
       Post #: 39
RE: EME60 - 10/14/2012 10:49 PM
ramoooo
Score: 100
Status: offline
looking forward to those #'s......... run the engine run it
Hide Signatures
       Post #: 40
RE: EME60 - 10/18/2012 10:32 PM  1 votes
closetguy
Score: 166
Status: offline
well i got time to get engine mounted and ran four tanks of fuel through it (fourty min.),with 32-1 redline.engine isn't a shaker, just as smooth as the 55dle's i have,easy starting,good throttle rsponse,smooth transtion.
the Xoar 23-8 laminate had really fast response at 7100 rpm's,didn't even try the Xoar 23-8 beechwood,i normally get 200 more with it verses the laminate.
the 24-8 NX got 6510,i didn't change the needles at all for the 24-8,they were set at max rpm's with the 23-8.engine was ran eight min. before any rpm's were taken,good and warm, at the end of the fouth tank.
muffler was a DA50 side dump,now i want to replace the dle55 on a WrongWay 50cc profile, with one of these 60's.
i am good with the rpm's i got, the Xoar laminate is a higher load prop.not sure about the 24-8 NX where that falls as load is concerned.maybe someone with a DA 60 can chime in and let me know how that stacks up.
< Message edited by closetguy -- 10/26/2012 11:17 AM >
Hide Signatures
       Post #: 41
RE: EME60 - 10/18/2012 11:34 PM
ramoooo
Score: 100
Status: offline
Thanks for the update.
have you tried it in a plane or just an engine stand.
what do you think of the performance over the DLE 55., does it have more power ? reliable ? smoother or just the same ?
does it feel like it has more compression using the bow man ?
thanks a lot
Hide Signatures
       Post #: 42
RE: EME60 - 10/19/2012 1:11 AM
closetguy
Score: 166
Status: offline
i don't have much use for a test stand,it's mounted in a 3DHS 89"Slick and it's been to windy to fly.MUCH better power than a DLE55 and just as smooth as the 55.
as with every engine i have used a Bowman ring in, it has at lease double the compression,but all of the engines have been china made.
base on only the power that it is putting out, and how smooth it is, i would buy another,but time will be the real test.
Hide Signatures
       Post #: 43
RE: EME60 - 10/21/2012 11:58 PM
ramoooo
Score: 100
Status: offline
double the compression, wow. that sounds amazing. i'm thinking of getting one of the 60cc's and one in the 120 for my 100cc plane.
what prop does it fly better with 23' or 24", for the 60cc i'm considering going with either  a vess 24b or 23b. which one do you recommend,,, 23 or 24 ?
thanks man for all your hard work on these engines
Hide Signatures
       Post #: 44
RE: EME60 - 10/22/2012 7:41 PM
closetguy
Score: 166
Status: offline
i just ran 3/4 of a gal. through the 60 on sunday.i tried a NX 24-8 and still getting in the low 6500 range of rpm's.spool up is to slow out of a hover on this prop for my liken.
the 23-8 Xoar laminate is MUCH better at 7150-7200 and will stick with this prop for the time being, it also has good vertical speed and no slowing down at all while climbing.engine is really easy to start with on flip starts all day after the first cold start of the day.
it is just as smooth as a dle55,i think the Bowman ring has lot to do with that,it's smooth out the two 55's that i put the ring in.so far i like the engine but only time will tell.
i would like to try a Falcon 24-8 but hate to spend that kind of money to find out i don't like it.
Hide Signatures
       Post #: 45
RE: EME60 - 10/22/2012 8:08 PM
ramoooo
Score: 100
Status: offline
have you tried vess 24B    ?
 for this motor would you say vess 23 or 24 would be better ?
Hide Signatures
       Post #: 46
RE: EME60 - 10/22/2012 9:26 PM
closetguy
Score: 166
Status: offline
john911 said he was getting 6750-6900 on both the Vess 24a and 24b.the 23a might be to much under prop.if i was going to try a Vess, which i might do, i would try the 24-a,a lot cheaper to by than a Falcon carbon.
Hide Signatures
       Post #: 47
RE: EME60 - 10/23/2012 5:32 PM
closetguy
Score: 166
Status: offline
just an update,i had to replace a used cm6 plug that i put in the engine, to get rid of a miss i had with a new cm6.and had to put a remote breather tube on the diaphragm cover on the carb to get rid of a rich running carb at low speed.
engine is running better than ever now,if it holds up i will be selling my BME58's and the DLE55's i have.
Hide Signatures
       Post #: 48
RE: EME60 - 10/26/2012 11:26 AM
closetguy
Score: 166
Status: offline
got almost three gals, through the 60 now,ring is still not competely seated due to that i am using 32-1 redline,just takes a little longer.rpm's have not change to much, just a little increase.
still like the Xoar 23-8 the best,tried a Bolly 23-8 and it just rip the prop bad,didn't like that prop at all.
Hide Signatures
       Post #: 49
RE: EME60 - 10/26/2012 12:05 PM
Stu26
Score: 100
Last Login: 5/21/2013
Status: offline
with the limited data we can get on this motor, are these better than a DLE55 for power? or near a DA60?
Anyone tried or seen a 120 yet?
Hide Signatures
       Post #: 50
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: EME60
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
