RE: A123 Question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> RE: A123 Question
Page: <<   < prev  1 2 3 4 [5]
Login
RE: A123 Question - 10/10/2012 8:03 PM
BarracudaHockey
Score: 280
Last Login: 5/21/2013
Status: offline
I got a bone to pick with you anyways Chad!!
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to taildragger21)
       Post #: 101
RE: A123 Question - 10/10/2012 9:01 PM
taildragger21
Score: 105
Last Login: 5/22/2013
Status: offline
Whats that. Lol
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 102
RE: A123 Question - 10/10/2012 9:19 PM
alan0899
Score: 100
Last Login: 5/12/2013
Status: offline
G'day Guys,
I have just read some of this thread, & I know I'm not in the USA, but I wonder if you have heard of BoomaRC here in Australia.
http://www.boomarc.com/
They have packs for ignition, at 1200Ma, they are actually 1400Ma cells, that can be used for RX, I have one for the ignition on my Saito FG21, they are self balancing, there is a charge lead,
& a power lead, both JR type plugs.
They also have larger packs, & all sorts of switches & equipment.
Also a forum for info. Rick is the guy that runs it all, & he is very helpful.
I only posted because of the balancing question.
Cheers
Good Flyin Mate. Keep Thyne Airspeed up, lest the ground arise & smite thee,
Allan.
Hide Signatures
       Post #: 103
RE: A123 Question - 10/10/2012 11:23 PM
45cal
Score: 100
Last Login: 4/18/2013
Status: offline
just got a 2300, A123 pack from Radical RC for a 50cc size build this fall.  After reading most of these post putting this battery pack in a 60 glow size plane with 5 futaba 3004 servos may be a little over kill
Hide Signatures
(in reply to alan0899)
       Post #: 104
RE: A123 Question - 10/11/2012 12:17 AM
pilotpete2
Score: 120
Status: offline
Maybe just a wee bit
The 1100mAh size is perfect for most any sport glow plane. I have a Sig 4 Star 60 (5 servos) and a H9 Showtime 50 (6 servos) both using 1100mAh A123's. In both cases the models use 65-75mA per flight. I use a Cellpro Multi4, so I get a very accurate indication of just how many mA I use per flight, and it's always less than you'd think. My 30cc Yak uses a pair with redundant switches to power 5 HS-5625's and an analog servo on throttle, with an IBEC also powered by the two 1100mAh packs.
With A123's I just make sure the battery is full before the first flight, and if I wind up flying that plane more than normal, I just put it on charge to top it off real quick
Radical Dave is a great guy to deal with
Pete
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
(in reply to 45cal)
       Post #: 105
RE: A123 Question - 10/11/2012 6:26 AM
ramboman
Score: 100
Status: offline
Two pairs of 1100 separated with Schottky diodes, two switches and two connectors to the Rx.
There is no better solution !
Hide Signatures
(in reply to pilotpete2)
       Post #: 106
RE: A123 Question - 10/11/2012 6:44 AM
alan0899
Score: 100
Status: offline
quote:
ORIGINAL: ramboman
G'day Mate,
You really don't need 4 batteries, 2 pairs is 4, & you don't need the diodes, just 2 batteries, 2 switches, & 2 rx connectors.
Both batteries need to be the same voltage, they won't effect each other at all, they will just power the RX.
Cheers.
Allan.
Hide Signatures
(in reply to ramboman)
       Post #: 107
RE: A123 Question - 10/11/2012 6:57 AM
ramboman
Score: 100
Status: offline
To be clear: one "battery" is a pair of a123 1100 mAh. There are two batteries or four a123 cells.
Hide Signatures
       Post #: 108
RE: A123 Question - 10/11/2012 7:04 AM
alan0899
Score: 100
Status: offline
G'day Mate,
Sorry we call them a pack, when there is more than 1 cell, not a pair.
My mistake, Sorry again for the misunderstanding.
Cheers
Allan.
Hide Signatures
       Post #: 109
RE: A123 Question - 10/11/2012 7:51 AM
ramboman
Score: 100
Status: offline
It's a question of wording... most of the time, when you use a123 you have to assemble cells into packs by your self... so it's logic to say "a pair"... instead of "a pack"...
Hide Signatures
       Post #: 110
RE: A123 Question - 10/11/2012 8:13 AM
alan0899
Score: 100
Status: offline
G'day Mate,
LiFe packs are not only in 2S, they can also be in series parrallel, to add capacity.
I buy mine from here: http://www.boomarc.com/category/53-lifep04-receiver-batteries.aspx
They have great gear, & ship world wide. Check em out.
I still don't think you need diodes, but BoomaRC also sell very good battshare devices.
Cheers
< Message edited by alan0899 -- 10/11/2012 9:49 AM >
Allan.
Hide Signatures
       Post #: 111
RE: A123 Question - 10/11/2012 10:23 AM
ramboman
Score: 100
Status: offline
You are right... I use them for main power up to 12s2p...
Hide Signatures
       Post #: 112
RE: A123 Question - 10/11/2012 2:23 PM
BarracudaHockey
Score: 280
Status: offline
quote:
ORIGINAL: taildragger21
Whats that. Lol
Sent you a msg on facebook, its all good
www.JaxRC.com
Hide Signatures
       Post #: 113
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
