Microjet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
ParkZone F-27Q Stryker - RTF
Seller:  nrthwing
Details:   $150.00   |  6/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Electric Aerobatic & Sport Planes >> Microjet
Page: [1] 2   next >   >>
Login
Microjet - 9/8/2003 2:07 PM
aerodynamic18
Score: 100
Last Login: 12/21/2006
Status: offline
Hi i was just wondering if anyone has flown the microjet from Multiplex and what do u think. I have one but am waiting for servos for it before i can fly and just wondered what you guys thought
Hide Signatures
       Post #: 1
RE: Microjet - 9/19/2003 11:37 PM
T28pilot
Score: 100
Last Login: 5/30/2013
Status: offline
I also have one in the works. I have found this site though. Check it out
http://www.philsrcworld2.fsnet.co.uk/microjet.htm
_____________________________
Disclaimer:- These are my views ..not the Views of RcUniverse or any of its employees..all views of MINE are Just that..Mine..Unless it is a bad post in my little part of the Forum..then i have to do my job
Hide Signatures
(in reply to aerodynamic18)
       Post #: 2
RE: Microjet - 9/20/2003 6:13 AM
daveslats
Score: 100
Last Login: 12/15/2009
Status: offline
Hi Aero,
I've had a microjet for about a month now. Great fun, indestructible (not that I've had any crashes) but it sure survived the first two launches very well. Seems that if you don't launch it either straight out or slightly nose down the thing just wants to fly into the ground. There're quite a few posts that describe this very phenomenon, including tPhil's site. But once that is overcome, I've had nothing but success and a whole heap of heart-thumping fun! I have mine set up standard, but use a 9-cell AE1100 brick pack (5+4), which fits really nicely way back in the fuse.
Some of the guys seem to use prop adaptors, but I'm still using the original Gunther stick on prop 15 flights later. I didn't even use epoxy, just a little spit to help it on, and then push the prop fully on.
You've got a great plane there. Take a pair of binoculars with you on first flight, cos you just may lose it, it gets small so quickly!!
Hide Signatures
       Post #: 3
go for Projeti - 9/22/2003 5:18 PM
Henke Torphammar
Score: 100
Last Login: 6/19/2013
Status: offline
Micro jet is no good, does´t fly that well...
I would´t call it indestructible.... infact it breaks pretty easy, but CAs togeather again just as easy... with only a cosmetic loss.
I would rather reccomend a Projeti (http://www.hobby-lobby.com) it flies much better.
/Henke
www.youtube.com/henke2
Swist F5D, Lambert Kolibri T25 - 310mph 2012
Hide Signatures
(in reply to daveslats)
       Post #: 4
RE: Microjet - 10/10/2003 3:34 AM
3dbatixkid
Score: 100
Last Login: 11/8/2004
Status: offline
friend of mine has a Micro Jet with a mega-motor in it, and it was clocked at 108mph :O
www.3dbatix.com
Hide Signatures
       Post #: 5
RE: Microjet - 10/10/2003 5:43 PM
Henke Torphammar
Score: 100
Status: offline
Mine had a 16/15/3, 8 cells, 120km/h
think a projeti would be even faster
/Henke
Hide Signatures
(in reply to 3dbatixkid)
       Post #: 6
RE: Microjet - 10/12/2003 2:11 AM
Wingman33
Score: 100
Last Login: 8/18/2004
Status: offline
Short wing span makes it a very unstable flier,with the 400 gunther prop and small wing area makes it a underpowered brick. Keep some CA and Kicker handy !! But to all you guys that say you love yours more power to you**** (and it was clocked at 108mph) :O Aw that aint nuthin!! Mine was doing 109mph wene it roll rated its --- rite into the ground WOO HOO!!
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Wingman33 -- 10/12/2003 1:07:25 AM >
Hide Signatures
       Post #: 7
RE: Microjet - 11/22/2003 11:04 PM
robinsphillips
Score: 100
Last Login: 6/2/2007
Status: offline
Heres a picture of mine, flys ok, not great mind, fun never the less.
http://www.geocities.com/rcsoaringhk/
Hide Signatures
(in reply to Wingman33)
       Post #: 8
RE: <span class= - 12/8/2003 10:55 AM
Rappy Pappy
Score: 100
Last Login: 10/21/2005
Status: offline
The microjet is a great plane to fly. However it needs at least an intermediate level pilot comfortable with small and fast planes.
I am flying one with an Aveox brushless motor set up and this plane is out of this world.
Hand launching needs a fair bit of care and requies a firm throw at a 30 degree angle.
Hide Signatures
(in reply to robinsphillips)
       Post #: 9
RE: <span class= - 12/8/2003 11:15 AM
gusser
Score: 100
Last Login: 2/27/2012
Status: offline
HEY FOLKS JUST WON A MICRO JET IN A RAFFLE...WHAT KIND OF PAINT CAN ONE USE TO TOUCH IT UP A BIT?????? GUSSER
Hide Signatures
       Post #: 10
RE: <span class= - 12/8/2003 11:18 AM
gusser
Score: 100
Status: offline
HEY PAPPY ANY SUGGESTIONS ON WHAT TYPE OF PAINT TO USE WITH THE MICRO?????? GUSSER
Hide Signatures
(in reply to gusser)
       Post #: 11
RE: <span class= - 12/8/2003 2:16 PM
Henke Torphammar
Score: 100
Status: offline
fly first, then paint I guess any aerosol can would work, the elapor can take CA glue and "oil" based paint
/Henke
/Henke
Hide Signatures
       Post #: 12
RE: <span class= - 12/8/2003 6:26 PM
gusser
Score: 100
Status: offline
THANKS HENKE WILL DO....GUSSER
Hide Signatures
(in reply to Henke Torphammar)
       Post #: 13
RE: <span class= - 12/21/2003 9:17 PM
SJN
Score: 105
Last Login: 6/20/2013
Status: offline
Flown mine 6 times with the stock sp400
It flys great.
Now I want some brushless action!
Any ideas for a good brushless setup that can use my KAN 1050 bats that take up to 18-20 amps ?
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 14
RE: <span class= - 12/22/2003 8:30 AM
Henke Torphammar
Score: 100
Status: offline
quote:
ORIGINAL: SJN
It flys great.
sure SJN
http://henke.rchomepage.com/video/ujet.wmv
same weight as sp400, better power clocked at 120km/h goes almost stright up. also fun to do touch n goes from short grass
/Henke
Hide Signatures
(in reply to SJN)
       Post #: 15
RE: <span class= - 12/22/2003 4:11 PM
SJN
Score: 105
Status: offline
Henke, what is your amp draw with the mega ?
It sure flys nice :-)
SJ.
Hide Signatures
       Post #: 16
RE: <span class= - 12/24/2003 5:45 AM
Henke Torphammar
Score: 100
Status: offline
18A (+1-0)
/Henke
Hide Signatures
(in reply to SJN)
       Post #: 17
RE: <span class= - 12/25/2003 3:23 AM
Sonic358
Score: 100
Last Login: 1/21/2004
Status: offline
any one know where to get the props for the micro-jet?
Hide Signatures
       Post #: 18
RE: <span class= - 1/7/2004 9:06 PM
SJN
Score: 105
Status: offline
Get the Graupner CAM 4,7 x 4,7 !
flys realy nice on the stock setup.
I took a video of my latest flight.
6,5mb on a 128kbit connection
http://bornholm.adsl.dk/modelfly/files/Microjet/MJVideo.WMV
had a guest fly in too :-)
SJ.
Click for fullsize
Hide Signatures
(in reply to Sonic358)
       Post #: 19
RE: <span class= - 2/4/2004 10:13 AM
kmccoy1023
Score: 100
Last Login: 9/30/2006
Status: offline
SJN, what size battery pack are you using in your Microjet? I watched your video.. your's flew well on launch...
Kmccoy
Hide Signatures
(in reply to SJN)
       Post #: 20
RE: <span class= - 2/5/2004 3:34 AM
SJN
Score: 105
Status: offline
Hi
Im using KAN 1050 cells, and the stock gunther again. The CAM props break all the time on me!! sp400 6V
Flew from a large hill this week. I took a video of it
4mb video: http://bornholm.adsl.dk/modelfly/files/Microjet/mjtop.WMV
1,8mb low quailty version of the same video:
http://bornholm.adsl.dk/modelfly/files/Microjet/mjsk.WMV
SJ.
Click for fullsize
Hide Signatures
(in reply to kmccoy1023)
       Post #: 21
RE: <span class= - 2/5/2004 4:40 AM
mglavin
Score: 100
Status: offline
We have the Microjet, RTF model, stock motor and prop. We have several different Lithium packs and find a 3S, 11.1V 1200mAh Lithuim works best. The Microjet is loads of fun and incredibly fast for a box stock electric model. We’re very happy with the flight envelope. I was out flying the Microjet this afternoon in the wind; down wind passes were ballistic... Still using the stock prop and all after about forty flights... This thing does take above average skills to pilot IMO.
I'm going to try an Astroflight brushless in the beast next with a 4.9x4.9 prop.
As mentioned you have to launch the Microjet at about 70 degrees with a hefty toss. Until you’re used to the model I'd suggest getting someone else with a good arm to throw it for you.
Another thing that seems to be pretty common is the ailevons need to be adjusted up approximately 2mm from what appears to be a neutral location.
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
Hide Signatures
(in reply to SJN)
       Post #: 22
RE: <span class= - 2/8/2004 8:38 PM
Matt G
Score: 100
Last Login: 7/20/2006
Status: offline
Yeah, they are a blast! I have 2, one for getting practice stock and one painted up going brushless. Was going to use mega, but my lhs now has himax. Cant wait!!!
Click for fullsize
Yeah, I can prolly jump that.
Hide Signatures
(in reply to mglavin)
       Post #: 23
RE: Building Instructions Microjet - 2/16/2004 7:41 PM
ZERO GRAVITY
Score: 100
Last Login: 7/27/2004
Status: offline
Hi,
I purchased a microjet yesterday (still needs assembling) from someone who didn't have the building instructions anymore . Does anyone have a set of building instructions or do you know where I can find these on the web ?
Cheers
Hide Signatures
(in reply to Matt G)
       Post #: 24
RE: Building Instructions Microjet - 2/18/2004 11:11 PM
SJN
Score: 105
Status: offline
I just built Canards on mine
I hope its slow flying properties wil be better....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to ZERO GRAVITY)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.531RCU1
