Tamiya King Tiger Help    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> Tamiya King Tiger Help
Page: [1]
Login
Tamiya King Tiger Help - 8/22/2012 2:08 PM
TigerTankMan
Score: 100
Last Login: 5/19/2013
Status: offline
Hi guys,
I recently aquired a Tamiya King Tiger and i was hoping someone could help solve an issue for me.
I did try searching for this issue but had no luck finding anything.
I have the cheap Futaba 4YF 'Skysport TX with the R136F receiver. I have been through the set process on the DMD and i cannot get recoil or muzzle flash to work.
When i flick the test switch on the MF01 they both fire and work OK - just not from TX.
Everything else (forward/back/turret rotation/barrel elevation) is fine. Is there a step i have missed or do i need a better TX or something?
I really appreciate any help guys as i am a complete newbie when it comes to Tamiya 1:16.
Hide Signatures
       Post #: 1
RE: Tamiya King Tiger Help - 8/22/2012 2:34 PM
Panther F
Score: 135
Status: offline
I'm using the newer RX 168DF in mine and have no problems at all and I'm not a radio magician either.
Try it as I think that number you have has been discontinued.
~ Jeff
Hide Signatures
(in reply to TigerTankMan)
       Post #: 2
RE: Tamiya King Tiger Help - 8/22/2012 10:38 PM
thecommander
Score: 121
Status: offline
Since you have rotation and traverse (The elev/trav. motors do run right? Not just make sound from the speaker?) there should be little doubt about the joystick not working. Or the Rx for that matter. Double check your work step by step starting with the communication cable and the Rx wires (in proper order). Most importantly...before running the Tamiya set-up....double check that the trim tabs levers are centered to zero trim. Then run the full set-up in your KT build manual...you should have no sound from the speaker while running set-up. Does the speaker make the main gun sound while the strobe and recoil fail to work? On that I am unclear.
_____________________________
Join us at NEAD: http://groups.yahoo.com/group/queenspanzergroup/
He who ends up with the most toys wins!!!
Hide Signatures
(in reply to Panther F)
       Post #: 3
RE: Tamiya King Tiger Help - 8/23/2012 2:59 AM
yellowshaker
Score: 183
Last Login: 5/20/2013
Status: offline
All I can suggest along with the information already provided is the following tidbit. When you do the programming procedure, as stated, make sure the trims are centered. After that, only move the sticks about halfway through the range of travel from center position. This will allow you to make sure that when the throttle is pushed all the way that the main gun will fire and all the way down, the MG will fire without ever having to move the trims from the center position. Hope this helps. Let us know if you geet it going.
Armorcreations.weebly.com
Hide Signatures
(in reply to thecommander)
       Post #: 4
RE: Tamiya King Tiger Help - 8/23/2012 9:47 AM
TigerTankMan
Score: 100
Status: offline
Hi guys,
Problem seems to have solved itself.
I took your advice and retraced my steps - i think i was doing the set up process incorrectly.
Instead of moving the stick from top to bottom i was moving it from center.
Thanks agian for the help guys - really appreciated.
Hide Signatures
(in reply to yellowshaker)
       Post #: 5
RE: Tamiya King Tiger Help - 8/24/2012 12:56 AM
thecommander
Score: 121
Status: offline
No worries mate.....that is what we are here for. Bob
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.188RCU1
