ZENOAH G26 RPM    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> ZENOAH G26 RPM
Page: [1]
Login
ZENOAH G26 RPM - 8/24/2012 10:38 PM
aframe2
Score: 100
Last Login: 5/14/2013
Status: offline
I have a Zenoah G-26, turning a 18x8 Xoar prop. I can't get any more than
6500 rpms. Is this too much prop for this engine? If so what size prop
are you running with this engine? The instructions say the engine should
be turning between 7500-8500 rpms.Thanks Aframe2
_____________________________
aframe2
Hide Signatures
       Post #: 1
RE: ZENOAH G26 RPM - 8/24/2012 11:22 PM  1 votes
tkg
Score: 657
Last Login: 5/19/2013
Status: offline
The bench mark prop is an APC 16-8 @8900 rpm. You need to get one and see what your engine does. If your engine is close.then you need to resize the Xoar till the engine is in its power band.
IMHO an 18-8 Xoar is way to much prop.
TKG
Too much power is just about right.
Hide Signatures
(in reply to aframe2)
       Post #: 2
RE: ZENOAH G26 RPM - 8/25/2012 2:51 PM  1 votes
pe reivers
Score: 646
Last Login: 5/18/2013
Status: offline
18x8 is just right for an MVVS 26 spinning at about 7600 rpm with the standard MVVS tuned pipe. A lot depends on the muffler though, and the engine will only get about 6800 on a side dump muffler.
At 6500 rpm on your engine, which likes to run a bit more rpm than MVVS, the prop may have very decent pull and be just what you need. You can always shorten the prop to 17" diameter as TKG suggested.
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to tkg)
       Post #: 3
RE: ZENOAH G26 RPM - 8/25/2012 5:11 PM
aframe2
Score: 100
Status: offline
Thanks, I originally had a 16x8 prop and was getting 8500 plus rpms.
My concern was that I have this engine on a Pacific Aeromodel Gee
Bee Y 1/4 scale, and the cowl is huge. There wasn't much prop past the outside
diameter of the cowl, so I changed to a 18x8. Haven't flew the plane
with this prop, was concerned about the power with so much less rpms.
I have a 17x6 prop on order that I will try, if it doesn't give me at least
7500 rpms I will return to the 16x8. Thanks for the advice. Aframe2
aframe2
Hide Signatures
(in reply to pe reivers)
       Post #: 4
RE: ZENOAH G26 RPM - 8/25/2012 10:38 PM
capnduane
Score: 105
Status: offline
I am running a 18x8 on my Pac aero GBY, but I have a Quadra 35 in it. Flys it great. I have a Zenoah 26I in my 1/4 scale Fokker D8, 17x8 prop does good.
Hide Signatures
       Post #: 5
RE: ZENOAH G26 RPM - 8/26/2012 3:27 PM
dadragon
Score: 112
Last Login: 3/14/2013
Status: offline
try dropping down to an 18-6.my G-23 pulls a 1/4 scale cub around just fine on that set up.
Hide Signatures
(in reply to capnduane)
       Post #: 6
RE: ZENOAH G26 RPM - 8/26/2012 10:30 PM  1 votes
pe reivers
Score: 646
Status: offline
The 6"props scream their heart out, and just fail to perform as well as higher pitched props, unless you want to fly 3D. Even then the 6" pitch is questionable.
Hide Signatures
(in reply to dadragon)
       Post #: 7
RE: ZENOAH G26 RPM - 8/29/2012 5:46 PM
hobby_man
Score: 105
Last Login: 3/23/2013
Status: offline
I had an xroar 18 x 6 7500 rpm on my g-26 ei
now I have an 17x 8 7600 rpm and more pull and my YAK
has anyone changed out the wt644 carb for a wt813 ? the wt-813 has an accelrator pump feature
Is anyone using these carbes with the primer buld?
Hide Signatures
       Post #: 8
RE: ZENOAH G26 RPM - 9/18/2012 1:55 AM
hobby_man
Score: 105
Status: offline
I had an xroar 18 x 6-7900 rpm on my g-26 ei after so more tuning
Hide Signatures
(in reply to hobby_man)
       Post #: 9
RE: ZENOAH G26 RPM - 9/22/2012 5:15 PM
dadragon
Score: 112
Status: offline
I went to a 16x10 on the G23 and made it pull a little better,I fly at about 5000',I started useing LL100 avgas,nice improvment.temp and humidity plays a big factor for me,the plane is 16LBS,I think I found the rite combination.I tried the 18x6 its not for this plane.I'm am going to a G26 soon.
Hide Signatures
       Post #: 10
RE: ZENOAH G26 RPM - 9/23/2012 1:41 PM
warbird_1
Score: 159
Status: offline
way to much prop. and go to an APC they are the best prop hands down 16x8 is what i would start at. don't worry about the cowl. it you seen pics of the full scale,it hardly has any prop out the cowl dia. you need a prop that the engine likes , not what the cowl likes. WB_1
Scratch Builders make their own destiny
Hide Signatures
       Post #: 11
RE: ZENOAH G26 RPM - 9/23/2012 4:56 PM
dadragon
Score: 112
Status: offline
Warbird;I fly scale dont do flips and twirls the landing gear for the most part looks at the ground,I'm kinda like the AD-1 skyraider I go low and slow.
Hide Signatures
(in reply to warbird_1)
       Post #: 12
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> ZENOAH G26 RPM
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
