how to make my savage x wider ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> how to make my savage x wider ? Page: [1]
Login
how to make my savage x wider ? - 8/25/2012 5:33 PM
sdi87
Score: 100
Last Login: 9/28/2012
Status: offline
 hi im new the site i have been messing with rc stuff for about 5 years now snd i own two savages a 25 and an x i like the savage x alot but it tends to flip over real easy i was just wondering if there is a kit to make it wider ? i have also heard of people using a arms off of the savage xl and i am assuming the driveshafts ,if thats possible, any help would be greatly appreciated thanks.
Hide Signatures
       Post #: 1
RE: how to make my savage x wider ? - 8/25/2012 6:02 PM
74sickness
Score: 100
Last Login: 11/22/2012
Status: offline
You could put sway bars for better handling not sure about the flipping though.
Hide Signatures
(in reply to sdi87)
       Post #: 2
RE: how to make my savage x wider ? - 8/25/2012 6:16 PM
sdi87
Score: 100
Status: offline
i have thought about that, but how effective are they ? thanks tho
Hide Signatures
(in reply to 74sickness)
       Post #: 3
RE: how to make my savage x wider ? - 8/25/2012 7:07 PM
jeepster820
Score: 100
Last Login: 6/18/2013
Status: offline
 hi you could use xl axle shafts as they are longer and but you also need to change the dogbones and the dive shafts as the dog bones are thicker. But if its a newer x it should already have the beefier shafts so will only need the axle shafts
Hide Signatures
(in reply to sdi87)
       Post #: 4
RE: how to make my savage x wider ? - 8/25/2012 7:25 PM
sdi87
Score: 100
Status: offline
yea its a 2012 model, so what all would i need from the xl to do that ? thanks
Hide Signatures
(in reply to jeepster820)
       Post #: 5
RE: how to make my savage x wider ? - 8/26/2012 4:13 AM
74sickness
Score: 100
Status: offline
I dont have sway bars yet but we will see when i get them.
Hide Signatures
(in reply to sdi87)
       Post #: 6
RE: how to make my savage x wider ? - 8/26/2012 7:41 AM
BKoz559
Score: 164
Last Login: 5/22/2013
Status: offline
I was under the impression that all Savages ride on the same suspension arms; except for the "E-Savage."  In any case, shouldn't 2 sets of these do the job?
Click to see fullsize image.
Click for fullsize
_____________________________
RDD Raceway Hobby Shop / Madera, CA
Slot Cars - RC - Models - Toys
Hide Signatures
       Post #: 7
RE: how to make my savage x wider ? - 8/26/2012 1:24 PM
jeepster820
Score: 100
Status: offline
 all you need is one set of these  http://www.ebay.co.uk/itm/NEW-HPI-Savage-XL-HEAVY-DUTY-WIDE-DRIVE-AXLES-SHAFTS-/310425872831?pt=Radio_Control_Parts_Accessories&hash=item4846d2e9bf#ht_785wt_1031 and you shoul be fine as long as you have the thicker shafts check in your manual to check the part no to make sure
Hide Signatures
(in reply to sdi87)
       Post #: 8
RE: how to make my savage x wider ? - 8/26/2012 5:34 PM
sdi87
Score: 100
Status: offline
ok cool yea i bought the xl frame tvp rails also im gona make it longer i ordered everything last night , thanks for the help guys
Hide Signatures
       Post #: 9
RE: how to make my savage x wider ? - 8/26/2012 6:40 PM
SLAYERDUDE
Score: 414
Last Login: 1/9/2013
Status: offline
quote:
ORIGINAL: sdi87
Did you get the longer rear driveshaft to go with the XL TVP's?
Hide Signatures
(in reply to sdi87)
       Post #: 10
RE: how to make my savage x wider ? - 8/26/2012 8:01 PM
steed2-inactive
Score: 166
Last Login: 12/18/2012
Status: offline
quote:
ORIGINAL: SLAYERDUDE
quote:
ORIGINAL: sdi87
nah, just run fwd.
oversteer scares passengers, understeer scares drivers!-savagex,-savagexl,-savageflux,-revo3.3,-tmaxx3.3,-losi aftershock lt
Hide Signatures
(in reply to SLAYERDUDE)
       Post #: 11
RE: how to make my savage x wider ? - 8/26/2012 10:53 PM
sdi87
Score: 100
Status: offline
yea it came with the longer driveshaft , if im not changing motor i shoulnt need the beefier diff cups right ? i mean eventually i will change the motor and when i do ill get them.
Hide Signatures
(in reply to steed2-inactive)
       Post #: 12
RE: how to make my savage x wider ? - 8/26/2012 11:09 PM
llkoolskillet
Score: 100
Last Login: 6/19/2013
Status: offline
To properly convert to the XL you need the following items
XL TVPs
XL rear center dogbone
XL/Flux Diff cups
XL Ext drive cups (the ones pictured above with the purple spacers)
XL/Flux axles
XL motor plate (not necessary tho)
Thats everything needed to convert to XL. If you upgrade to the ext drive cups you WILL need the diff cups and axles. There is no way around this, the X axles will bind and fall out
ERCM Picco/ Endbleed power should be the only combo allowed in a Savage.
Hide Signatures
(in reply to sdi87)
       Post #: 13
RE: how to make my savage x wider ? - 8/27/2012 1:51 AM
sdi87
Score: 100
Status: offline
ok thanks guys
Hide Signatures
(in reply to llkoolskillet)
       Post #: 14
RE: how to make my savage x wider ? - 8/27/2012 2:39 AM
sdi87
Score: 100
Status: offline
can u guys give me the part number for the diff cups, i want to make sure i get the right thing. the ones that go from the differential to the axles, not center axles
Hide Signatures
(in reply to sdi87)
       Post #: 15
RE: how to make my savage x wider ? - 8/27/2012 7:25 AM
SLAYERDUDE
Score: 414
Status: offline
Just buy some Flux / XL BP diff bulks off ebay, or look at the XL manual and use them.
Best bet is to get flux or newer XL bulks with BP diffs, 29/9 and not the 43/13.
They will come with the larger diff cups either way.
Hide Signatures
(in reply to sdi87)
       Post #: 16
RE: how to make my savage x wider ? - 8/29/2012 1:57 PM
BKoz559
Score: 164
Status: offline
That's a good point; I didin't think about the cups since I installed BP diffs anyhow.  If you use the 29/9 gearset then everything will match up and you should never have diff issues.
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
