Mini Ultra Stik Conversion    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Electrics to Glow Conversions >> Mini Ultra Stik Conversion
Page: [1]
Login
Mini Ultra Stik Conversion - 8/27/2012 1:42 AM
ckreef
Last Login: 5/17/2013
Status: offline
Since my last conversion was a total bust (Maxford USA - Gee Bee "Y"), I stripped all the parts out of it and did this Mini Ultra Strik EP conversion.
Eflite Mini Ultra Stik EP
Converted using OS .25 LA
9 x 5 wood prop
4 oz tank
9 gram servos
1100-mah 6-volt NIMH battery
Spektrum receiver.
AUW came out at 32oz
Last Sunday night I ordered the plane from Horizon Hobby. It was shipped on Monday. It arrived on Wednesday. I started the conversion and finished it up Last night (Saturday). This was a very easy converision. I took it to the field and even thought is was a bit windy with decently strong gusts I maidened it anyway. I got 3 flights in total.
Take off's were way crazy. They had a good bit of right angle thrust  built into the motor mount/frame area. In the future I am going to add a few washers to take out some of that right thrust in hopes of calming down ther takeoffs. Once in the air she flew great.  She had plenty of power. Seemed like unlimited vertical or at least vertical until I got uncomfortable with the altitude and then throttled back and let her dive out of the sky doing a few spins on the way down. The control throws even on low rates were more then adequete. Landings were smooth and gentle. Not sure why one would want to split the aileron into quad flaps but to each their own as I will keep it with full ailerons.. The rudder was more then adequate for decent ground handeling even with the tail skid. I really saw no need to convert it into a stearable tail wheel. The main gear wheels are a bit skinny and coupled with the light weight, it really didn't like taxing on the grass. Fater "Tundra" style tires might help that.
The next  few posts will be pics of the conversion.
This is a full pic of the Mini Ultra Stik Conversion.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: Mini Ultra Stik Conversion - 8/27/2012 1:47 AM
ckreef
Status: offline
I cut out the battery holder tray from the front compartment. I then reinforced the front compartment with some plywood strips and added a foam and velcro mounting system for the fuel tank. I used a 4oz flex tank. A 6oz tank was a smige big and I have yet to find a 5oz tank available for sale.
Click for fullsize
Hide Signatures
(in reply to ckreef)
       Post #: 2
RE: Mini Ultra Stik Conversion - 8/27/2012 1:51 AM
ckreef
Status: offline
The battery was installed about 1/2 way between the TE and the horizontal stabilizer inside the fuselage. I had to glue in place a plywood holding tray with a vecro strap in order to hold tyhe battery in place.
Click for fullsize
Hide Signatures
       Post #: 3
RE: Mini Ultra Stik Conversion - 8/27/2012 1:56 AM
ckreef
Status: offline
Here is the final electronics placement inside the main fuselage compartment. I am not fond of the quick connect type of servo/pushrod  holders but thats what came with the plane so with some blue locke-tite I used them anyway.
Anyway enjoy the pics and if I get a chance I will try and take a video at some time. This was a great conversion and would make an awesome first conversion for someone wanting to get into small glow planes. If you have any questions be sure to ask.
Click for fullsize
Hide Signatures
       Post #: 4
RE: Mini Ultra Stik Conversion - 8/27/2012 2:12 AM
Twin_Flyer
Last Login: 5/23/2013
Status: offline
Looks great ,looking forward to the flight video!
Bill S.
_____________________________
Carl Goldberg Ultimate Brotherhood #56
Ultra Sport Brotherhood #135
http://radiocontrolhobbies.freeservers.com
Hide Signatures
       Post #: 5
RE: Mini Ultra Stik Conversion - 9/2/2012 1:50 PM
Zampa
Last Login: 3/12/2013
Status: offline
 Hi everyone, I'm new I just bought a mini ultra stick (almost impossible to find here in Italy) to be converted with an Irvine 20 which is around 20 years old
I think I'm putting on a 9x4 prop, 4 oz fuel tank etc...
I'm so excited to bring back to life that engine
ckreef, have you reinforced the firewall or only the nose?
Thank you, and sorry for my not-so-good english
Hide Signatures
(in reply to Twin_Flyer)
       Post #: 6
RE: Mini Ultra Stik Conversion - 9/7/2012 2:35 AM
ckreef
Status: offline
quote:
ORIGINAL: Zampa
The Mini UltrStik comes with 2 fire wall plates for different electric setups. I made a 3rd firewall plate (same size as theother 2) from plywood and covered it in white covering. Drilled the holes for the engine mount and then epoxied that in the proper position. When you get the Mini you'll understand exactly what I'm talking about.. Also reinforced the 2 sides and floor of what will now be your fuel tank compartment with 1/2" wide strips of plywood. There is a good bit of right thrust built into the frame where your firewall plate goes. I used some small washers when mounting the engine mount to remove some of that right thrust in order to get it to track better down the runway on takeoff.
Choose your fuel tank carefully as there is not a lot of room in there. I used a 4 oz flex tank surrounded on the bootom and sides w/ 1/4" foam then velcro'ed in place.
The Rx battery I used was a long, thin, 6v 1100 mah NIMH and installed per the pictures.
I've flown it 5 times since my last post including 2 tanks of fuel about 2 hours ago. She is a bit nose heavy even with the battery installed way back where it is. Some time in the near future I will add a little tail weight. On a calm day (no head wind) she lands a bit hot and if you slam her down the main gear will flex a lot and you might have to flex it back into shape.
With the .25 LA she is a fast little plane with unlimited vertical, very manuverable and a blast to fly.
< Message edited by ckreef -- 9/7/2012 2:37 AM >
Hide Signatures
(in reply to Zampa)
       Post #: 7
RE: Mini Ultra Stik Conversion - 9/10/2012 1:39 AM
ckreef
Status: offline
 Last night I added 1 oz of lead weight to the underside of the tail just between the 2 rudder mounting bolts. This greatly improved the CG and she flys better then ever. She also does a little better taxing through the grass.
Flew another 3 tanks earlier with the new weight configuration.
Hide Signatures
       Post #: 8
RE: Mini Ultra Stik Conversion - 9/16/2012 4:06 AM
ckreef
Status: offline
  I taxi through grass to a rubber mat runway. It's actually an old conveyor belt off of a large newpaper printing press. The problem is the rubber mat is slick and the tail skid doesn't do well on it. Last night I installed a stearable tail wheeel. I used a Du-Bro Tailwheel Bracket (part # 375) and the associated Du-Bro Tailwheel for that bracket (can't find the part # but rubber wheel and aluminum hub). This is the bracket and tailwheel for a .40 sized plane which is a little big but..........
The front hole of the bracket is the correct length to match up with the back bolt that secures the vertical/horizontal stabilizers to the the airframe. just ream out the front bracket hole a little and install it with the rear bolt/nut. This correctly aligns the tail wheel wire with the rudder/elevator hinge line. I used a long thin screw to secure the back bracket hole through the horizontal stabiler into the air frame.  This made take off, landing and taxing much more stable and manageable.  Pictured below is the tail wheel assembly along with the extra weight for CG.
Also I started out using a Zinger 9x5 wood prop. I then switched to a Master Airscrew 9x5 prop which I balanced as close as humanly posible. Immediatly I noticed the Master Airscrew prop vibrated and shook the airframe much more then the wood prop. After 2 flights I switched back to the wood prop.
I flew another 3 flights after work today (yea sucks I had to work on Saturday). The more I tweak this plane the more I like it. I already have metal gear servos for the rudder and elevator. I have order metal gear servos for the ailerons and will install them as soon as they arrive.  She is a fast flyer (for her size) and I tend to fly the "snot" out of her so I don't want to strip the aileron servos in mid-flight causing a crash like I did with the electrostik conversion.
Click for fullsize
Hide Signatures
       Post #: 9
RE: Mini Ultra Stik Conversion - 9/29/2012 1:13 AM
ckreef
Status: offline
After about 30 dead stik landings and a fuel line reconfiguration I think the motor is fully broken-in and running right (finally). She starts up instantly and flys for 6 min at WOT on a 4oz tank leaving me about 1/4 tank after landing.
I also replaced my aileron servos after one totally stripped in-flight. I knew something wasn't right when the riffle rolls turned into barrel rolls Now she has digital, metal gear servos on all the control surfaces (except throttle).
I love my MiniStik.
Hide Signatures
       Post #: 10
RE: Mini Ultra Stik Conversion - 10/15/2012 4:18 AM
ckreef
Status: offline
Here are a  couple of pics of her flying from our clubs burger & dog meeting.
Click for fullsize
Hide Signatures
       Post #: 11
RE: Mini Ultra Stik Conversion - 10/15/2012 4:20 AM
ckreef
Status: offline
One pic per post in this forum sucks
Click for fullsize
< Message edited by ckreef -- 10/15/2012 4:21 AM >
Hide Signatures
       Post #: 12
RE: Mini Ultra Stik Conversion - 11/7/2012 2:47 AM
ckreef
Status: offline
I did the same TE fix on the Mini that I did on my 25e conversion. I did this one 1st and the 25e fix came out better but this still gets the job done.
Here is the fix preped. You can see the soft balsa crushed by the washers/wing bolts.
Click for fullsize
< Message edited by ckreef -- 11/7/2012 2:48 AM >
Hide Signatures
       Post #: 13
RE: Mini Ultra Stik Conversion - 11/7/2012 2:49 AM
ckreef
Status: offline
This is the TE fix epoxied in place. Yup the pic sucks.
Click for fullsize
< Message edited by ckreef -- 11/7/2012 2:50 AM >
Hide Signatures
       Post #: 14
RE: Mini Ultra Stik Conversion - 11/7/2012 2:52 AM
ckreef
Status: offline
At this point I have flown this plane easily over sixty flights. I can't wait to finish up the 25e conversion to give the Mini a rest. Here is a pic next to his big brother.
Click for fullsize
Hide Signatures
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
