tornado rpx tires and axles    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Tornado XP
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> tornado rpx tires and axles
    Page: [1]
    Login
    tornado rpx tires and axles - 8/27/2012 4:12 PM
    davidgp
    Score: 100
    Last Login: 2/13/2013
    Status: offline
    I want to fit much larger tires on my Tornado EPX. The motor has already been updraded and I'll adjust the gear ratio as necessay. What is the hex size and offset for the Tornado? Can you suggest a monster truck tire that fits.
    Oh yes, what about upgrades for things like axles. Are they available?
    David
    Hide Signatures
           Post #: 1
    RE: tornado rpx tires and axles - 8/27/2012 11:47 PM
    nitrosportsandrunner
    Score: 296
    Last Login: 5/25/2013
    Status: offline
    quote:
    ORIGINAL: davidgp
    David
    redcat has CVD driveshafts for upgrades. I prefer to use bits of nitro fuel tubing inside the drive cups to lessen the play of the dogbones. This makes them last alot longer.
    On to tires.
    Tricky part is the right rim. The offset needs to be such that the hex of the rim is to the inside (towards the chassis) so that it doesnt rub against the hub or a-arm.
    I used traxxas rustler REAR tires. Now, I had to mod the tires on the front. These traxxas rims have a good offset, but have plastic "fins" on the inside of the rim. For them to work on the front, I had to cut away these fins.
    I used Proline dirt hawg 2.2 tires on them.
    Add on a heat sink to the motor, and it will compensate for the larger tires. tires larger than the ones I put on MAY rub the body when you turn.
    See my thread "Cat 5 tornado"
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    _____________________________
    Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
    Hide Signatures
    (in reply to davidgp)
           Post #: 2
    RE: tornado rpx tires and axles - 8/28/2012 12:53 AM
    Dads like rc too
    Score: 540
    Status: offline
    I put Proline 2.8 Desperado's and Dirt Hawgs on my former Tornado S30
    Click for fullsize
    Caldera 10e : Volcano EPX : Monsoon XTR : Sumo x2 :
    Hide Signatures
           Post #: 3
    RE: tornado rpx tires and axles - 8/28/2012 1:50 AM
    Score: 296
    Status: offline
    quote:
    ORIGINAL: Dads like rc too
    those look sick!
    2.8 rims probly work better...my rim is close to the A-arm when I turn the wheel. A 2.8 rim shouldnt do that.
    Hey Dads', whats the total diameter of your wheel/tire combo?
    I like the look. I went with the dirt hawgs cause I new my tornado would be on pavement mostly and I needed a tire that wouldnt wear quicly. The dirt hawgs work well on pavement, but still have enough deep tread for offroading when I feel like it.
    Hide Signatures
    (in reply to Dads like rc too)
           Post #: 4
    RE: tornado rpx tires and axles - 8/28/2012 2:47 AM
    Dads like rc too
    Score: 540
    Status: offline
    quote:
    ORIGINAL: nitrosportsandrunner
    those look sick!
    The 2.8 rims worked perfect. Sorry but that project has been sold so I can't measure but I will tell you the 2.8 dirt hawgs were buggy tires so for others reading this that means the sidewall was shorter. So if you took a 2.2 dirt hawg from a monster truck and put it next to the 2.8 buggy tire, the diameter was nearly identical. And also, yes the bigger tires are exactly what the Tornado needed to make it a real backyard basher. The added ground clearance and tire size just made it a much more versatile buggy. Of course for those interested in doing this a gearing change will be mandatory.
    Hide Signatures
    (in reply to nitrosportsandrunner)
           Post #: 5
    Page:   [1]
    Page: [1]
    Tornado XP
  • Read Full Review
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.250RCU1
