Carf Paint match    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Carf Paint match
Page: [1]
Login
Carf Paint match - 8/28/2012 1:54 AM
GSR
Last Login: 5/18/2013
Status: offline
If anyone is interested I have found the paint match for the commonly used red on Carf models. Eurosport, Old flash, Rookie and probably a few others. It is a GM color and is called Torch Red. Used on 1995-about 2002 or so Corvettes. It is a perfect match and any paint store can mix it with this info. If you want it in a rattle can DupliColor used to sell it but no longer make it. You can still find it around if you search. Scotty
_____________________________
"If you ain''t crashed-You ain''t flown"
Hide Signatures
       Post #: 1
RE: Carf Paint match - 8/28/2012 7:21 AM
Andrew Bailey
Status: offline
Brilliant. Thanks for this. Did you work out a match for the white paint they use?
Cheers
Andrew
Hide Signatures
(in reply to GSR)
       Post #: 2
RE: Carf Paint match - 9/6/2012 12:16 PM
Andrew Bailey
Status: offline
Hi GSR.
It looks like there are two versions of GM Torch Red. One has code 70-9075 and the other is 70-9076. Do you happen to know which of these is the match?
Andrew
quote:
ORIGINAL: GSR
Hide Signatures
(in reply to GSR)
       Post #: 3
RE: Carf Paint match - 9/6/2012 3:24 PM
SPLIT S
Last Login: 5/11/2013
Status: offline
The four digit codes are used to signify at what plant the car was manufactured at, to differentiate between the car and truck code and sometimes whether the car was made in the States or overseas. As a general rule of thumb the lower the number usually refers to the most widely used version of the color. Home sick from work today, can look both codes up tomorrow and tell you for certain.
Dan
Hi Dad, Doing anything? Want to go to the field?
Hide Signatures
(in reply to Andrew Bailey)
       Post #: 4
RE: Carf Paint match - 9/6/2012 5:10 PM
Andrew Bailey
Status: offline
Cool. Thanks for that.
Hide Signatures
(in reply to SPLIT S)
       Post #: 5
RE: Carf Paint match - 9/7/2012 1:49 PM
SPLIT S
Status: offline
9075 is the correct code 70 for the given year range. WA9076 was used from 90-91 only, non clearcoat version of 9075.
Dan
Hide Signatures
       Post #: 6
RE: Carf Paint match - 9/7/2012 7:28 PM
GSR
Status: offline
Here is the match code for the red. Dont have the white as it was a scan gun match andthey did not write the code.Scotty
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 7
RE: Carf Paint match - 9/7/2012 7:40 PM
Andrew Bailey
Status: offline
Fantastic. I really appreciate you sharing that. I will finally be able to finish repainting the tail of my Flash.
Cheers
Andrew
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
