RE: Sig Ryan STA    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Sig Ryan STA Page: <<   < prev  23 24 [25] 26 27 28 29 30 31 32   next >   >>
Login
RE: Sig Ryan STA - 12/16/2012 1:47 AM
stuntflyr
Score: 137
Last Login: 6/18/2013
Status: offline
What size gasser does it take to replace a glow 60? 1.20? 20-26cc? How much more does it weigh? Is everyone of the opinion that the model needs noseweight so a gasser with it's larger physical size and additional battery weights are the way to go with the ST?
Chris...
Hide Signatures
(in reply to raptureboy)
       Post #: 601
RE: Sig Ryan STA - 12/16/2012 1:53 AM
VincentJ
Score: 160
Last Login: 6/17/2013
Status: offline
Thanks Robert, I appreciate all the kind words and thanks too to all for following this thread....the best is yet to come
What's on your build table Robert?
_____________________________
VJ
Hide Signatures
(in reply to acerc)
       Post #: 602
RE: Sig Ryan STA - 12/16/2012 1:54 AM
stuntflyr
Score: 137
Status: offline
I wonder if one could roll those wires so they are flatter?
Chris...
Hide Signatures
(in reply to VincentJ)
       Post #: 603
RE: Sig Ryan STA - 12/16/2012 2:00 AM
VincentJ
Score: 160
Status: offline
Chris, I debated with myself wheather or not to use the flat wires supplied in the kit, but in the end I went with what more appealed to me.  If this were going to be a true "scale" build I would have went with the flatter wire. I literally have hundreds of hours into this build and I probably have the same number of hours of debating and decision making that  went on in my head to get to where I am now... If at a later dater I want to make a more true to scale flying wire I can easily swap them out.
< Message edited by VincentJ -- 12/16/2012 3:17 AM >
VJ
Hide Signatures
(in reply to stuntflyr)
       Post #: 604
RE: Sig Ryan STA - 12/16/2012 2:04 AM
aframe2
Score: 100
Status: offline
VJ, I am going to build this same model this Winter. Are you saying that the flying wires are a rigid rod? Not a flexible piece of wire? Is that what the plans
for the kit call for, or is that a modification you made? Just curious. I've been taking notes for my build. I am currently putting together a Black Horse Ryan
Sta ArF. There was a thread on that build, but I think it has stalled. Aframe2
aframe2
Hide Signatures
(in reply to acerc)
       Post #: 605
RE: Sig Ryan STA - 12/16/2012 2:10 AM
acerc
Score: 221
Status: offline
Your welcome VJ. I'm building a Andy Sheber Pitts s1s over in RC Scale. Only been at it for a couple days.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to aframe2)
       Post #: 606
RE: Sig Ryan STA - 12/16/2012 2:12 AM
VincentJ
Score: 160
Status: offline
Airframe2, the plans call for a flat steel wire (about 1/8" wide)  that you would attatch the clevis to.  I substituted this with regular 2-56 steel rod.  My flying wires are fully functional.  I will post a photo later this evening on what was supplied in the kit so you can see.
< Message edited by VincentJ -- 12/16/2012 10:33 AM >
VJ
Hide Signatures
       Post #: 607
RE: Sig Ryan STA - 12/16/2012 2:21 AM
cublover
Score: 111
Last Login: 6/16/2013
Status: offline
I love this plane, I would have never cut the box open!!!!...plans are cheaper!!...hahahaha...I bet someday this plane would be worth more than you paid..
Life is to short,,, to fly slow planes!!!!!!
Hide Signatures
       Post #: 608
RE: Sig Ryan STA - 12/16/2012 2:51 AM
VincentJ
Score: 160
Status: offline
Airframe2, the first photo shows the stock flying wire (on bottom), the middle is the same wire turned to show its thickness, while the top wire is the 2-56 rod that I used.  The instructions say that this ( stock ) wire is made of aluminum, but it's not it's steel and can be soldered if you choose.
Click to see fullsize image.
Click for fullsize
Click for fullsize
VJ
Hide Signatures
       Post #: 609
RE: Sig Ryan STA - 12/16/2012 3:25 AM
raptureboy
Score: 183
Status: offline
WHAT! Your breaking scale!     You just gotta have the struts man, you better check your respirator I think you been sniffing that glue too much  Nice work on the wires though, I've been thinking about using the airfoil shaped tubing K&S makes.
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
       Post #: 610
RE: Sig Ryan STA - 12/16/2012 3:44 AM
raptureboy
Score: 183
Status: offline
The 20cc gassers are about equivelent to a 1.20 FS but a .60 2 stroke is just under 10cc. There are some 15cc gassers out there but the 20 seems to make the most sense all around for planes in the 10-15 lb range for scale flying. I have the DLE 20 in my 11 lb TF P-40 and it flys great at a little less than 3/4 throttle but put the petal to the metal and you have war power baby Them zeros don't what hit them. The weight of my DLE is 30 oz with muffler and ign. I actually had to mount my radio battery at the trailing edge area of the wing to get balance on my ryan, I hung it under the wing bolt plate.
quote:
ORIGINAL: stuntflyr
Chris...
Hide Signatures
       Post #: 611
RE: Sig Ryan STA - 12/16/2012 10:29 AM
VincentJ
Score: 160
Status: offline
Raptureboy, I did buy the K&S streamline tubing for the struts and even came up with a neat folding strut to make assembly at the flying field a bit easier, but still undecided at this point if it will go on.... we shall see.
You are right about sniffing the glue though....now what were we talking about and who are you?  AHHHHHHH.  LOL
VJ
Hide Signatures
       Post #: 612
RE: Sig Ryan STA - 12/16/2012 5:52 PM
VincentJ
Score: 160
Status: offline
This morning I made the last set of flying wire brackets for the trailing edge side of the wing.  Brackets are similar to what I made in the front except they are a different size.   I did not follow the instructions as they would have you make two separate brackets for each side (top and Bottom).  I combined them making one and believe it will be less prone for any type of movement.  I added a 1/4" x 1/2" balsa stock that I epoxied to the adjacent spar to further secure it between the bay.
Click for fullsize
Click for fullsize
VJ
Hide Signatures
       Post #: 613
RE: Sig Ryan STA - 12/16/2012 7:42 PM
VincentJ
Score: 160
Status: offline
Upper flying wires completed, here's how they look.  It occured to me that maybe you would want to see what I use to do my soldering with.  This Ultra Torch works very well for things like clevis' because a propane torch gives off too much heat and an electric soldering gun not enough.  Not very expensive and works super.  Good stocking stuffer from Santa!  Time to work on the lower flying wires but that means I have to assemble the landing gear first.  Not much left build wise, but plenty sanding wise...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
VJ
Hide Signatures
       Post #: 614
RE: Sig Ryan STA - 12/16/2012 10:24 PM
Jaybird
Score: 112
Status: offline
quote:
ORIGINAL: acerc
Oh come on! I know no one is going to scratch build this beautiful bird and go and put a oil spewing, covering soaking, wood drenching nitro engine on it!  ROTFLMAO
Sorry to dissappoint you Robert, but as you can see I'm not scratch building it as it's already built and covered. I also don't have any model gas engine experience or equipment but I do have a 2-stroke 60 and a four stroke 91 looking for a good home. The 91 looks like it will mount up quite nicely and the exhaust can be routed out the bottom of the ABS cowling without any cutting.
Do I have to resign my brotherhood membership?
Jaybird
Hide Signatures
(in reply to acerc)
       Post #: 615
RE: Sig Ryan STA - 12/16/2012 11:21 PM
VincentJ
Score: 160
Status: offline
All in good fun Jaybird.....
Spent some time in the workshop getting the landing gear sorted.  Earlier in the build I had made accommodations to alleviate some of the stress placed on the landing gear blocks and beef up the landing gear wire.   Now you can see how it all came together.  I added 3/32" music wire as an additional brace to the rear portion of the gear wire which in the morning will be married together with some braze rod.  All of this will be hidden from view by the spats shown in the plans.  This may just work...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by VincentJ -- 12/17/2012 12:10 AM >
VJ
Hide Signatures
(in reply to Jaybird)
       Post #: 616
RE: Sig Ryan STA - 12/17/2012 1:03 AM
acerc
Score: 221
Status: offline
What do you mean may...  Look's as if it already has.
Jaybird, It's all good my friend.
Robert
Hide Signatures
       Post #: 617
RE: Sig Ryan STA - 12/17/2012 1:44 AM
skylarkmk1
Score: 210
Status: offline
OK Guys,
I made it out to Creve Coeur Airport this morning and took about 100 photos of the ST-M (white with blue & yellow trim, posted earlier) with the Ranger engine. A few are below
P1 - Profile of N 48587 (yes that is an AN-2 in the far background)
P2 - No need to seal the gap, the elevator is similar
P3 - Top view of nose paint (de Havilland Dragon Rapide in background)
P4 - Top of wing paint, bottom has a similar paint scheme
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
(in reply to acerc)
       Post #: 618
RE: Sig Ryan STA - 12/17/2012 1:51 AM
Jaybird
Score: 112
Status: offline
Whew! You guys are pretty serious about this stuff so I wasn't sure.
VJ - I ws thinking of doing something similar to mine. It wouls seem to me that if the gear did flex rearward that it could tear out the underwing bracing or at least bend some brackets. The builder of mine has some large hardwood blocks mounted to the underside of them to mount the spats to, so those might work as an anchor point.
No work on mine today as it was good weather for a change and I spent an hour and half in a C-172 Skyhawk doing take-offs and landings and then a little sightseeing. It was cold but very light winds right down the runway and the air was smooth with a 2900 ft overcast. We then went out to a Christmas tree farm and brought home a nice tree.
I have bought some parts for mine. I have to exchange my spinner though as somehow I measured 2-1/4 when it should be 2-1/2. I drive right by the hobbyshop everyday on the way to work so it will be pretty easy.
Jaybird
Hide Signatures
(in reply to acerc)
       Post #: 619
RE: Sig Ryan STA - 12/17/2012 1:54 AM
acerc
Score: 221
Status: offline
Man! I have barely started my current build and John post pics like that. My mouth is just a watering. Send me all those pics you can John.
Robert
Hide Signatures
       Post #: 620
RE: Sig Ryan STA - 12/17/2012 3:24 AM
ovationdave
Score: 111
Status: offline
Just thought I would chime in. Watching this build thread, and your doing a very nice job Vincent. Keep it up, your giving me some ideas for building the rigging on my Brown B-2 Miss los Angeles. Lots of similar types of rigging on that one. Anyway, keep up the good work!
Dave
I have not failed. I''''ve just found 10,000 ways that don''''t work - Thomas A. Edison
Hide Signatures
(in reply to acerc)
       Post #: 621
RE: Sig Ryan STA - 12/17/2012 3:43 AM
raptureboy
Score: 183
Status: offline
O.K jay, we'll let you play with us.  Actually I had an STA with the 90 FS in it and it flew just fine and sounded good too. I used a flexable lead pipe to the muffler out the bottom of the cowl and had an onboard glow igniter to keep it hot on the idle. If you get a chance to pick up a set of the Robart gear they made for the Ryan, do so they really help with the landing shock.
Hide Signatures
       Post #: 622
RE: Sig Ryan STA - 12/17/2012 11:22 AM
VincentJ
Score: 160
Status: offline
Thanks and welcome to the thread Dave.
John, that is a very pretty Ryan, the colors are just perfect.  Sounds like it has Robert's name all over it.  Thanks for posting the pictures.  It would be great if you could post a bunch of those pictures either here or on the brotherhood thread for documentation purposes....  they will come in handy for sure!
Jaybird we forgot to tell you once you're in the brotherhood your in for life!  (like the Mafia) LOL
VJ
Hide Signatures
       Post #: 623
RE: Sig Ryan STA - 12/17/2012 1:46 PM
acerc
Score: 221
Status: offline
Vincent, I seen it too.  I need a bigger work shop.
 Jaybird, You don't leave the family!
Robert
Hide Signatures
       Post #: 624
RE: Sig Ryan STA - 12/17/2012 6:07 PM
raptureboy
Score: 183
Status: offline
RED ALERT! RED ALERT! BUILDERS MAN YOUR TABLE ! http://www.ebay.com/itm/SIG-Ryan-Sta-Special-scale-RC-model-airplane-balsa-kit-72-NIB-/130821239337?pt=US_Character_Radio_Control_Toys&hash=item1e758db229   $Buy now price $ 150+ 25 shipping!
Hide Signatures
       Post #: 625
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.047RCU1
