RE: Sig Ryan STA    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Sig Ryan STA
Page: <<   < prev  30 31 [32] 33 34 35 36 37 38 39   next >   >>
Login
RE: Sig Ryan STA - 12/29/2012 5:59 PM
acerc
Score: 221
Last Login: 5/25/2013
Status: offline
I know from motorcycle painting, fenders and such, ABS does not take standard paint very well. Either the paint gets to hard and breaks away or a softer flexible paint can dissolve the plastic. A bridge primer, designed for ABS,  is what I would think would be best.
  Of course you could use the ABS as a mold and make a  glass one.
_____________________________
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to VincentJ)
       Post #: 776
RE: Sig Ryan STA - 12/29/2012 6:12 PM
mrwad
Score: 100
Last Login: 5/14/2013
Status: offline
VJ,
I glued the headrest onto the fiberglass and then primered with Glass Kote epoxy primer and had no problems what so ever. I think your glue will bond to the fiberglass better than to the primer. Oh yeh, sand your ABS with some light sandpaper before primer. My 2 cents.
Don
Hide Signatures
(in reply to acerc)
       Post #: 777
RE: Sig Ryan STA - 12/29/2012 6:18 PM
VincentJ
Score: 145
Last Login: 5/24/2013
Status: offline
Don, thanks for your input.  Since I am using the same type of primer (Klass Kote) you have dispersed my fears of the plastic disolving from the primer.
VJ
Hide Signatures
(in reply to mrwad)
       Post #: 778
RE: Sig Ryan STA - 12/29/2012 9:51 PM
VincentJ
Score: 145
Status: offline
Headrest is now in place.  More cowl work to do next.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
VJ
Hide Signatures
       Post #: 779
RE: Sig Ryan STA - 12/30/2012 12:06 AM
mobyal
Score: 110
Status: offline
quote:
ORIGINAL: VincentJ
Great thread and I'm following it w/ interest. Where'd you get that builders' stand you're using? I'd really like to have one of those.
You and Jaybird stay indoors, warm and dry!
Al
MobyAl
Hide Signatures
       Post #: 780
RE: Sig Ryan STA - 12/30/2012 12:48 AM
VincentJ
Score: 145
Status: offline
Welcome to the thread Al.  The stand that I've been using is made by Precision Aero, it's called the "Ultimate Flight Stand" here's the link: http://www.precision-aero.com/
Comes assembled however with no finish applied.
VJ
Hide Signatures
(in reply to mobyal)
       Post #: 781
RE: Sig Ryan STA - 12/30/2012 12:50 AM
ovationdave
Score: 111
Status: offline
I have to admit, I really like this plane, and have oogled over the few for sale on RCU and Ebay. What is keeping my from the final purchase is all of that ABS. I never seem to have good luck with the ABS stuff. Does the real plane have a lip where the headrest is mounted, or do you have to blend it into the fuse somehow? Just wondering. Looks great so far, thanks for the build thread, its been great viewing!
Dave
I have not failed. I''''ve just found 10,000 ways that don''''t work - Thomas A. Edison
Hide Signatures
       Post #: 782
RE: Sig Ryan STA - 12/30/2012 12:59 AM
VincentJ
Score: 145
Status: offline
Dave don't sweat the ABS.  There are six sheets, and you cut them out and sand to final size with some sandpaper.  The lip that your talking about is already there as you can see from the photo of the cut out scoop.  Getting it to fit is up to the builder.
Click for fullsize
Click for fullsize
VJ
Hide Signatures
(in reply to ovationdave)
       Post #: 783
RE: Sig Ryan STA - 12/30/2012 2:18 AM
mobyal
Score: 110
Status: offline
Thanks, Vince.
Soon as I can raise them on the phone I'm gonna order one.
Al
MobyAl
Hide Signatures
       Post #: 784
RE: Sig Ryan STA - 12/30/2012 4:48 PM
VincentJ
Score: 145
Status: offline
Another snow storm came through last night.  You can see what it left for all of us....I keep telling myself the days ARE getting longer!
Put the last of the plastic pieces on the cowl  (this is the oil filler cap).   All I have left on the cowl are the panel lines and of course rivets/bolts which will all be done after the primer is sprayed.  I didn't put all the bells and whistles on the cowl that came in the kit as the Ryan that I am copying does not have them.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
VJ
Hide Signatures
       Post #: 785
RE: Sig Ryan STA - 12/30/2012 9:54 PM
raptureboy
Score: 178
Status: offline
Only 79 days until spring I know those NH winters though, they can be long. HAPPY NEW YEAR ALL!
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
       Post #: 786
RE: Sig Ryan STA - 12/30/2012 10:53 PM
VincentJ
Score: 145
Status: offline
Always the optimist, that's good Raptureboy...
Been trying to keep busy since I am in a holding pattern on the paint.  I cut out and fitted the dorsal fin piece.  This piece has not been epoxied into place as I will have to cover the fin first with Solartex, but you still can get a good idea of how it will appear once installed.  I also finished the axle on the tail wheel.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
VJ
Hide Signatures
(in reply to raptureboy)
       Post #: 787
RE: Sig Ryan STA - 12/30/2012 10:55 PM
ghoffman
Score: 163
Status: offline
Vinnie, I guess I am going flying tomorrow, are you?
Hide Signatures
       Post #: 788
RE: Sig Ryan STA - 12/30/2012 10:58 PM
VincentJ
Score: 145
Status: offline
I can, but need to put skis on the Tiger...that is if this wind stops howling.
VJ
Hide Signatures
(in reply to ghoffman)
       Post #: 789
RE: Sig Ryan STA - 12/30/2012 11:00 PM
ghoffman
Score: 163
Status: offline
I have some aluminum ones if you want to borrow some.
Hide Signatures
       Post #: 790
RE: Sig Ryan STA - 12/30/2012 11:04 PM
VincentJ
Score: 145
Status: offline
 I have several pairs that I can use. Thanks anyway!
VJ
Hide Signatures
       Post #: 791
RE: Sig Ryan STA - 12/31/2012 5:18 AM
Cub Flyer Fresno
Score: 115
Status: offline
Hey, this isn't Ryan related.  Come on, back on topic!
Looking good VJ!  Can't wait to see the paint go on!
Cub Brotherhood #65
Hide Signatures
       Post #: 792
RE: Sig Ryan STA - 12/31/2012 5:50 AM
skylarkmk1
Score: 210
Status: online
VJ,
N 48587 (1941 ST-M converted) does not have the mini dorsal fin (pic 1109). It is always good to check references. The Paul Matt drawing of NC 14985 (1936) does show it. Wind Canyon Books has the ST-A drawings in 1/24 scale (1/2" = 1") on 2 - 18" x 24" sheets available (rolled in a Tube additional cost). http://www.windcanyonbooks.com/books.php?pid=17&cat=1 They also have all of Paul Matts drawings on 4 CDs ($20/CD) or all 4 CDs on 1 DVD for $50.
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
       Post #: 793
RE: Sig Ryan STA - 12/31/2012 11:12 AM
VincentJ
Score: 145
Status: offline
John the plane that I have been trying to replicate is the 1937 Ryan ST-A Special  N17368 which does  have the dorsal fin.  Ryan N48587 is close in appearance which is why your CD has been so important for me to reference.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by VincentJ -- 12/31/2012 8:09 PM >
VJ
Hide Signatures
(in reply to skylarkmk1)
       Post #: 794
RE: Sig Ryan STA - 12/31/2012 2:43 PM
raptureboy
Score: 178
Status: offline
78 days till spring!
Hide Signatures
       Post #: 795
RE: Sig Ryan STA - 12/31/2012 3:33 PM
skylarkmk1
Score: 210
Status: online
VJ,
Other differences I noted in a quick look at the photos of N 17368.
It appears to have the original Menasco C-4 Four cylinder 125 hp engine (4 exhaust Stacks vs 6 on the Ranger in N 48587)
Cowl may be slightly shorter due to engine (extra stacks may cause the illusion).
No starboard side cowl air scoop and the Top Cowl scoops may be slightly lower on N 17368. (Only noticeable on direct comparison of photos or planes)
Pitot tube appears to be missing on N 17368.
There are no strut fairings covering the strut ends.
Minor details for sure, makes your job a bit easier (less detail to add).
I would like to see a Fly In of Ryan STs all together at one place like the Wacos and Mustangs have.
< Message edited by skylarkmk1 -- 12/31/2012 5:37 PM >
Hide Signatures
       Post #: 796
RE: Sig Ryan STA - 12/31/2012 6:56 PM
VincentJ
Score: 145
Status: offline
Otherr differences  between the two is that N48587 doesn't have any fin fairings as well as the already noted dorsal fin. The way the flying wires are attatched to the fuse has a different type of bracket.  I too would love to see a fly-in for Ryans, who knows maybe it will happen...
And speaking of fin flaring, that's exactly what I've been fitting on my Ryan.  Looks harmless enough, but it took me a bit of time to get the fit where you see it here.  Again it can't be installed along with the dorsal fin beacuse I want to get the primer down first and the fin covered.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by VincentJ -- 1/1/2013 11:01 AM >
VJ
Hide Signatures
       Post #: 797
RE: Sig Ryan STA - 12/31/2012 7:17 PM
WacoNut
Score: 175
Status: offline
Looks really good VJ,
You will also want to get all your panel line details down before applying the fairings.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 798
RE: Sig Ryan STA - 1/1/2013 10:54 AM
VincentJ
Score: 145
Status: offline
Happy New Year everyone...
I'm going to go and buy some Acetone today so I  can assemble the wheel pants and spats.  The acetone will soften the ABS plastic and weld them together.  I'm running out of things to do waiting for the paint to arrive.
VJ
Hide Signatures
(in reply to WacoNut)
       Post #: 799
RE: Sig Ryan STA - 1/1/2013 6:34 PM
Jaybird
Score: 112
Status: offline
Happy New Year as well!
Well, it's mighty windy and cold today so my first flight of the year will have to wait until next weekend. Spent some more time with the landing gear on this almost completed kit build. I bent up some support braces and drilled the blocks already under the wings for anchor points. Both wheel axles are now about 5/8" in front of the leading edge rather than behind. The wheel pants aren't mounted quite the same way on both landing gear legs so one sits about 1/4" ahead of the other, but the axles are in-line. This has been quite a struggle but the plans helped a lot to give me some reference dimensions as the parts and assemblies were out of position. Since the landing gear wire has to thread up through the wheel pants the way this one was built I made the brace a clamp on assembly. I'm using small steel cable clamps to secure it the gear wire. I'll have to test it to see if it will hold up.
I have verified that at 2 degrees positive incidence at the wing the stabilizer is 0 degrees and the motor shaft is 0 degrees (pretty close anyway). I used a lazer level to check the alignmemt of the end of the motor shaft, centerline of the firewall and vertical stabilizer and that is in good shape as well. The next step will be to figure out the aileron and flap servo mounting and connection as well as the rest of the radio gear. Fuel tank is still not installed either.
There is a club meeting tonight that I hope to attend and maybe get some ideas.
Stay warm!
Jaybird.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 800
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.594RCU1
