RE: Sig Ryan STA    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Sig Ryan STA
Page: <<   < prev  35 36 [37] 38 39 40 41 42 43 44   next >   >>
Login
RE: Sig Ryan STA - 1/16/2013 11:17 AM
acerc
Score: 221
Last Login: 5/24/2013
Status: offline
Vincent I use vinyl tape to lay out the paint line then I mask about 1/2 inch off that with regular masking tape. I spray in between with the two with the liquid masking film, usually three coats, then pull the vinyl tape off and let the masking film dry. Peeling it off is similar to peeling wood glue off your fingers when dried, just knurl it right off.  Because it is a liquid when applied it leaves a super crisp line with no bleed under.
  Anyplace that carries hobby supplies should have it in one brand or another.
_____________________________
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to VincentJ)
       Post #: 901
RE: Sig Ryan STA - 1/16/2013 11:36 AM
VincentJ
Score: 145
Status: offline
Thanks for the explination Robert, I'll give it a try.  Can it be brushed on with the same results?
VJ
Hide Signatures
(in reply to acerc)
       Post #: 902
RE: Sig Ryan STA - 1/16/2013 11:58 AM
acerc
Score: 221
Status: offline
Yes it can and it is actually a little better brushed on, thicker and easier to peel. I'm just a cheap skate and want to get as much use as possible.
There is one major advantage, for me anyway, it does not leave a sticky residue behind. I have not found a tape yet that does not leave a little of it's adhesive on the airframe. But I use the dope type paints, something like latex or other water based paints the adhesive may not stay behind.
Robert
Hide Signatures
       Post #: 903
RE: Sig Ryan STA - 1/16/2013 2:18 PM
TCampbell
Score: 100
Status: offline
quote:
ORIGINAL: VincentJ
...school here just got cancelled so I'm glad I brought my fuse home last night.  I'll be in my workshop as well! (Expecting 2-4 inches here)  Let's get some work done....
So. Jealous.
Tim
Hide Signatures
       Post #: 904
RE: Sig Ryan STA - 1/16/2013 3:09 PM
raptureboy
Score: 178
Status: offline
 Ask and you will receive. The finished look.  Do you still have kids at home?  Mine are grown so I have to go to work no matter the weather. The liquid nmask is great stuff for painting canopies that have frames moulded in like a warbird or for doing markings, I bought mine at a local art store but try a craft store also like AC Moore.
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
(in reply to TCampbell)
       Post #: 905
RE: Sig Ryan STA - 1/16/2013 4:35 PM
VincentJ
Score: 145
Status: offline
Well that looks pretty good!  No, I don't have any children of my own. So I am able to do what I please for the most part. I have been fortunate that when the weather is bad I don't have to go to work.  I feel for those that do.  It was nice to stay home and work in the workshop...
VJ
Hide Signatures
(in reply to raptureboy)
       Post #: 906
RE: Sig Ryan STA - 1/16/2013 6:02 PM
VincentJ
Score: 145
Status: offline
Fuse is all taped off for the final panel lines which will get sprayed tomorrow at work.
Shifting my attention to the rudder, specifically the plastic rudder cones that go on the lower halves of the rudder.  Initially I had no intention on using them, but I may have changed my mind.  I was able to fit them and conceal the pull-pull horns nicely.  What I don't like about these cones is that they limit the amount of rudder the plane will have.  I may purposely add more of a hinge gap between the rudder and fin to get a bit more deflection.  From what I can tell in the photos that I have the gap between the fin and rudder are large anyway.  I'll try it, I can always remove it if it dosen't work out.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
VJ
Hide Signatures
       Post #: 907
RE: Sig Ryan STA - 1/16/2013 6:24 PM
Cub Flyer Fresno
Score: 115
Status: offline
Gee VJ, I'm glad you posted that last photo.  It made me think of my Cub and how much gap I want on the control surfaces.  Hmmm....
By the way, that looks really good!  Keep it!
Stay warm,
David
Cub Brotherhood #65
Hide Signatures
       Post #: 908
RE: Sig Ryan STA - 1/16/2013 6:26 PM
mrwad
Score: 100
Last Login: 5/14/2013
Status: offline
I vote that you use them ! I think they are a large part of the Ryan's caracter !
Regards, Don
Hide Signatures
       Post #: 909
RE: Sig Ryan STA - 1/16/2013 7:00 PM
Jaybird
Score: 112
Status: offline
It seems like you will have a lot of rudder travel with size horn. The SIG "spec sheet" that has been posted several times reads 1/2" rudder left and right. That seems like very little for a model but that could be increased fairly easily. I would think you'd want to conceal the rudder controls as on the full scale (I think) and mount them inside those covers. That way both the elevator and rudder cables are hidden. The pushrod setup on the the one I bought gives plenty of rudder and tailwheel throw with a horn that will just fit inside the side covers. See the last picture in post #686. Just my opinion of course, but it seems a shame to have those large controls horns hanging out when they could be covered up.
Sorry,
Jaybird
Hide Signatures
(in reply to mrwad)
       Post #: 910
RE: Sig Ryan STA - 1/16/2013 7:09 PM
raptureboy
Score: 178
Status: offline
+1 on that. My GP Ryan has the horns hidden in the shrouds and it looks good.I'll se if I can post a picture later as I'm at work now. Well some of us have to go and support the govt.
< Message edited by raptureboy -- 1/16/2013 7:37 PM >
Hide Signatures
(in reply to Jaybird)
       Post #: 911
RE: Sig Ryan STA - 1/16/2013 7:42 PM
VincentJ
Score: 145
Status: offline
Negative on the horns inside of the cone.  The length of the horns on there now have not been trimmed to proper length so it will be a lot shorter.  This is a pull-pull system so the stock location of the rudder contol was scrapped long ago.  I want easy access to the clevis' if need be as well.
VJ
Hide Signatures
       Post #: 912
RE: Sig Ryan STA - 1/16/2013 10:55 PM
VincentJ
Score: 145
Status: offline
Few days ago Anthony (Waconut) had suggested for me to make rivets from aluminum soda cans so I decided to try my hand at it.  I took a piece of 4-40 rod and ground one end to profile the dome shape of a rivet.  After sliceing open a Coke can I used a hammer and started to punch out these tiny rivets.  As suggested this should be done over some firm rubber which I need to get from the hardware store.  The end result are some pretty nice facsimiles of rivet heads.  This is going to take me a while....
Note: If you notice in the first photo where I'm holding the 4-40 rod, you will see a small blood blister where I slipped with the hammer. OUCH!
Click for fullsize
Click for fullsize
Click for fullsize
VJ
Hide Signatures
       Post #: 913
RE: Sig Ryan STA - 1/16/2013 11:01 PM
acerc
Score: 221
Status: offline
If you did not draw blood it does not count. Blisters don't count!
Robert
Hide Signatures
       Post #: 914
RE: Sig Ryan STA - 1/17/2013 12:24 AM
WacoNut
Score: 175
Status: offline
quote:
ORIGINAL: acerc
Robert I think you are correct, seems to be a little too timid with da hammer doesn't he
VJ,
Those rivets look great. You need to just set a few of them in place on the plane and snap a pic so we can see how they will look.
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
(in reply to acerc)
       Post #: 915
RE: Sig Ryan STA - 1/17/2013 1:02 AM
VincentJ
Score: 145
Status: offline
Well what do you think, should I use them?
Click for fullsize
Click for fullsize
Click for fullsize
VJ
Hide Signatures
(in reply to WacoNut)
       Post #: 916
RE: Sig Ryan STA - 1/17/2013 1:06 AM
WacoNut
Score: 175
Status: offline
I think they look great. You cannot get that consistancy in size and or shape with glue. They will really pop once the paint goes on.
Later!!
Anthony
Hide Signatures
       Post #: 917
RE: Sig Ryan STA - 1/17/2013 1:22 AM
acerc
Score: 221
Status: offline
I second Anthony's opinion.
Robert
Hide Signatures
       Post #: 918
RE: Sig Ryan STA - 1/17/2013 1:30 AM
WacoNut
Score: 175
Status: offline
quote:
ORIGINAL: acerc
About the rivets or the Hammer
Hide Signatures
(in reply to acerc)
       Post #: 919
Cub Flyer Fresno
Score: 115
Status: offline
Are you kidding VJ?  Go for it!  I'm learning, learning to save money and time.
Cub Brotherhood #65
Hide Signatures
(in reply to acerc)
       Post #: 920
RE: Sig Ryan STA - 1/17/2013 1:39 AM
acerc
Score: 221
Status: offline
Both issues.
Robert
Hide Signatures
(in reply to Cub Flyer Fresno)
       Post #: 921
RE: Sig Ryan STA - 1/17/2013 2:49 AM
raptureboy
Score: 178
Status: offline
Well in case yoou chane your mind about the rudder I'll include some pics of mine. The rivets look cool, only 993 more to go  if you don't wear glasses now you will by the time your done. Are'nt you glad we came along for the ride, you might have just done a simple paint job by now and be done with this project
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to acerc)
       Post #: 922
RE: Sig Ryan STA - 1/17/2013 10:45 PM
VincentJ
Score: 145
Status: offline
Ok I painted the last of the panel lines and this time when I peeled off the Frog Tape I paid carefull attention if thier was that paint blocker gel under the tapes edge.  As you can see there was.
Now I need a little help, I made a comparison from the rivets made from 4-40- rod and rivets punched from 2-56 rod.  Which one looks better.  To my eye the 2-56 rivets seem more scale for a 1/5 scale plane.  Tell me what you think!
Click for fullsize
Click for fullsize
VJ
Hide Signatures
       Post #: 923
RE: Sig Ryan STA - 1/17/2013 10:55 PM
WacoNut
Score: 175
Status: offline
I think the 2-56 looks better as well.
You may wind up needing both sizes. I think I remoember seeing larger and smaller rivets in pics.
Later!!
Anthony
Hide Signatures
       Post #: 924
RE: Sig Ryan STA - 1/17/2013 11:05 PM
acerc
Score: 221
Status: offline
Like Anthony, I as well like the 2-56 size better. They just look more appropriate.
And the sticky from the Frog tape is why I like the Liquidmask.
Robert
Hide Signatures
       Post #: 925
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
