Sig Ryan STA    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> Sig Ryan STA
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Sig Ryan STA - 8/28/2012 3:22 PM  1 votes
VincentJ
Score: 145
Last Login: 5/20/2013
Status: offline
Like many others before me, I started in this wonderfull hobby in the early 70's.  Having a very limited budget then left me with the hopes of someday building the planes that I wanted during that era at some other time in the future when funds were more available.  Fast forward to today, where did all that time go  (not to mention my funds)?
  I've always admired the Sig Ryan STA plane, and recently I had the good fortune to buy one on E-bay for a tidy sum of $225.00.  Now buying a NIB kit from 1971 makes one wonder if all that money that you are spending will just be for the plans and instruction booklet, after all, the wood in the kit is 41 years old!  My kit arrived  recently and I was eager to open it and check its contents.  It was like a time capsule.  I found the wood to be of the highest quality with no warping, twisting, splitting or hardening of any kind!  I really couldn't believe it....
My intentions for this rather hard to find kit is to bring it out of the 70's build technology and bring it into today's technology standards without changing its looks or flight characteristics.  There isn't a whole lot of information out there for this type of plane for me to reference.  My thoughts are to power this beauty with a DLE20 engine and get rid of all the bellcranks and install individual servos for all the ailerons and flaps along with a pull-pull set-up on the rudder.  So that's it in a nut shell, hope you enjoy the process.........
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by VincentJ -- 9/18/2012 1:45 AM >
_____________________________
VJ
Hide Signatures
       Post #: 1
RE: Sig Ryan STA - 8/28/2012 4:01 PM
acerc
Score: 221
Status: online
Looking forward to it. I am subscribed.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to VincentJ)
       Post #: 2
RE: Sig Ryan STA - 8/28/2012 4:06 PM
acerc
Score: 221
Status: online
By the way, if you want a fiberglass cowl and pant's they are available here.  http://www.fiberglassspecialtiesinc.com/catalog.htm
Robert
Hide Signatures
(in reply to acerc)
       Post #: 3
RE: Sig Ryan STA - 8/28/2012 6:56 PM
batdog
Score: 131
Last Login: 5/19/2013
Status: offline
I am subscribed as well and can hardly wait to see the progress. This plane has been a favorite of mine but I have never owned one. good luck. batdog
Hide Signatures
(in reply to acerc)
       Post #: 4
RE: Sig Ryan STA - 8/28/2012 7:02 PM
smithcreek
Score: 159
Status: online
Will a DLE-20 fit in the cowl? Would be a real shame to hack it up. The plastic parts with the sig kits are high quality, actually usable compared to other kit makers.
For a kit you are, and to a kit you shall return.
Hide Signatures
(in reply to batdog)
       Post #: 5
RE: Sig Ryan STA - 8/28/2012 7:40 PM
FlyerInOKC
Score: 116
Status: offline
VincentJ, put a .60 in it! If you still need a little more power consider a .75 or a .90 which in a lot of cases share the .60 crankcase. Remember the .60 the designer put in his airplane back in the 70s had a lot less power than a new .60 you buy from your LHS or mail order. You don't even need to get the top of the line OS Max .60 AX to get extra power! I'm sure some of our resident RCU engine experts can quote the hp ratings if we give the time to post. This is a scale Ryan STA trainer do you really need to 3D it like a modern pattern plane and hang it vertical from the propeller?
My workbench where you always find the weird and unusual! Sig Kadet Brotherhood #89 Ryan STA/STM/SC Brotherhood # 27
Hide Signatures
(in reply to smithcreek)
       Post #: 6
RE: Sig Ryan STA - 8/28/2012 7:43 PM
FlyerInOKC
Score: 116
Status: offline
One more thing you lucky dog! The STA is on my short list. I just need to get my scratch built twin Ryan SC-M/W finished first. Yes i'm green with envy!
Hide Signatures
(in reply to FlyerInOKC)
       Post #: 7
RE: Sig Ryan STA - 8/28/2012 7:56 PM
EF
Score: 100
Status: offline
I got the same kit, same condition, and for the same reasons
However, and probably most will disagree with me (even though my approach has proved successfull many times), when I build such a kit I try to remain faithful to the original e.g. use same or similar type of power (a DLE 20 is way overpower and out of character of this model) and I usually even use bellcranks where they were used on the original model. Keep in mind most real full size light aircraft use bellcranks so why can't a model use them successfully? of course they need to be installed and connected properly, and there are ways to do that.
Good luck and please do post a build thread with lots of photos!
Erez
Hide Signatures
       Post #: 8
RE: Sig Ryan STA - 8/28/2012 9:37 PM
VincentJ
Score: 145
Status: offline
Thanks Robert for the link  I will be sure to use them in this build.  Welcome, Acerc, FlyerInOKC, Smithcreek, EF and batdog!
It is true that the engine I am installing is overpowered for this model but with some of the modifications that I am planning and the throttle stick I will still be able to fly it "scale" and do it much cheaper than by using glow fuel.  The question of the DLE20 fitting inside of the cowl is a good one, and one that I will  answer in just a moment.  First thing that I did however was to take the plans to a copier and have them duplicated, I did this for a couple of reasons one which is obvious and the other being that I hate to build on folded plans,  I much prefer rolled plans.  Having done that- with plans on the work table I was able to come to the conclusion that the DLE20, mounts and exhaust will fit under the cowl with no problems.
To fit the engine/mount combo, the firewall will need to be moved 1-5/8" back. (Pencils on the plan show original mount and future mount locations) Doing this will also solve an inherent weak point in the original build sequence which I will show in the next batch of photos to follow.
Click for fullsize
< Message edited by VincentJ -- 8/29/2012 12:17 AM >
VJ
Hide Signatures
(in reply to EF)
       Post #: 9
RE: Sig Ryan STA - 8/28/2012 9:42 PM
VincentJ
Score: 145
Status: offline
Photo 2
Click for fullsize
VJ
Hide Signatures
       Post #: 10
RE: Sig Ryan STA - 8/28/2012 9:43 PM
VincentJ
Score: 145
Status: offline
Photo #3
Click for fullsize
VJ
Hide Signatures
       Post #: 11
RE: Sig Ryan STA - 8/28/2012 9:46 PM
FlyerInOKC
Score: 116
Status: offline
Looks like the DLE 20 will fit. I'm glad they designed the 20 to beam mount instead of stud mounting like the bigger engines.
Hide Signatures
       Post #: 12
RE: Sig Ryan STA - 8/28/2012 10:56 PM
acerc
Score: 221
Status: online
Sound's like you have a good game plan VJ. Whatever you do don't drill, file, sand, or anything to that engine mount. I have seen three aluminum mount's break because of such. I personally use a compareable glow composite engine mount. For my 20cc's  I use this.    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXATG7&P=0
Robert
Hide Signatures
       Post #: 13
RE: Sig Ryan STA - 8/28/2012 11:45 PM
TLH101
Score: 175
Status: offline
I have built a lot of older kits, and I have only encountered 1 issue with them. The wood is usually much drier than normal, so CA glue may not cure. If the kit was stored in a controlled environment, this may not be an issue. Just test a few scraps with CA before you start, if you plan to use CA. It's not a problem for me as I don't use it lot anymore.
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
Hide Signatures
(in reply to acerc)
       Post #: 14
RE: Sig Ryan STA - 8/29/2012 12:07 AM
VincentJ
Score: 145
Status: offline
Thanks for the heads up on the aluminum mount Robert.  I too have used that same mount on some of my other planes.
TLH101, I don't use much if any CA either.  My glues of choice are Titebond II wood glue for most building and 30 minute epoxy for higher stressed areas.
VJ
Hide Signatures
(in reply to TLH101)
       Post #: 15
RE: Sig Ryan STA - 8/29/2012 12:13 AM
acerc
Score: 221
Status: online
Great mind's think alike.
Robert
Hide Signatures
       Post #: 16
RE: Sig Ryan STA - 8/29/2012 3:49 AM
I_Fly
Score: 100
Status: offline
What a strange turn of events, finding this thread. I remember looking through the old Sig catalogs and LHS dreaming of flying the Ryan STA with its bold front end and bright colors. Two weeks ago I went to a small swap and found not one but two models that have been on my "to build" list since my start in this hobby sometime in the mid '80s. One was the SIG Ryan STA special. The other was the Sig Liberty Sport biplane. I remember visiting the local shop and looking at both of these. Something about them just called to me but as a teenager I didn't have the money, time, or skills.
Truth be told I may not be much better off today. My last kit build was a Sig Aqua Star about four years ago and really enjoyed getting back to actual building. But I purchased both kits at bargain prices which put a smile on my face. I look forward to your thread and sharing my eventual build with my two boys ages 7 and 9. So I have been looking for information online trying to decide which kit was going to be the project for this winter. Part of the choice will depend on power. I'm thinking a Satio 90. The power and sound just seem to suit this model.  My other concern is proper covering and finish.   So please include details of everything you plan to do!
Count me as subscribed!
Carl
Ultra Sport Brotherhood #122
Ryan STA/STM Brotherhood #5
Hide Signatures
(in reply to acerc)
       Post #: 17
RE: Sig Ryan STA - 8/29/2012 10:10 AM
n8622t
Score: 101
Status: offline
Well to say the least this is an exciting thread. I just happen to have a completely built Sig Ryan STA I built and flew in 1982. I am at work currently, but rest assured pics will follow this afternoon.
Jimmy
"Go low if you wanna make a show"
P-40 Brotherhood #49
Hide Signatures
       Post #: 18
RE: Sig Ryan STA - 8/29/2012 11:56 AM
acerc
Score: 221
Status: online
Vincent, by photo #2 you might need a pitt's with a taper on the outlet. I bought one from J-Tec made with that taper. Cost a little more but worth it vs cutting the side open on the cowl.
Robert
Hide Signatures
(in reply to n8622t)
       Post #: 19
VincentJ
Score: 145
Status: offline
Welcome Carl and Jimmy!  Carl the two kits that you found were they started or not?  Nice find.   I know what you mean about the Ryan bringing you back in time.
Jimmy can't wait to see some pictures of your model....  The Ryan has been a plane that many have remembered and admired, to that end why has there been  little information on such a wonderful airplane?  Hopefully through this thread we can resurrect the Ryan and give it the attention it deserves!
< Message edited by VincentJ -- 8/29/2012 1:37 PM >
VJ
Hide Signatures
       Post #: 20
RE: Sig Ryan STA - 8/29/2012 12:02 PM
WacoNut
Score: 175
Status: offline
Subscribed,
I always liked the Ryan.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 21
RE: Sig Ryan STA - 8/29/2012 2:06 PM
I_Fly
Score: 100
Status: offline
Vincent
The two kits I found were not started. The Liberty sport is still wrapped in plastic. Someone opened the Ryan but it looks to be complete. The box is yellow from age but the wood, hardware, and plastic parts all seem to be there and are in good shape. Balsa is an amazing material and can last for many years when properly handled. That same seller had another Ryan that was started and someone else grabbed it as I walked up. Latter we compared what we purchased and only the tail had been worked on. Fortunately I found the second one and quickly put it under my arm.
 I can't wait to start one of them but it will be a month or more before some of my household responsibilities are taken care of.
quote:
ORIGINAL: VincentJ
Hide Signatures
       Post #: 22
RE: Sig Ryan STA - 8/29/2012 2:11 PM
FlyerInOKC
Score: 116
Status: offline
For all you fellow Ryan fans the aviation museum in San Diego has uploaded their Ryan factory photo collection with lots of STAs, STMs, and the harder to find SCs if you are interested. I downloaded every photo I could find for my SC-M/W project and plan on going back for more photos. Use Google search and you will find them.
Hide Signatures
(in reply to WacoNut)
       Post #: 23
RE: Sig Ryan STA - 8/29/2012 2:14 PM
FlyerInOKC
Score: 116
Status: offline
I have found leaving the box lid off indoors during humid weather will let old balsa absorb a little of the loss moisture and acclimatize to the indoor environment. Patience is the key and something I want right now!
Hide Signatures
       Post #: 24
RE: Sig Ryan STA - 8/29/2012 2:57 PM
mrwad
Score: 100
Last Login: 5/14/2013
Status: offline
Hi there,
I love this plane ! I live just outside San Diego and when I go to the Aerospace Museum I always spend a lot of time in front of the Ryan they have on display. My Ryan "build" is a Great Planes "ARF Bash". Ready for paint but can't make up my mind. I want something BOLD in color rather than the military scheme. Enjoy your build ! I too will be following your progress.
Don
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.938RCU1
