RE: Sig Ryan STA    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Sig Ryan STA
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: Sig Ryan STA - 9/21/2012 2:27 AM
VincentJ
Score: 145
Last Login: 5/24/2013
Status: offline
I guess Anthony you better start to clean off the workbench and get started on that Waco.!
_____________________________
VJ
Hide Signatures
(in reply to WacoNut)
       Post #: 151
RE: Sig Ryan STA - 9/21/2012 8:05 PM
WacoNut
Score: 175
Last Login: 5/25/2013
Status: offline
The Waco teardown and inspection will start this evening
Check out the pics below. This plane was spraying the corn field across from my house when I got home. The 5 bladed prop sounds great with the turbine mixed in. The plane is HUGE.
Later!!
Anthony
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
(in reply to VincentJ)
       Post #: 152
RE: Sig Ryan STA - 9/22/2012 1:58 AM
VincentJ
Score: 145
Status: offline
That's great Anthony. Keep us posted on your progress. Besides it's about time you get back in your shop building or in this case rebuilding .  That must have been an exciting moment to see and hear that Air Tractor!  I've never seen one, do they come around your house spraying often?
Servo trays have all been completed.  In photo #1, the servo on the left is for the throttle, and the other is for the choke.  I'm glad that's done, there was a lot of head scratching going on to get things to work the way I wanted them to.  Started on the top stringers as well.  Looking forward to sheeting the fuse.  It's starting to look like a Ryan...  I know I've said it before but I am still amazed how good this balsa is after 41 years, I did find one 1/4" square stock that was as hard as a rock, but so far that's it.  So far this plane has been a pure joy to put together.
Click for fullsize
Click for fullsize
Click for fullsize
VJ
Hide Signatures
       Post #: 153
RE: Sig Ryan STA - 9/22/2012 2:16 AM
acerc
Score: 221
Status: offline
That is the only thing about gas engines I don't like, the orientation of the linkage. And I alway's hook up the choke to a servo. Looking really good. Very nice and clean workmanship.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 154
RE: Sig Ryan STA - 9/22/2012 2:18 AM
acerc
Score: 221
Status: offline
Anthony, if it make's you feel any better, I'd rather be rebuilding the Waco than the two house's  I'm currently remodeling.
Robert
Hide Signatures
(in reply to acerc)
       Post #: 155
RE: Sig Ryan STA - 9/22/2012 2:53 AM
WacoNut
Score: 175
Status: offline
VJ,
The Airtractor was out at our R/C field a couple months ago, our runway is on the end of a 3,000ft grass strip on a farm. We use the last 600ft. There were 2 of them flying out of the field spraying the neighboring farms. I didn't have my camera on me when they were at the R/C field. They are very quiet when they are coming in for a landing and taking off. They are on you before you know they are there.
Robert I have to say I am not looking forward to refinishing the Waco. It was a labor of love and I hate doing the same subject twice. I put over 300ft of rib and reinforcement tapes on the Waco the 1st time around. I am looking forward to having it back in the fleet.
I wound up not working on it at all this evening, the wife is down with bronchitis and not feeling good at all. Maybe tomorrow as the weather is going to be bad here.
Later!!
Anthony
Hide Signatures
(in reply to acerc)
       Post #: 156
RE: Sig Ryan STA - 9/22/2012 7:47 PM
VincentJ
Score: 145
Status: offline
All top stringers are now in place.  On the front side of the second F-1T former, thier is a 1/4"x1/2"x3 3/4" balsa block which is inset into the stringers to provide a shelf for mounting the future flying wire metal braket.  I substiuted the balsa with a piece of spruce for added strength as the flying wires on this plane will be functional and not cosmetic.  I have a few minor items to complete on the fuse and then it's ready for sheeting.  I will hold off on the sheeting for now and focus on building the wing.  If their are any adjustments that need to be made I think it better that the sheeting not be in place.  I am very excited to build the wing.  I will make some modifications and improvements to the wing which will be explained as I progress.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by VincentJ -- 9/22/2012 11:51 PM >
VJ
Hide Signatures
       Post #: 157
RE: Sig Ryan STA - 9/22/2012 10:03 PM
SunDevilPilot
Score: 147
Status: offline
I like the use of blind-nuts for the mounting of the servos, I did that on my last build and it is a great method.  Probably overkill but super strong.
Great build!
SunDevilPilot
SunDevilPilot
Cub Brotherhood # 47
Hide Signatures
       Post #: 158
RE: Sig Ryan STA - 9/22/2012 11:44 PM
VincentJ
Score: 145
Status: offline
Thanks SDP...
One last detail for this evening.  Along with strengthening the flying wire block there is another wing strut attatchment directly below.  The instructed method of attatchment of the wing strut to the fuse is with a very small piece of 3/32" ply that is cut flush into the top balsa sheeting.  This looks like a definite future trouble point so I added a 1/4" basswood block that has been glued to the stringers and will better support the balsa top sheeting, in addition to giving additional bracing to the above wing block.
Click for fullsize
Click for fullsize
VJ
Hide Signatures
(in reply to SunDevilPilot)
       Post #: 159
RE: Sig Ryan STA - 9/23/2012 1:39 AM
acerc
Score: 221
Status: offline
Robert
Hide Signatures
       Post #: 160
RE: Sig Ryan STA - 9/23/2012 2:29 AM
VincentJ
Score: 145
Status: offline
Thanks Robert,  Can;t wait 'till you get back on your (Dan's) Cub.  Always look forward to seeing your progress and creative ideas.
< Message edited by VincentJ -- 9/23/2012 11:37 AM >
VJ
Hide Signatures
(in reply to acerc)
       Post #: 161
RE: Sig Ryan STA - 9/23/2012 11:49 AM
VincentJ
Score: 145
Status: offline
Last detail completed on the fuse and it's time to start building the wing.  Before the fuse is sheeted the tail cone piece had to be carved out of some solid balsa which will ultimately get sheeted as well.  The tapered cone shape was made on the the belt sander until I got close to my marks, then final shaped by hand sanding using a sanding block.  In order for the sheeting to have a seamless transition from the fuse to the tail cone the shape had to be just right.  I checked using a straight edge from the stringer to the top of the tail cone MANY times before I got what you see in the photos. Tail cone was glued held securely using rubber bands.
Going flying today so I'll get back to the workshop later on today...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
VJ
Hide Signatures
       Post #: 162
RE: Sig Ryan STA - 9/23/2012 12:00 PM
aframe2
Score: 100
Last Login: 5/21/2013
Status: offline
VincentJ, I have the same kit that I am planning on building this winter. One question I have is, are you
going to use the abs plastic parts for some of the fairings and wheel pants, etc. Or are you going to
purchase the parts in fiberglass? Can they be purchased in fiberglass? I know fiberglass specialties has
a lot of parts for different kits, but I haven't looked into their inventory to see if they could duplicate
the parts. Thanks, Aframe2
aframe2
Hide Signatures
       Post #: 163
RE: Sig Ryan STA - 9/23/2012 12:25 PM
VincentJ
Score: 145
Status: offline
Airframe2, Fiberglass Specialties only has the cowl and wheel pants that I am aware of.  I plan on buying the cowl from them for this project.  I have used them before and have been very pleased with their products.  The plastic parts that are supplied with this kit are actually really nice, not like the cheap thin pieces of junk that you find in newer kits.  Hope this thread makes your build go a bit easier....
VJ
Hide Signatures
(in reply to aframe2)
       Post #: 164
RE: Sig Ryan STA - 9/24/2012 5:00 AM
Cub Flyer Fresno
Score: 115
Status: offline
quote:
ORIGINAL: WacoNut
Later!!
Anthony
Oh I love watching crop dusters!  There used to be a lot more around when i was a kid.  Great shots Anthony!  Ya need to get a video camera though.
Cub Brotherhood #65
Hide Signatures
       Post #: 165
RE: Sig Ryan STA - 9/24/2012 5:17 AM
Cub Flyer Fresno
Score: 115
Status: offline
Whew!  Finally caught up.
Great job VJ!  I think I might have found my next 3+ year building project.    It looks like a pretty stout fuse there, is it?  Maybe it's just that I'm still new to this stuff.
Cub Brotherhood #65
Hide Signatures
(in reply to Cub Flyer Fresno)
       Post #: 166
RE: Sig Ryan STA - 9/24/2012 4:48 PM
VincentJ
Score: 145
Status: offline
It is David, and I'm thankful for it as I am putting  a DLE-20 on it.  It went together very well.  Wing is up next!
VJ
Hide Signatures
       Post #: 167
RE: Sig Ryan STA - 9/24/2012 11:34 PM
VincentJ
Score: 145
Status: offline
Well as promised, I did start on the wing this evening.  I separated all of the die-cut ribs from their sheets and cleaned them up a bit by stacking them all up and sanding them as if they were one.  I was lucky in that anyone who's had to deal with die-cut parts knows that it's always a gamble if the die at the time of cutting is sharp or not.  The ribs came out pretty cleanly!
Looking at the plans previously, I saw that the front main spar was 1/4" x 3/4" balsa and the rear spar 1/4" x  1/2" balsa.  These were swapped out for Basswood of the same dimension.  The front main spar was further strengthened by laminating two 1/8" x 3/4" pieces giving me the same overall dimension but with increased strength that laminating provides.
I prefer to use Tite-bond II glue for my joinery but in this case CA lended itself well for this particular situation adhearing the ribs to the spars. I will post a few more pics later this evening.
Click for fullsize
Click for fullsize
VJ
Hide Signatures
       Post #: 168
RE: Sig Ryan STA - 9/25/2012 12:44 AM
VincentJ
Score: 145
Status: offline
Bonus Coverage!
Here are some shots of the rib and spar connections.  As you can see, if I had tried to use wood glue on the inside opening of each rib, by the time I slid the rib into place the glue would have been wiped clean.  I tried to make the joints as slop free as I dared allowing each rib to be slid down each spar into position, this is why I used CA on these connections.  The building of this wing is different from what I'm used to seeing. Very "old school", just like me!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
VJ
Hide Signatures
       Post #: 169
RE: Sig Ryan STA - 9/25/2012 3:46 PM
raptureboy
Score: 178
Status: offline
Every thing is looking very clean and well thought out. That is an interesting way to build a wing, I'm used to pinning the spar down to the plans and then gluing the ribs on to the botom spar and then adding the top spar. Seems like a pain in the butt to slide all the ribs down one by one, but looks to be very strong this way.
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
       Post #: 170
RE: Sig Ryan STA - 9/25/2012 4:55 PM
VincentJ
Score: 145
Status: offline
Yes I thought the same thing.  Changing over to basswood for the spars should really increase the strength of these wings.  I don't know if this was a commont type of wing build practice on the planes of old.  As far as sliding each rib down, yes it was a bit more work, I had to make sure I didn't crack any ribs as I positioned them but it was fun.  Hinging the ailerons will be a bit more challenging when you see the leading and trailing edges.  I plan on using Robart hinges.
VJ
Hide Signatures
(in reply to raptureboy)
       Post #: 171
RE: Sig Ryan STA - 9/25/2012 5:06 PM
smithcreek
Score: 159
Status: offline
quote:
ORIGINAL: raptureboy
It's for scale appearance.
For a kit you are, and to a kit you shall return.
Hide Signatures
       Post #: 172
RE: Sig Ryan STA - 9/26/2012 12:21 AM
VincentJ
Score: 145
Status: offline
Tonight I glued the front leading edge of the wing and trailing edge of the aileron which in the instruction booklet is called "the special shaped balsa part" onto the left wing.  I took a photo of this "special shaped balsa part" so you can see how the leading edge of the aileron will fit into the trailing edge of the wing.  Clamping the trailing edge onto the ribs wasn't complicated once I figured out that I could use the leading edge as a pivot to allow my clamps to sit parallel on the parts.  I have no doubt that the right wing will go together much quicker.  I did notice that I forgot to drill holes in the ribs for the servo wires to go through.   Would have been a snap to do when I had all of the ribs clamped while I was sanding them, but who wants to do things the easy way?  For those of you that are planning on building this plane be aware that one could easily put on the "special shaped balsa part" ( I just like to say it )on the wrong wing and then it would be upside down.  (No, I didn't do it)  Would have been a good heads-up in the manual ...
Click for fullsize
Click for fullsize
Click for fullsize
VJ
Hide Signatures
(in reply to smithcreek)
       Post #: 173
RE: Sig Ryan STA - 9/26/2012 12:58 AM
WacoNut
Score: 175
Status: offline
Looking Good VJ,
The wing construction is very interesting. Can't wait to see the whole pane framed up.
Later!!
Anthony
Hide Signatures
       Post #: 174
RE: Sig Ryan STA - 9/26/2012 5:47 PM
VincentJ
Score: 145
Status: offline
While surfing the internet I came across this , pretty interesting information with some great old pictures of the Ryan.
http://www.airminded.net/st/const/st_const1.html
VJ
Hide Signatures
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.640RCU1
