SyCo_VeNoM -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (9/5/2012 6:45 AM)
quote:
ORIGINAL: Eman77 So next I decided to transfer the center diff to the new chassis plate. Here's a pic of the diff as it comes, before I removed the braking material we won't need because of the electric conversion (pads, discs, etc). I did notice that even the parts that rotate to engage the brakes were using shielded bearings. Nice! The last pic is of the center diff installed, but later you'll see that I'll swap out one of the side diff mounts with the electric motor mount, and the top brace with a box to house the Rx. always loved how ofna with a $79 kit gives alum chassis, shock tower, full shielded ball bearings, and a steel drive line with CVDs where most others for 2X more you get a plastic tub, a plastic drive chain, with plastic bushings :D
