RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (Full Version)
All Forums >> [RC Cars, Buggies, Trucks, Tanks and more] >> 1/16th, 1/18th, Mini & Micro RC Cars
Message
Eman77 -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/9/2012 3:15 PM)
Let us know how that goes! Won't 2700 kv be a bit low?
yakfish -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/9/2012 6:13 PM)
quote:
ORIGINAL: Eman77
These truck were designed to run on nitro motors that only pull between 30,000-38000rpm on the high end. 2700 kv will do 29970 rpm at 11.1v and 34020 rpm at 12.6v and will have more than enough torque to pull slightly taller gearing. Lower kv motors are more efficient and have more torque. On 3s I can gear it for 50mph-60mph and still run fairly cool. if I gear it for 45mph I wouldn't even have to think about temps. And if I feel like going crazy I can drop in a 4s or even 5s battery and go nuts with it and still be on the safe side!
Eman77 -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/9/2012 6:20 PM)
Ah, you're going 3s too. I get it. 5s would be insane on this little guy.
echthelion -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/10/2012 12:16 AM)
got my crt today and just wow it is indeed well worth the money. tho the stock tires are realy soft ill have those bald in the first drive lol i was thinking of getting these
http://www.amainhobbies.com/product_info.php/cPath/1_25_1466_1231/products_id/150923/n/Pro-Line-Pre-Mounted-Dirt-Hawg-I-Titus-Bead-Loc-Wheels-Black-Black-2-1-16-E-Revo
SyCo_VeNoM -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/10/2012 12:41 AM)
quote:
ORIGINAL: echthelion
personally I'd go with something bigger as those are for the 1/16th e-revo. IMO you should look at 1/10th scale tires.
echthelion -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/10/2012 12:48 AM)
they might be marketed for the mini revo but there not that small
SyCo_VeNoM -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/10/2012 5:29 AM)
they are .4 inches larger in diameter than the stock mini revos which is about the size of the stock tires on the Jammin .5 CRT.
if you like how the rim looks I guess its an ok deal. if you seen some rear buggy rims you liked http://www.amainhobbies.com/product_info.php/cPath/1_26_2338_2339_213/products_id/5511/n/Pro-Line-Dirt-Hawg-I-22-Buggy-Tires-2 would be a better deal,and are the same size ( specs I used came off http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDU13&P=ML as amains sucked)
main reason I said something a little bigger is cause the gearing on the crt.5 is a tad low ;).
echthelion -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/10/2012 6:40 AM)
low huh hmm id be happy with 35mph. lucky for me is i have a hpi firestorm and i have 3 sets of 2.2 tires so if i wanted i could put a set of them on. but for just everyday runnin im realy leaning towards what i linked ><
yakfish -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/10/2012 5:57 PM)
Dirt hawgs are good but you want these ones. they will fit on the wheels that come with the kit. I have a set and they are nice.
echthelion -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/10/2012 6:18 PM)
those are the same ones i linked just without the rims for savin money yes it would be smarter but i realy realy realy hate glueing
cumminspower5.9 -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/10/2012 7:00 PM)
Dirt hawg tires are not that great. They are definitely no dirt tire. I had ome on my bandit vxl and they sucked off road.
Eman77 -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/10/2012 7:20 PM)
I'm pretty happy with the geolandars so far. 4" outer diameter, 2" width, FYI.
Of course, it's frying my little 19T motor, but I figured that would happen.
echthelion -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/10/2012 10:43 PM)
ok i cant for the life of me get the rear chassis brace to line up with the 2 screw hole on the long chassis
echthelion -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/11/2012 4:13 AM)
its getting there    i just used the brute force method on the brace
a few pics i used the spacer that came with the battery tray bag to get a flush underside
SyCo_VeNoM -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/11/2012 6:17 PM)
I'm shocked they just don't make an electric crt.5 already. Very little in terms need to be modded of the existing one.
btw echthelion interesting way to put the battery box on did you drill holes into the box?
Eman77 -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/11/2012 6:43 PM)
I'm curious about the battery box too - could you provide pics of the inside of the battery box? How do you keep the screws from bumping into the battery?
Eman77 -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/11/2012 6:49 PM)
Yeah, I had to brute force that thing too. I guess once it's on, it's solid!
SyCo_VeNoM -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/11/2012 7:08 PM)
quote:
ORIGINAL: Eman77
I'd only assume he put it through, and cut the spare screw off so it was flush as that is how I did my X1 CRT, but that I had way more room to cut. Thing that confuses me is the spacer he mentioned. I'll be honest I don't remember spacers on the parts tree.
echthelion -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/11/2012 7:56 PM)
nah i didnt cut anything ill go take it apart and snap a few pics
the spacers offset the chassis holes to line up with the 4 holes in the battery tray and lets you mount the tray either way but i like the wires coming out the back
Eman77 -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/11/2012 8:30 PM)
Ah, wait - so you screw the tray to the spacers in one hole, and then attach the spacer to the chassis plate through the other hole! Nice. Wish I had done that. Maybe time to drill a few more holes. :)
echthelion -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/11/2012 9:17 PM)
quote:
ORIGINAL: Eman77
indeed your right  dont need to drill anything tho
SyCo_VeNoM -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/12/2012 12:11 AM)
aaahhhhh thats what those things were for
I was wondering why the tray had counter sunk holes in the battery box.
funny enough the 3 holes I drilled into the chassis seem to make the battery box sit exactly as you have it
That REALLY makes me wonder tough why they never made an electric kit even more seeing all the parts are there.
yakfish -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/12/2012 1:35 AM)
well the deal I had in place that was going to get me a Mamba Max pro fell through. so now I am going to go a different direction. I bought an 80 amp XERUN ESC today for $40. I plan to order a Tacon 3674 2800 motor and run that on 3s. I still need to order all the parts for the brushless conversion, and some batteries. what are the dimensions on the battery tray for the SCRT10? Will 5000 mah batteries fit or do I need to go smaller? I think I will buy 2 batteries so I can run them in series together in my 1/8 truggy.
on a side note here is a link to the build thread when I first got my CRT.5 in case you are interested.
http://www.rcuniverse.com/forum/m_10842128/mpage_1/key_/tm.htm
echthelion -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/12/2012 1:51 AM)
the tray just fits my 2s 5000mah 40c gensace lipos as shown in the pics a few post back so anything thinker then them id say youll need another tray
yakfish -> RE: Ofna Jammin CRT.5 1/12 Truggy Build Thread and E-Conversion (10/12/2012 3:22 AM)
are you able to measure the inside width and inside length of the battery tray? preferrably in millimeters!
Page: <<   < prev  1 2 3 [4] 5 6 7   next >   >>
Valid CSS!
SITE MAP!   : :   FORUM RULES
0.2339993
