RE: P-40 Brotherhood (All P-40's Welcome)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: P-40 Brotherhood (All P-40's Welcome)
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: P-40 Brotherhood (All P-40's Welcome) - 10/2/2012 2:33 AM
Duplicator41
Score: 100
Last Login: 5/21/2013
Status: online
DougB1. I have not seen a lot of builds on any CJM planes on any of the forums. I've belonged to some pretty large clubs in California and Illinois and the guys did not have a high opinion of CJM kits they built. (mostly jets at the time) On the other hand Ziroli and Jerry Bates plans were well regarded by the giant scale guys. I personally don't build anything over 1/5 scale, my aircraft carrier is small, so I can't speak from a direct experience with CJM planes. I do own one set of their fifth scale retracts and they don't come close to my Sierras. You might check the forms on IMAA for more help.
_____________________________
So many planes, so little time
Hide Signatures
(in reply to DougB1)
       Post #: 176
RE: P-40 Brotherhood (All P-40's Welcome) - 10/2/2012 2:46 AM
DougB1
Score: 112
Status: offline
quote:
ORIGINAL: Duplicator41
The plane they have is built from Jerry Bates plans. Bruce the owner said he worked with Jerry in the construction planning stages.
DougB1
Hide Signatures
(in reply to Duplicator41)
       Post #: 177
RE: P-40 Brotherhood (All P-40's Welcome) - 10/2/2012 2:59 AM
Duplicator41
Score: 100
Status: online
I'm sure Bruce's statement is fact as he states that on the CJM site and I certainly would not dispute that and Jerry's plans are terrific. I have a 1/5th scale Jerry Bates P40-B with a glass fuse from Vic at Vicrc. His glass work is superb, retracts are from Sierra which are very scale looking down to the drag links and all the laser cut wood was from Bob Holman and it was excellent. You have a tough choice ahead of you. Best of luck.
Hide Signatures
       Post #: 178
RE: P-40 Brotherhood (All P-40's Welcome) - 10/2/2012 3:18 PM
raptureboy
Score: 178
Status: offline
Well I am sad to say that I will not be installing the Wingspan retracts in my plane Although they are very well made and operate flawlessly they have way too much play in the trunnions when extended. I could twist the struts back and forth almost 1/2" from straight to tow in. My hat goes off to Mike at WS for great customer service and for allowing me to return them even though I had modified them to except 5/32 gear. He is on the right track for developing a good product and if this issue can be resolved I would buy them in a heartbeat. I know this rotating gear is such a pain in the butt to find any that hits the right balance of quality and cost and function. On one hand you have Sierra gear weighing a pound and running $270 + 40 for the links, and then Robarts which fold up on any landing that is not absolutly perfect and all the junky mech ones out there. Theres also the issue of most of them being only 90 deg instead of 100deg on the rake. My kingdom for a pair of resonable rotating gear! O.k all you genius types out there, the world is waiting.
quote:
ORIGINAL: raptureboy
O.K my new Wingspan 100 deg rotating retracts came today. I am going to see if I can install them tonight. I will post pic's along the way. Here are a few pre install pics. They are really well made of aluminum and stainless steel for the gear and the control board is small and fits inside the wing
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
(in reply to raptureboy)
       Post #: 179
RE: P-40 Brotherhood (All P-40's Welcome) - 10/2/2012 8:18 PM
Lifer
Score: 148
Status: offline
The Sierras on my .60-size P-40 have been flawless. I have never paid that much for that sized gear before, but 3 years later, I truly have no regrets. I remember a sign on the way to a recreational lake in southern Missouri many years ago. It said (in reference to a high-priced boat) to "Buy the Best. You'll only cry once!" It is painful to buy the best, but it does tend to result in less stress later.
Best regards.
Hide Signatures
       Post #: 180
RE: P-40 Brotherhood (All P-40's Welcome) - 10/3/2012 2:48 AM
WARBIRDRCER
Score: 118
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: WARBIRDRCER
Welcome to the P-40 Brotherhood
Numbers:
51. predman
52. jet22b
P-40 Brotherhood
Master Roster
Started 8-31-2012
Updated: 9-22-2012
Brotherhood Update, we now have 52 in our squadron.
If you would like to join the P-40 Brotherhood please make your request on this thread and I will assign you a number.
Never can tell when you may run into another P-40 Brother somewhere, so join now.
1. Warbirdrcer OK, USA
1.5. Talimena Kidd OK, USA
2. Chad Veich AZ, USA
3. dasintex TX, USA
4. Meschmidt TX, USA
5. gaumflyer Gaum, USA
6. gaumflyer’s Dad Gaum, USA
7. tp777fo SC, USA
8. Dash7ATP VA, USA
9. 77chickenhawk CA, USA
10. ccostant MA, USA
11. Capt G NV, USA
12. RBean PA, USA
13. P-40 Driver TX, USA
14. LQUAN CA, USA
15. raptureboy PA, USA
16. SVX UT, USA
17. AmishWarlord NC, USA
18. Duplicator41 ID, USA
19. gregandhollie IN, USA
20. LDM PA, USA
21. spadsriver09 IN, USA
22. mobyal VA, USA
23. Ram-bro NE, USA
24. Lifer MO, USA
25. Peter OZ Queensland, Australia
26. tocstrum NJ, USA
27. Barron VA, USA
28. darren763 MN, USA
29. DrYankum NJ, USA
30. M Callahan OH, USA
31. gsmarino2000 CO, USA
32. Cpt Crash NM, USA
33. proffj550 NM, USA
34. psheffield AZ, USA
35. Quikturn IA, USA
36. trent smith Australia
37. wireman NJ, USA
38. jblloyd MS, USA
39. Dave Bugz U.K.
40. Ford34tom WA, USA
41. doolittles ME, USA
42. SPEED51J FL, USA
43. P-39 fan WI, USA
44. US185Damiani
45. bookmaker FL, USA
46. 108buzz NJ, USA
47. Naval Flight Officer FL, USA
48. Super Chief GA, USA
49. n8622t AR, USA
50. jetster MI, USA
51. predman
52. jet22b
53. askham
askham, Welcome to the Brotherhood #53
Steve - Flight Leader - Warbirds Over Oklahoma
Spitfire & P-40 Brotherhood #1
Hide Signatures
(in reply to WARBIRDRCER)
       Post #: 181
RE: P-40 Brotherhood (All P-40's Welcome) - 10/6/2012 2:53 PM
LDM
Score: 174
Last Login: 5/19/2013
Status: offline
http://www.youtube.com/watch?v=6TqVe9sL1SA&sns=em
Sent from my iPad
Flown , love the plane , flight video coming soon , spinner has been painted red , weathering will be added
LDM
Hide Signatures
       Post #: 182
RE: P-40 Brotherhood (All P-40's Welcome) - 10/6/2012 4:03 PM
yard-dart
Score: 110
Status: offline
My Skyshark P-40.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to LDM)
       Post #: 183
RE: P-40 Brotherhood (All P-40's Welcome) - 10/6/2012 5:51 PM
Lifer
Score: 148
Status: offline
yard-dart,
What engine do you have in your P-40?
Hide Signatures
(in reply to yard-dart)
       Post #: 184
RE: P-40 Brotherhood (All P-40's Welcome) - 10/6/2012 10:27 PM
LDM
Score: 174
Status: offline
Yard dart , nice job did you add the counter balances to the tail and the round gear housing ?
LDM
Hide Signatures
(in reply to Lifer)
       Post #: 185
RE: P-40 Brotherhood (All P-40's Welcome) - 10/7/2012 12:58 AM
WARBIRDRCER
Score: 118
Status: offline
Spent time Friday and today monokoting the TF 1/7 wing. Next will be applying paint to the fuselage and then blending the wing to fuselage with the brown color camouflage.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to LDM)
       Post #: 186
RE: P-40 Brotherhood (All P-40's Welcome) - 10/7/2012 2:06 AM
skull1971
Score: 105
Last Login: 5/15/2013
Status: online
Ok with the all P-40's welcome,, I have an E-flite 300 size P-40, I'm a pylon racer, not really a scale guy. But my daughter found in at the bottom of a stack of planes at my LHS, and we just had to have the "Cute little shark plane." Well today at an electric fly-in here in Texas I found a guy selling a "Cartoon P-40", and just had to have one.
http://parkflyerplastics.com/cart/index.php?main_page=product_info&cPath=24_62&products_id=576
PS can I have number 59 on the brotherhood number? it would go along with my racing number, and Revver Brotherhood.
ERIC DESARDI, Revver Bro. 159, NMPRA 59i
Moe''s Cycle Service, New Creations-RC
Hide Signatures
       Post #: 187
RE: P-40 Brotherhood (All P-40's Welcome) - 10/7/2012 2:37 AM
DougB1
Score: 112
Status: offline
Has anyone had or have a Quadra 100 motor that could give me info on? If I get the 1/4 scale P-40 I am thinking about it uses the Quadra 100 for power.
DougB1
Hide Signatures
       Post #: 188
RE: P-40 Brotherhood (All P-40's Welcome) - 10/7/2012 4:00 AM
LDM
Score: 174
Status: offline
Skull , when you go to park flyer plastic check out the 1/4 scale foam built P40, it's a total gem , great flyer and for advanced builders
LDM
Hide Signatures
       Post #: 189
RE: P-40 Brotherhood (All P-40's Welcome) - 10/7/2012 10:40 AM
Lifer
Score: 148
Status: offline
I have a friend who has a Q-100 in a large Bearcat. It came from a raceplane. The engine is incredibly powerful. Should haul your plane around quite well.
Hide Signatures
(in reply to LDM)
       Post #: 190
RE: P-40 Brotherhood (All P-40's Welcome) - 10/7/2012 1:32 PM
yard-dart
Score: 110
Status: offline
quote:
ORIGINAL: Lifer
yard-dart,
I'm running a Quadra 52.
Hide Signatures
(in reply to Lifer)
       Post #: 191
RE: P-40 Brotherhood (All P-40's Welcome) - 10/7/2012 1:34 PM
yard-dart
Score: 110
Status: offline
quote:
ORIGINAL: LDM
The counter balances are stock. The round gear pods are aftermarket.
Hide Signatures
(in reply to LDM)
       Post #: 192
RE: P-40 Brotherhood (All P-40's Welcome) - 10/7/2012 8:34 PM
jet22b
Score: 110
Status: offline
Hello Brothers,
Here are a few pictures of my Top Flite P-40 Warhawk. She is power by a OS 1.20 Four Stroke . As you can see the engine is inside the cowling. You also see working cowl flaps. She has a total of 5 flight with 3 gear up landing!!! Over all I love this bird and looking hard at moving up to its big brother.
Sonny
aka
jet22b
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Spitfire Brotherhood #12
P-40 Brotherhood #52
Hide Signatures
       Post #: 193
RE: P-40 Brotherhood (All P-40's Welcome) - 10/8/2012 12:39 AM
Ram-bro
Score: 156
Status: offline
http://www.youtube.com/watch?feature=fvwp&v=E1cKPUWHa8I&NR=1
Hide Signatures
(in reply to jet22b)
       Post #: 194
RE: P-40 Brotherhood (All P-40's Welcome) - 10/14/2012 6:19 PM
rppoind
Score: 100
Last Login: 4/28/2013
Status: offline
Yard-Dart.........Just starting my second Skyshark P40. One of the things I am wanting to change on this one is the gear pods. Are yours from Vicrc? Please let me know where you got yours.
By the way moderator please sign me up for the brotherhood!
Richard
Near Beaumont TX
Hide Signatures
(in reply to Ram-bro)
       Post #: 195
RE: P-40 Brotherhood (All P-40's Welcome) - 10/16/2012 10:28 AM
Antoinebobrob
Score: 100
Last Login: 5/11/2013
Status: offline
Hey Guys,
I just ordered a Top Flite 60 sized P40 of tower hobbies. I will be using the O.S 120 Pumped 4 stroke and a 16x6 Prop (good for idling). I will be using the Robart retracts as well (hope it all goes well). I will also be adding a remote glow fixture so it will be easier to start the engine. Plane might be arriving tomorrow!
Hide Signatures
(in reply to rppoind)
       Post #: 196
RE: P-40 Brotherhood (All P-40's Welcome) - 10/16/2012 3:07 PM
raptureboy
Score: 178
Status: offline
Cool, since your already in China you should just go down to the factory and save all the shipping charges So are you ordering from the USA?
Hide Signatures
(in reply to Antoinebobrob)
       Post #: 197
RE: P-40 Brotherhood (All P-40's Welcome) - 10/17/2012 12:57 AM
darren763
Score: 105
Status: offline
Hey Richard,
The TopFlite Giant Scale P-40 Gear nacelles will work on the SkyShark P-40 with little modification.
Darren
That''s not flying, that''s just falling with style.
Hide Signatures
       Post #: 198
RE: P-40 Brotherhood (All P-40's Welcome) - 10/17/2012 1:19 AM
WARBIRDRCER
Score: 118
Status: offline
quote:
ORIGINAL: Antoinebobrob
Hey Guys,
Antoinebobrob,
Welcome to the P-40 Brotherhood #55
Hide Signatures
       Post #: 199
RE: P-40 Brotherhood (All P-40's Welcome) - 10/17/2012 8:52 AM
Antoinebobrob
Score: 100
Status: offline
Yeah I ordered it from the U.S of tower hobbies. I couldn't find it in China! The products are directly shipped to the U.S. Its just silly, my plane flew all the way from China to the U.S then back again to China!
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.309RCU1
