Airworld models. Fw 190 102"    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Airworld models. Fw 190 102"
Page: [1] 2 3   next >   >>
Login
Airworld models. Fw 190 102" - 8/31/2012 2:49 PM
pedro w rdz
Score: 100
Last Login: 5/19/2013
Status: offline
 Ok. Got this.  War bird from a friend all it needs is 2 receiver batteries.  N engine.   I can't afford a moki.
I think will get a dle 170 with 3 blade prop as power plant
Hope this thing fly straight.  Any.   Input.  Will be more than welcome.
Specially if any one around has one of these
Thanks.
Pedro W Rdz
_____________________________
wilbertpedro@gmail.com
Hide Signatures
       Post #: 1
RE: Airworld models. Fw 190 102 - 9/1/2012 6:43 AM
pedro w rdz
Score: 100
Status: offline
 No body ?
Hide Signatures
(in reply to pedro w rdz)
       Post #: 2
RE: Airworld models. Fw 190 102 - 9/1/2012 6:51 AM
quist
Score: 116
Last Login: 5/25/2013
Status: offline
Not sure that motor will fit. Maybe a da 120.
If you don''''t have time to do it right the first time, when are you going to find time to do it again?
Hide Signatures
       Post #: 3
RE: Airworld models. Fw 190 102 - 9/1/2012 10:55 AM
kram
Score: 110
Status: offline
Best-flying warbird I ever owned.
Like a Cadillac in the air: solid, stable. Practically lands itself
Worst thing I ever did was put a Moki in it: eventually caused loss of the plane (it doesn't handle very well dead-stick)
Cowl is huge: check the internet for motor dimensions of whatever you're putting in it. I believe the Moki 215 had a diameter of about 11.5 inches and it barely fit.
Will need at least a DA 100, maybe 150, to fly with authority.
Only problem area I had to reinforce was the wheel wells and gear-mounts. Lemme know if you want details
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to quist)
       Post #: 4
RE: Airworld models. Fw 190 102 - 9/2/2012 1:48 AM
pedro w rdz
Score: 100
Status: offline
Thanks for answering guys
Checked dle 170   11.3. Inches head to head.  The.  Cowl.  Has 12.5. Clearence     Hope it will fit. Or I'll have to go. To dle 111
Kram.    Man.   I'm so sorry.  About your plane.
But your. Words. About the plane are good news. For me
We have a 400 feet paved run way will it be able to land  or shoul I look for abiger runway
Man that plane sure looks good.  Will post pictures of mine next week when I put that engine
I really appreciate the input guys
Do you remember how do you had your flaps set up how many inches of trow. Any mixes ?
Hide Signatures
(in reply to kram)
       Post #: 5
RE: Airworld models. Fw 190 102 - 9/2/2012 2:58 AM
Mustang51
Score: 106
Last Login: 5/24/2013
Status: offline
I had the 3rd flying 190 in the country about 7 years ago. Best flying warbird I ever owned. Flew like a pattern plane. I had a 3W 120 in it and it was over powered. Flew around on about 1/2 throttle. A 100 would fly it just fine.
Hide Signatures
       Post #: 6
RE: Airworld models. Fw 190 102 - 9/2/2012 4:04 AM
kram
Score: 110
Status: offline
Pedro:
Be careful in your calculations about the engine and the cowl.
Remember that the cowl is slightly wider in the back than the front and the maximum diameter of the engine will hit the cowl somewhere between 1/2 and 2/3 of the way forward, so you don't have 12.5" for the engine.
Also, some 2-stroke engine spec diagrams aren't real clear as to whether the "head-to-head" measurement includes spark plug and cap, which can be an inch or more
The widest part of a Moki 215 is the valve lifters at 11.22" and they had no more than 1/4" clearance where they laid in the cowl for me: a very close fit. Too close, really to allow for vibration and bending, etc..
The flaps are not a part of the original kits (at least not the early ones). I cut mine out of the relatively thin underwing skin and fortified both the flap and the flap bay with stiff balsa you can see if you look closely at the picture
I flew with zero flaps, landed with 35 to 45 degrees, depending on wind.
No mixes. All my warbirds have some exponential on the low setting for elevator and ailerons. Makes me look like a better pilot than I really am.
If you have experience flying warbirds, you can easily land it in 400 feet. Longer is always better, of course.
It takes off and lands fine on grass
Remember what I said about intrinsic flimsiness of the gear rail attachment points. Better to fix it first rather than after. My maiden flight was spoiled by the left gear punching through the wing-top after a near perfect landing on a grass field
If you start to feel overwhelmed by the project and would like someone to take it off your hands, lemme know
Click for fullsize
Hide Signatures
(in reply to Mustang51)
       Post #: 7
RE: Airworld models. Fw 190 102 - 9/4/2012 4:49 AM
pedro w rdz
Score: 100
Status: offline
Wow Kram  your bird looks awesome in the picture I can see the landing gear Issue     so I should reinforce. Where the retracts are screw to the wings  right
Ho by the way I'm not a good builder. I just fly   But my neighbor is a pro.     He sold me the plane and I will ask him to help me on the reinforcement of landing gear. He loves building
We measured the cowl  and the wider part was 13.5 inches and 12.5 the front wich is smaller.  I wonder if mine is part of the second or third edition or who knows since it came with flaps and different size cowl
Well Kram.    I really appreciate your help. And details about the plane
Thanks again
Hey one last question when did you bought the plane how old is that pic?
My name.  Pedro W Rodriguez
Hide Signatures
(in reply to kram)
       Post #: 8
RE: Airworld models. Fw 190 102 - 9/4/2012 5:24 AM
pedro w rdz
Score: 100
Status: offline
Ok.
Kram I know I said last question    Just one more
Where is the cg point on these bird ?
Hide Signatures
       Post #: 9
RE: Airworld models. Fw 190 102 - 9/5/2012 1:51 AM
butlern
Score: 100
Status: offline
Was that question about the date the picture more of a comment on the good doctor's shirt?!?!?
Hahahaha... just joking, Mark.
Best wishes for the event (Wish I was closer!!!).
Noah
Hide Signatures
       Post #: 10
RE: Airworld models. Fw 190 102 - 9/5/2012 5:50 AM
kram
Score: 110
Status: offline
Noah:
Why, I resemble that remark!
My 14 year-old pretends she doesn't know me when I wear one of those shirts.
Feels bad not seein' you around in Iowa anymore.
So, is it hot down there in OK? (That's a jab, not a real question. I've got an uncle in Chickasha)
mt
Hide Signatures
(in reply to butlern)
       Post #: 11
RE: Airworld models. Fw 190 102 - 9/5/2012 5:53 AM
glazier808
Score: 291
Status: online
Hey now.... that shirt is good for Sunday in Hawaii!
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to kram)
       Post #: 12
RE: Airworld models. Fw 190 102 - 9/5/2012 5:56 AM
kram
Score: 110
Status: offline
Pedro:
I bought the kit and the plane second-hand in 2005, so it's at least that old.
I spent 2006/2007 building it, struggled with the Moki for two years, then
That picture after the maiden is 2009.
I lost the plane due to Moki in 2011
Good to know your cowl is significantly bigger than mine. In case I buy another one
Strengthening the landing gear attachment is more about the dorsal surface of the wheel wells than the actual gear rails
I had good strong gear rails when I cracked the wing on maiden. The problem is the dorsal surface of the wing is quite thin: strong enough to fly, but easy to push a rib through the skin with even the slightest of runway imperfections.
I resolved it by reinforcing the underside of the dorsal surface of the wing (the deep wheel well) with 4 layers of laminated 1/32" ply (so it can be strong but mold to the airfoil) over an area 10" long and as wide as the entire distance from the main spar to the leading edge, then built a new set of 1/4" ply ribs and 1/2" ply gear rails and epoxied it all to each other and the main spar and leading edge. Yeah, it took me two weeks, but I never had any problems, even with rougher landings, after that.
I wish I could pop that assembly out of the wreck and into my new one! But that's the main beauty/function of it: custom-contoured fit and epoxy stickin' to the whole chicken.
Maybe they have addressed the issue in the newer kits?
Mark
< Message edited by kram -- 9/5/2012 6:39 AM >
Hide Signatures
(in reply to kram)
       Post #: 13
RE: Airworld models. Fw 190 102 - 9/5/2012 6:04 AM
kram
Score: 110
Status: offline
Pedro:
Figuring out the Focke-wulf CG is one of my fondest moments in the hobby.
The day before my maiden, an Owatonna Committee of some of the finest minds in RC aviation (including Dino DGiorgio by long-distance cell phone) helped me determine the optimum CG.
In the air, it proved perfect.
It's marked on my fuse, which I still have. I'll try to get a pic for you soon.
I suppose it might be different if they changed the molds when they made the cowl bigger?
mt
< Message edited by kram -- 9/5/2012 6:40 AM >
Hide Signatures
(in reply to kram)
       Post #: 14
RE: Airworld models. Fw 190 102 - 9/5/2012 6:37 AM
2walla
Score: 100
Last Login: 5/23/2013
Status: offline
I have one with a moki. And one I am setting up with a 3w106. The moki is a bit overrated but hey it is a hobby. With the moki you need the elevator seros in the stabs. With a twin you need to put all the servos as far forward as you can. Most 150 sized motors won't fit without pRotruding. Double check your measurements. Put a couple formers in the fuse. Airworld fuses are floppy. Landing gear mounts are not that strong for a reason. The wing is tender and significant reinforcement in this area mat mean just a larger hole is left behind after a bad landing.
Hide Signatures
(in reply to kram)
       Post #: 15
RE: Airworld models. Fw 190 102 - 9/5/2012 6:58 AM
kram
Score: 110
Status: offline
2walla:
I agree on both counts.
I had to put two big Ni-cads in the aft fuse to balance it with the Moki. I'm sure with a 3W, lead will be needed up front.
Does the 3W106 fit in the Fw cowl without cut-outs for the plugs? That is a SWEET engine.
I understand what you're saying about the gear mounts. A general rule in RC aviation is when you reinforce a break point, you just move the break point up to a more expensive place.
For this particular set-up, however, I theorized:
1) My maiden landing was SO smooth the prop didn't even stop turning when the left gear broke, so the majority of my future landings were not going to be any smoother, so I had to improve things somehow
2) This plane is such a smooth flyer and lander that "bad landings" will be uncommon
My second-hand kit came with a big long thick swath of carbon fiber cloth glued to the inside of both fuse sides. Not sure if that was factory-installed or after-market.
Hide Signatures
(in reply to 2walla)
       Post #: 16
RE: Airworld models. Fw 190 102 - 9/6/2012 9:44 PM
pedro w rdz
Score: 100
Status: offline
Ok I asked for measures do dle170 plug cap to plug cap and 13.3 inches.    I will have to make 2 small holes on cowl for plugs Uffffffff
 Well I. Really want that engine.   It's got weight.  N power.
Thanks every one   For all the help.   Will post pic.  When I start building
Please send me info.  About the cg.  Of these bird    Thanks
And is it true.  That rtf. Thesebirds  weight as much as 40 lbs.     Wow
Kram mustang51 2wella glazier 808 blutern. Quist.    Thanks
Hide Signatures
(in reply to kram)
       Post #: 17
RE: Airworld models. Fw 190 102 - 9/8/2012 8:52 PM
pedro w rdz
Score: 100
Status: offline
Where did you all go are you guys flying jeje   Enjoy
Please when you get back I'll be here waiting for you all   To help me with my project
Pedro WRdz
Hide Signatures
       Post #: 18
RE: Airworld models. Fw 190 102 - 9/15/2012 10:25 PM
kram
Score: 110
Status: offline
Pedro:
Sorry, busy hosting my event last weekend (then recovering from it)
The CG is best set at the second rivet line back from the "exhaust port" on the molded fuselage
Another way of describing it: extrapolate the leading edge all the way to the fuse side with a straight-edge. It's 5.5" back from that point.
I would show you pictures, but my fuselage isn't in very good shape in that region!
If you post a full length and a front half pic of your fuse, I can show you where.
It seemed too far forward, but it flew great.
< Message edited by kram -- 9/15/2012 10:49 PM >
Hide Signatures
       Post #: 19
RE: Airworld models. Fw 190 102 - 9/15/2012 10:45 PM
kram
Score: 110
Status: offline
Here's a pre-crash photo of my plane, edited with a vertical red line to show the correct CG
Good Luck!
Click for fullsize
Hide Signatures
(in reply to kram)
       Post #: 20
RE: Airworld models. Fw 190 102 - 9/16/2012 7:40 PM
pedro w rdz
Score: 100
Status: offline
Hey Kram
Thanks.  For the. Cg
It's very clear on the picture
I promise.   Will up load pictures as soon as I star working on it
Hide Signatures
(in reply to kram)
       Post #: 21
RE: Airworld models. Fw 190 102 - 10/15/2012 6:24 AM
pedro w rdz
Score: 100
Status: offline
 Ok started  installing motor   On these bird.
Here pictures
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 22
RE: Airworld models. Fw 190 102 - 10/15/2012 6:26 AM
pedro w rdz
Score: 100
Status: offline
While installing  motor.  Found. That the canopy air piston was removed   So i have to ask
Where can i buy the piston
Hide Signatures
       Post #: 23
RE: Airworld models. Fw 190 102 - 10/15/2012 4:36 PM
vertical grimmace
Score: 154
Status: offline
Mcmaster Carr
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
       Post #: 24
RE: Airworld models. Fw 190 102 - 10/15/2012 5:08 PM
pedro w rdz
Score: 100
Status: offline
Vertical grimmace
They have everything you could need
Any one has bought a piston  For the fw 190 canopy That could help me with the part number   Couldnt find the right one jeje
Thanks. Again
Hide Signatures
(in reply to vertical grimmace)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.484RCU1
