RE: Need a Good Spray Gun    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> RE: Need a Good Spray Gun
Page: <<   < prev  1 [2]
Login
RE: Need a Good Spray Gun - 9/9/2012 4:25 PM
PatrickCurry
Score: 110
Last Login: 6/19/2013
Status: offline
Really?  Have you ever purchased anything online?  I digress.  I apologize for trying to add anything to the conversation.
Hide Signatures
(in reply to LesUyeda)
       Post #: 26
RE: Need a Good Spray Gun - 9/11/2012 1:10 PM
ARUP
Score: 144
Last Login: 6/20/2013
Status: offline
I use a Badger Model 400 touch up gun and Prime Air Model 2500 set at 30psi to the gun. They are over 10 years old. After trial and error the gun is set perfectly for 50/50 dope/ thinner mix. The downside is that the gun's paint cup is small and the compressor cycles a lot for bigger projects like what you want to paint. Since I'm never in a hurry I'm very happy with adding paint mix and waiting for compressor to get up to pressure. Most importantly, I'm happy with the results.
Hide Signatures
       Post #: 27
RE: Need a Good Spray Gun - 10/8/2012 2:34 AM
mark IX
Score: 100
Status: offline
OK, guys I finally got some time to try my touch up gun with the new Home Depot regulator. I wanted to prime my Spitfire with Benjamin Moore latex . I mixed up the paint with a 50% water and paint mix. At first I mixed a batch with denatured alcohol but that seemed to "curdle" the paint somehow. So I decided to stay with the water mix. When I set the regulator at the gun to 25-30 psi it seemed to spray quite well. The temp today was 50F as well. I was a little worried about that. Any way buying the regulator made all the difference. The spray pattern was controllable and even, although I did notice some pulsating in the gun as I was applying the paint.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to ARUP)
       Post #: 28
RE: Need a Good Spray Gun - 10/9/2012 1:20 PM
scale only 4 me
Score: 329
Status: offline
Glad it worked better for you,
You need to remember that it's just a flow regulator, extra pressure can't bleed off anywhere like the regulator on the compressor, if you let it sit the compressor pressure will build up to the gun's valve/trigger, the first few pulls and it evens down to the setting at the regulator. If you get a real big burst turn down the compressor more. Play with it and you'll find a good balance, but you'll never get rid of that initial burst, you can minimize it though..
What I do is 2-3 pulls against the table or in the air then move down to the piece, you never want to start the paint stream on the subject anyway
good luck
Hide Signatures
(in reply to mark IX)
       Post #: 29
RE: Need a Good Spray Gun - 10/9/2012 1:27 PM
Old Fart
Score: 158
Status: offline
Lordy me scale only fair enough to have a chat about what you think you know but this advice is leading mk9 down the wrong track.Don't mean to be rude to you or other people reading this.
_____________________________
Watch out for the ground eh?
Hide Signatures
(in reply to scale only 4 me)
       Post #: 30
RE: Need a Good Spray Gun - 10/9/2012 1:38 PM
scale only 4 me
Score: 329
Status: offline
You're intitled to your opinion, I'm only relating what works well for me.
Hide Signatures
(in reply to Old Fart)
       Post #: 31
RE: Need a Good Spray Gun - 10/9/2012 8:07 PM
acerc
Score: 221
Status: online
I will unplug my gun if stopping for more than a few seconds. Also give's the opertunity to reshake the mix when plugging back in.
I was taught to start to spray before the object and finish the spray after the object. Move the body not the hand or solely the hand, help's keep an even distance from the object.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 32
RE: Need a Good Spray Gun - 10/9/2012 8:12 PM
acerc
Score: 221
Status: online
Not looking to stir the pot so to speak. But, old fart, your gallery supports your advice. LOL
Robert
Hide Signatures
(in reply to acerc)
       Post #: 33
RE: Need a Good Spray Gun - 10/10/2012 3:30 PM
jester_s1
Score: 233
Status: offline
What's wrong with what scale said old fart?
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
(in reply to acerc)
       Post #: 34
RE: Need a Good Spray Gun - 10/11/2012 4:48 AM
Leroy Gardner
Score: 117
From: Coeurd'''''''''''''''''''''''''''''''' ALENE,
Status: offline
One thing is obvious here, some guys are painters and others just paint stuff. Painting the many products can be achieved by most anyone with some understanding of how to mix the product ( get the right viscosity ) and adjust the pressure to provide a nice smooth pattern. All paints do not spray the same, meaning the viscosity and pressure vary from paint to paint. Laytex is a heavy bodied paint and has to be thinned alot to go on smoothly and the gun will determine that. Suction guns most always require more pressure and volume. HVLP will produce great results and hardly any over spray at 10-15 PSI at gun inlet, a regulator is needed there to prevent air serges and the same applies to suction guns. Always spray straight on as much as possible to get the best results from the spray pattern. Cheep 2mill clear tarp is a great product to set your gun up on.
A good 2 stage air brush and a good HVLP spray gun and you can paint anything but your compressor will have to meet the requirements of the Larger gun no matter what it is. Practice makes perfect so do alot of it before you start on your plane, it won't take long to get the hang of it. Leroy
Leroy Tiger Club # 53, TF 1/5th P-51 mustang
Eagle 2'' bashed Tiger 60
Hide Signatures
(in reply to jester_s1)
       Post #: 35
RE: Need a Good Spray Gun - 10/11/2012 12:41 PM
Old Fart
Score: 158
Status: offline
I may be at fault for not properly wording my reply it's an old tradesmans habit,and a bad one at that. I've also read leroys posts from the past re spraypainting and he knows and explains how better than most.Dead right about painters too,there's paint sprayers and spraypainters,a massive differerence between the two.Cheers all
Hide Signatures
(in reply to Leroy Gardner)
       Post #: 36
RE: Need a Good Spray Gun - 10/11/2012 8:16 PM
scale only 4 me
Score: 329
Status: offline
So you just drop an innuendo bomb and say oops my bad? LOL
Hide Signatures
       Post #: 37
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.047RCU1
