RE: Goldberg Tiger Club    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Goldberg Tiger Club
Page: <<   < prev  18 19 20 21 22 [23] 24 25 26 27   next >   >>
Login
RE: Goldberg Tiger Club - 12/24/2012 4:09 AM
52larry52
Score: 120
Last Login: 5/25/2013
Status: offline
I am looking for C/G information for a Goldberg Tiger 120. I am restoring one for a fellow club member and he is the second or third owner and has no paperwork for the plane. I know one of you Tiger fans will have this C/G spec. I'am sure that this was an ARF version if that matters. The airframe was badly fuel soaked in the engine compartment and lower fuselage area. The main gear had been torn out of the wings and required new mounts and reinforcement in that area. Just finishing up the wings now, have the fuselage done and ready for covering and will want to balance it after reassembly prior to it's test flight. Nice plane, wish they still made the 120 size. Think I might settle a 60 size kit for myself. Thanks in advance for the C/G help.
Hide Signatures
(in reply to computermonkey)
       Post #: 551
RE: Goldberg Tiger Club - 12/24/2012 2:40 PM
Crazy4Flight
Score: 110
Status: offline
http://manuals.hobbico.com/gbg/gbga1077-manual.pdf
for the Tiger 120 ARF are:
LOW HIGH
AILERONS 3/8" 1/2"
ELEVATOR 3/8” 1/2"
RUDDER 1-1/2"
To determine the Center of Gravity, measure back on the fuselage 3-7/8" from the leading edge of
the wing. The C.G. range for this aircraft is 3-3/4 to 4-3/4".
Hide Signatures
(in reply to 52larry52)
       Post #: 552
RE: Goldberg Tiger Club - 12/24/2012 11:18 PM
52larry52
Score: 120
Status: offline
Thank you Crazy4flight, That's just what I needed to know. Merry Christmas
Hide Signatures
(in reply to Crazy4Flight)
       Post #: 553
RE: Goldberg Tiger Club - 12/25/2012 2:34 AM
jkr_1100
Score: 105
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: 52larry52
this is a straight with with no taper in the plan view. so 33% of the MAC would be exatly 1/3 of the way from LE towards the TE. If you can't find the manual.
_____________________________
AMA 414878 - Cub brotherhood - Tiger Club #1
Club Saito #789 - 50,91,125,125,150S,180
Hide Signatures
       Post #: 554
RE: Goldberg Tiger Club - 12/25/2012 2:35 AM
jkr_1100
Score: 105
Status: offline
quote:
ORIGINAL: Crazy4Flight
LOW HIGH
AILERONS 3/8'' 1/2''
ELEVATOR 3/8” 1/2''
RUDDER 1-1/2''
To determine the Center of Gravity, measure back on the fuselage 3-7/8'' from the leading edge of
the wing. The C.G. range for this aircraft is 3-3/4 to 4-3/4''.
what the manual says, Thanks Bob.
Hide Signatures
       Post #: 555
RE: Goldberg Tiger Club - 12/25/2012 2:49 AM
jkr_1100
Score: 105
Status: offline
merry christmas everyone!!
Hide Signatures
(in reply to jkr_1100)
       Post #: 556
RE: Goldberg Tiger Club - 12/30/2012 4:12 PM
psmith36
Score: 100
Last Login: 5/11/2013
Status: offline
Hey all! I am starting to build the Tiger 2 and was wondering how a 52 magnum 4 stroke would pull it around. I origonally bought a 55ax to instal but have since put it in a T/H Kaos. I plan to build it as a tail dragger and modify it to have dual ailaron servos. I am also considering cowling it in after viewing some of the nice planes on this web site. Any feedback would be great. Thank you!
Hide Signatures
       Post #: 557
RE: Goldberg Tiger Club - 12/30/2012 4:29 PM
jkr_1100
Score: 105
Status: offline
quote:
ORIGINAL: psmith36
I think that engine will fly it around well. you will not have giant vertical up lines. I like to go overboard on everything. I had a Saito 125 on my Tiger 2 and it was really great. I bet a 91 would make you really happy. when o bought the plane used it had an OS 40 2 stroke and a ton of nose weight to make it balance. when i put the saito 125 on it i had to add 1/2 oz to the tail at the elevator. this plane tends to be tail heavy because of the long tail.
good luck , happy new year, and please send us build pics.
Hide Signatures
(in reply to psmith36)
       Post #: 558
RE: Goldberg Tiger Club - 12/30/2012 4:33 PM
Crazy4Flight
Score: 110
Status: offline
I have an OS.52 4-stroke in my girlfriends Tiger II ( kit built) no lack of power for it. just wont go vertical forever.
It balance perfect...loops rolls split-s cuban-8 andgreat fuel economy.
standard trike gear, and 6 std servos-dual aileron + 1 for the flaps whichwere added by the builder about 30% of the original ailerons
If the 52 is what you have no need to spend a lot of money on over kill motor.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 559
RE: Goldberg Tiger Club - 12/30/2012 10:48 PM
thailazer
Score: 110
Status: online
quote:
ORIGINAL: psmith36
Here's what a Tiger 2 can do with a 35AX. Your 52 would pull it along much better than this. I only use full throttle on take-off and on up lines.
Tiger Flyer #49
Hide Signatures
       Post #: 560
RE: Goldberg Tiger Club - 12/31/2012 5:21 PM
psmith36
Score: 100
Status: offline
Thanks for the comments I will keep them in mind. I have heard of the problems with the tail being heavy so maybe I will go slightly larger.
Hide Signatures
(in reply to thailazer)
       Post #: 561
RE: Goldberg Tiger Club - 1/3/2013 12:15 PM
thailazer
Score: 110
Status: online
Had some fairly gusty winds today and had a handful on take off when a gust caught the ship right at rotation. After a few wild seconds, up away from too much danger! Was a lot of fun to hit the top of a loop with no or almost no ground speed. After two flights, thought I should park it and ease the nerves! The Tiger is a great windy day flier, but it was a bit too much today.
Tiger Flyer #49
Hide Signatures
       Post #: 562
RE: Goldberg Tiger Club - 1/4/2013 10:55 PM
Leroy Gardner
Score: 116
Last Login: 5/22/2013
From: Coeurd'''''''''''''''''''''''''''''''' ALENE,
Status: offline
quote:
ORIGINAL: psmith36
Yes the tail is heavy and it also lacks some authority. You can solve part of the problems by adding width to rudder and elevators, you don't have to add the balance tabs like I did and then drill the heck out of it to lighten it up and you probably won't even add any weight.
Click for fullsize
Leroy Tiger Club # 53, TF 1/5th P-51 mustang
Eagle 2'' bashed Tiger 60
Hide Signatures
       Post #: 563
RE: Goldberg Tiger Club - 1/5/2013 1:06 AM
GAToland
Score: 100
Status: offline
Leroy your Tiger is really looking good.
Gary
Goldberg Tiger Club #55
Hide Signatures
(in reply to Leroy Gardner)
       Post #: 564
RE: Goldberg Tiger Club - 1/5/2013 2:27 AM
Leroy Gardner
Score: 116
Status: offline
Thanks Gary, the complete build can be seen here, www.rcuniverse.com/forum/m_11326847/tm.htm
Hide Signatures
(in reply to GAToland)
       Post #: 565
RE: Goldberg Tiger Club - 1/5/2013 3:40 AM
sgu
Score: 100
Status: offline
 So Proud to be # 54
Click for fullsize
Goldberg Tiger Club #54
Hide Signatures
       Post #: 566
RE: Goldberg Tiger Club - 1/5/2013 3:57 AM
rye
Score: 110
Status: offline
Hey that's cool were do I get mine at
Hide Signatures
(in reply to sgu)
       Post #: 567
RE: Goldberg Tiger Club - 1/5/2013 4:34 PM
Twin_Flyer
Score: 108
Status: offline
just a guess but I bet you make it yourself!
love the idea too!!!
Bill S.
Carl Goldberg Ultimate Brotherhood #56
Ultra Sport Brotherhood #135
http://radiocontrolhobbies.freeservers.com
Hide Signatures
(in reply to rye)
       Post #: 568
RE: Goldberg Tiger Club - 1/5/2013 10:59 PM
sgu
Score: 100
Status: offline
Thanks guys, I am finding much of the fun in building is learning new skills. I had an idea of what I wanted on the tail but then, how to do it?
I used Papilio clear inkjet waterslide paper to print the decal (you can get a sample page shipped for about $3.50 ( http://www.texascraft.com/hps/catalog/Inkjet_Waterslide_Decal_Paper-orderby_0-p-1-c-250.html )
After printing I coated it with a clear-coat to waterproof the ink, cut it out, dropped it in some water and slid it onto the tail. Unfortunately the edges started to curl up so I left a flat ruler on the decal for an hour so that the edges would stick. Now I just need to get some fuel-proof clear to protect it.
For the graphics I used Photoshop Elements 8. I typed the top text using the Text tool, then right-clicked and selected "Warp Text" then "Arc Upper" with max bend and lots of vertical distortion. Then Arc lower for the bottom text. Unfortunately, it didn't end up as a passable circle so I selected all and pasted to a new blank file, this allowed me to adjust the aspect ratio and get it looking pretty good.
Here is a blank if anyone wants to use it.
Dave
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Twin_Flyer)
       Post #: 569
RE: Goldberg Tiger Club - 1/6/2013 1:49 AM
jkr_1100
Score: 105
Status: offline
quote:
ORIGINAL: sgu
 So Proud to be # 54
VERY cool. You are the star Tiger club member for January 2013.
Hide Signatures
(in reply to sgu)
       Post #: 570
RE: Goldberg Tiger Club - 1/6/2013 2:47 AM
sgu
Score: 100
Status: offline
quote:
ORIGINAL: jkr_1100
Great! Now I know what my next sticker will be...
Click for fullsize
Hide Signatures
       Post #: 571
RE: Goldberg Tiger Club - 1/16/2013 11:01 AM
CHassan
Score: 105
Last Login: 5/17/2013
Status: offline
My first powered plane was a Sky Tiger, back in the early 80's. My dad, brother, and I all shared that plane. I bet it had a thousand hours between my 8 and 16th birthday. Only 2 air frame rebuilds, and I think the motor guts were replaced a couple times too. Since we had to take turns we would fly around and then get real high when we thought the fuel was running low. That way we had a nice long glide once the motor quit.
I had a couple other planes, but none I like so much as the tiger, so a few years after our beloved Sky Tiger passed, I bought my first big plane. A Tiger 60. That was just mine, and I did fly the hell out of it, but being a young teen and trying to impress the peanut gallery, I dumb thumbed it after a botch 4 point roll just above the bean field.
I've always threatened to get another one. I'm just getting back into flying after a 8ish year lay off. My youngest daughter is helping me build my new Ultimate Bipe. If her interest continues I guess I'll have to get another Tiger as her first trainer!
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy--
Hide Signatures
(in reply to bikerbc)
       Post #: 572
RE: Goldberg Tiger Club - 1/16/2013 2:03 PM
jkr_1100
Score: 105
Status: offline
Chassan,
That sounds like the call of destiny. IF your daughter is interested? What about what you want? I'll bet your daughter just wants to hang out with dad. A new Tiger 60 sure would be nice.
Mark
Hide Signatures
(in reply to CHassan)
       Post #: 573
RE: Goldberg Tiger Club - 1/21/2013 4:29 AM
psmith36
Score: 100
Status: offline
What do you guys thing about the evolution 10cc gas motor for my Tiger 2. I have never ran a gas motor and I'm not sure if I would have enough room for extra battery and whatever els I would need.
Hide Signatures
       Post #: 574
RE: Goldberg Tiger Club - 1/21/2013 2:15 PM
jkr_1100
Score: 105
Status: offline
It would probably be great. I don't have any experience with this engine. If it runs well I bet the Tiger 2 would fly very well with it.
I have a lead on a Tiger 120. I am trying to get the airframe, I think I have an engine that will go on it and fly it well.
Hide Signatures
       Post #: 575
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
