Trex 450 handling Characteristics    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> Trex 450 handling Characteristics
Page: [1]
Login
Trex 450 handling Characteristics - 9/2/2012 1:57 AM
gs550t1981
Score: 100
Last Login: 1/20/2013
Status: offline
   Hey, I have a question about the handling characteristics of my heli. I am flying a Hausler 450 which is a trex 450 clone. I have Hitec HS65m servos for cyclic. A spektrum rx and tx. It has a hk450 head assembly. The problem is it is not responsive at all. I have another hk450 that I fly and it is just like the simulator I am using and the radio settings are identical in both my helis but when I fly the hausler 450 the stick movements are so far in relation to actual movement of the heli. The servo arms are all lines up perfect with the head also. I don't know where to look for help. I watched all the finless bob vids during setup and assembly. Any help is appreciated. Thanks.
Jeff
Hide Signatures
       Post #: 1
RE: Trex 450 handling Characteristics - 9/2/2012 4:17 AM
Kozzy_98
Score: 100
Last Login: 5/22/2013
Status: offline
Check your swash mix and also your dual rates.
_____________________________
Helis: HK450GT - Typhoon 2215+Spektrum AR6200X, HK450G/MT - Typhoon 2218+Orange6chRX, MCPX
Hide Signatures
(in reply to gs550t1981)
       Post #: 2
RE: Trex 450 handling Characteristics - 9/2/2012 5:26 AM
gs550t1981
Score: 100
Status: offline
 See, I wass wondering about that. My swah mix is set at -60 on pitch and ail because i used that to reverse them on set up. I am still not 100% on what the swash mix is for. Also my dual rate is set at 30 with a dx6i. Should I move it to the negative?
Hide Signatures
(in reply to Kozzy_98)
       Post #: 3
RE: Trex 450 handling Characteristics - 10/5/2012 4:45 AM
jester_s1
Score: 233
Status: offline
Regardless of your radio settings, what's really important is the cyclic throw you're getting at the blades. I'd suggest before you change anything to break out the pitch gauge and compare the two helis for both collective and cyclic pitches. If it turns out they are the same or nearly so, you likely have a problem with your head.
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
       Post #: 4
RE: Trex 450 handling Characteristics - 10/7/2012 10:49 PM
whstlngdeath
Score: 105
Last Login: 2/2/2013
Status: offline
Check your head speed too. The gearing might be different between the two.
Jesse
< Message edited by whstlngdeath -- 10/8/2012 4:25 AM >
"Greater cruising speeds are possible, but the size of the earth does not warrant greater speeds." - Igor Sikorsky in 1934
Hide Signatures
(in reply to jester_s1)
       Post #: 5
RE: Trex 450 handling Characteristics - 10/7/2012 11:07 PM
john josey
Score: 110
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: gs550t1981
Do you know how to check the cyclic pitch ? should be around 7deg
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
