pattern plane recommendations
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> pattern plane recommendations Page: [1] 2   next >   >>
Login
pattern plane recommendations - 4/22/2002 4:58:26 AM
krayzc-RCU
Status: online
I have never flow pattern but I have a 46 with a tuner pipe, and a OS-160; can you all give me some recs. toward two pattern planes for these motors? thanks
_____________________________
smooth as silk!
       Post #: 1
pattern plane recommendations - 4/22/2002 5:26:36 AM
Scorpionjack
Status: offline
Zen 50 for the 46FX Flown these excellent aircraft.
Hirobo Stream 50 another superb aircraft.
Tracer by Great planes for the 46 as well. Tracks very nice building is easy Change gear to Fixed just at the leading edge.
Kaos by Bridi always superb for a pattern trainer. Will always be right up there in the Pattern trainer realm excellent aircraft.
the 1.60 well may be a little overpowered but you'll have great vertical. Znline ALLIANCE GFK Classic
http://www.probuild-uk.co.uk/products/kits/znline.php
Zen 1.40 still with the 1.60 a little over powered but you should be ok.
World Models Tai JI F3A but just to darn expensive. $2000.
(in reply to krayzc-RCU)
       Post #: 2
pattern plane recommendations - 4/22/2002 5:41:41 AM
KNIFE BROTHER
Status: offline
The Focus from Piedmont models would be an excellent plane for the 1.60 FX. The latest RCM has a review of this plane with that motor. You can get more info at [url]www.piedmontmodels.com.[/url] This ARF was flown with great succes at the last NATS. I believe Kirk Gray finished 2nd in F3A with it.
       Post #: 3
pattern plane recommendations - 4/22/2002 5:50:26 AM
rpsmithii
Status: offline
And as Knife Brother will attest - the Kyosho Majestic 1400 will do quite nicely on the 46FX.
See interesting info here:
http://www.rcaerosport.com/
Look under reviews.
Great 46 sized plane for the money.
- Bob Smith
Atlanta, GA
       Post #: 4
pattern plane recommendations - 4/22/2002 5:58:59 AM
DESERT RATT
Status: offline
The SPECTRUM by HOBBICO is a good PATTERN beginning plane as is the GLOBAL AVENGER
I'm flying a THUNDER TIGER PRO 46 with a tuned pipe in the SPECTRUM and an OS 70 4 stroke in the AVENGER.
Both are fun fly on "RAILS" type fliers.
GLOBAL also has a new one out,the "VANCE" I've heard good things about it also.
The "ZEN" I haven't owned but never heard bad! ( It is expensive) and the BRIDI "KAOS" is another great one in kit form.
I have one friend who won't be without one. If he dumps one he builds another!
And there is also others.
RON in NEVADA
THERE'S NO SUCH THING AS A CRASH! IT WAS AN OBSTACLE!
(I JUST NEED TO LEARN HOW TO OVERCOME IT!)
       Post #: 5
pattern plane recommendations - 4/22/2002 6:17:07 AM
Scorpionjack
Status: offline
Forgot about the Focus KB; Thanks.
I have the Majestic and fly it on a YS 63. Superb aircraft mostly just fly it 3D with a YS 53 or the 63 it wold make a nice F3A practice aircraft. 46FX not sure. KB how's the vertical with the 46FX?
The Spectrum is ok but has a very weak landing gear. Change it too, by sealing the retracts and putting a front mounted gear just at the Leading edge of the wing and it will be even better.
       Post #: 6
pattern plane - 4/22/2002 6:23:18 AM
jon595
Status: offline
Go for the Zen 50, mine had a Saito .56 fourstroke. It had constant speed and good handling just like the bigger planes. And for the price you cannot beat it. Realyy enjoyed watching that freestyle exhibition put on by Naruke that day last month.
Take care,
Jon
       Post #: 7
pattern plane recommendations - 4/22/2002 7:56:05 PM
Aresti-RCU
Status: online
I am currently working on a Hirobo Steam 50. The plane screams for a 4-stroke (YS 63!). It looks like a miniature F3A plane: fiberglass cowling, pipe tunnel, soft mount, retracts, etc. (All included in the kit!). To complete the looks you will to add a Hatori header and pipe. You could use a two stroke, but the openings in the cowling will look terrible. According to the instructions, the OS 52 with flex pipe is another option.
       Post #: 8
pattern plane recommendations - 4/23/2002 1:03:23 AM
robert
Status: offline
For the 46, I saw a cuban forty that was perfect for this engine. Its in an article and I will dig it up for you if you want. Its an ARC, but none of the c*** you can get. I think its designed for the 46FX and pipe. The Zens are also good, and EZ have released an Alliance, for around that range. Not sure what exactly what engine size though.
For the 160, anything you want really. Check out the [url]www.znline.com[/url] or [url]www.plprod.com[/url]
They are the main manufacturers around now, although there are alot more.
Hope this helps,
Robert.
       Post #: 9
pattern plane recommendations - 4/23/2002 1:17:14 AM
Sport_Pilot
Status: offline
Check out http://www.bridiradiocontrol.com. The giant Chaos and Dirty Birdy look like good choices for that 1.6. Bridi Kits are great quality as well as value. You don't get die crunched or lazer burned parts. Instead you get cut and sanded parts that are ready to be glued as is.
       Post #: 10
pattern plane recommendations - 4/23/2002 2:28:41 AM
3DRC
Status: offline
Krazy???? Don't do it.... You can't be serious..... No!....
They don't use gas and they can't 3D...... Don't let them sway you.....
Bean
"Experience is what you get, right after you needed it"
       Post #: 11
gettting closer - 4/23/2002 5:48:29 AM
krayzc-RCU
Status: online
3DRC,
It kind of like G-2 and your beginning I have flown hellos on g-2 but never in real life. You and I know those edge are so easy to 3D. Over here in Japan all are flying pattern planes or trainers, about 10-12 flyers. I am on a kick to win me a trophy they are having a contest over here in Oct 2002, I leave out of here headed back to NC in Dec 2002. Then I will have my hands back on that AW 29% Edge and of course I will have ordered that 40% Radio Craft 330 with a DA on cans ( I know a Harley should sound like a Harley) he he, I just don't want to be the one who cause up to loose our field, as I usually get in 2-3 flight 4-6 times a week in NC, that edge of mine was noisy as all until 10 flights later I went to a J & H peacekeeper, man was it annoying to me while I was trying to adjust all that is needed to be adjust on a new bird.
Jon hope all is well in Cali for you it was good to see you in Japan last month maybe some of the other flyers will come visit over this way before I leave. If not, I will see Bean and the rest of the gang at the show he does in AL next year.
right now the crowd say go for the Zen 50, someone said the majestic alone the global freestylewill do some 3d. I need have a decsion by this week so i can have the bird waiting for me when i get back from 2 weeks in Hawaii with main squeeze.........
smooth as silk!
       Post #: 12
pattern plane recommendations - 4/23/2002 6:08:11 AM
Scorpionjack
Status: offline
Krazy;
Where in Japan I just came back from Okinawa. Kadena!
       Post #: 13
pattern plane recommendations - 4/23/2002 7:01:23 AM
krayzc-RCU
Status: online
Scorpionjack
i am on Kinser; I hope the new place you are located doesn't always have the12-25 MPH wind that we always have over here. You know how it makes the flyers look that don't fly the rudder like they arer flying the cox planes on the string he he.
smooth as silk!
       Post #: 14
pattern plane recommendations - 4/23/2002 7:44:31 AM
Scorpionjack
Status: offline
KC,
Nah! Predominant 15 Mph. Just had snow this week darn can't do diddly! But I have been building and flew a few in the front yard the other day. Have you met up with the guys at Tori? They fly all the time. Also Yomitan except dodging cars when they come down the road.
Email me normal I started a F3A competition there at Futenma years ago and the guys just had another one.
Great bunch a guys but they are novices and they only use what The locals use no originality. I did the same thing flying a Tai Ji with a YS 120. The Zen's are all good aircraft as are the Tai Ji and all that have been mentioned thus far. Majestic, Stream 50 etc. are all excelent as well. You'll find the one that fit's you. As for 3DRC's comment when you can hover your Pattern plane/Torque Roll it as well with the Majestic/Stream Hyper/G-Trick 90 do any of the 3D maneuvers as well as F3A pattern then bring your little Funfly's along for the ride. : ) Precision with Attitude : )
       Post #: 15
pattern plane recommendations - 4/23/2002 10:30:05 AM
