WHen lifting heli goes left.....    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> RC Helicopter Beginners Forum >> WHen lifting heli goes left.....
Page: [1]
Login
WHen lifting heli goes left..... - 9/3/2012 4:17 PM
RcChris1
Score: 100
Last Login: 9/3/2012
Status: offline
Hello, well i am new to the heli world. its a walkera 4# and everytime i go to lift up it just flys left and crash. this is within an inch or two of lifting up...can anyone help ?
Hide Signatures
       Post #: 1
RE: WHen lifting heli goes left..... - 9/3/2012 5:01 PM
BrettOssman
Score: 100
Last Login: 2/8/2013
Status: offline
I'd check out some of the free helicopter flying lessons online.  Yes, lessons.  Flying helis is not as easy as most newbies would think.  One set of lessons, for example, is on http://www.rchelicopterfun.com/how-to-fly-rc-helicopters.html.  There are others as well, but pretty much the same.  Also, get a sim, if you don't have one.  Can't imagine anyone saying getting a sim is a bad idea.
You'll likely get respones to this problem specifically, but you really need an overall plan.
< Message edited by BrettOssman -- 9/3/2012 5:28 PM >
Hide Signatures
(in reply to RcChris1)
       Post #: 2
RE: WHen lifting heli goes left..... - 9/3/2012 5:28 PM
BrettOssman
Score: 100
Status: offline
Oh, you may also want to look into transmitter settings for your heli to tame it down, while you learn it.  For example, I just got Blade mCPx, and am trying these settings: http://www.helifreak.com/showthread.php?t=407020.  NOW, recommended settings for your heli could be quite different.  I have 3 helis, and each one's "tamed down" settings are different.  I'll let someone familiar with your Walkera heli help you there.
Hide Signatures
(in reply to BrettOssman)
       Post #: 3
RE: WHen lifting heli goes left..... - 9/4/2012 4:36 AM
madmorgan
Score: 100
Last Login: 12/27/2012
Status: offline
going to the left on takeoff is pretty normal on take off the more you get use to take offs you will learn to use a bit of right input to tame it!
_____________________________
if you dont know you better ask somebody ! usarmy active 1989-1997, 1990 desert sheild /desert storm, 1993 somolia .
Hide Signatures
       Post #: 4
RE: WHen lifting heli goes left..... - 9/4/2012 6:57 AM
Solman
Score: 100
Last Login: 5/15/2013
Status: offline
It is most likely out of trim.  Every time I give the car more throttle, it goes to the left.  It is the same concept.  Make sure your swash is level and give it some right trim if needed.  if it is far off, then you will most likely either need to adjust it mechanically and/or adjust  your sub trim.
If a heli is properly trimmed, that should not be the case.
Trex 450 Pro / Trex 500 / Trex 600E
AR7200BX microbeast IKON
Hide Signatures
(in reply to madmorgan)
       Post #: 5
RE: WHen lifting heli goes left..... - 9/4/2012 6:16 PM
madmorgan
Score: 100
Status: offline
so all of your helis take off straight up solman?
Hide Signatures
(in reply to Solman)
       Post #: 6
RE: WHen lifting heli goes left..... - 9/4/2012 6:35 PM
Solman
Score: 100
Status: offline
Yep, once they are trimmed out.  Now if the winds are fairly strong, then I will most likely have to compensate.
Hide Signatures
       Post #: 7
RE: WHen lifting heli goes left..... - 9/4/2012 7:00 PM
Real2You
Score: 100
Last Login: 5/1/2013
Status: offline
One other thing that could contribute to your heli lifting off to the left is the ground effect. You can get out of the "rotor wash" by lifting off like say 2 feet or more.For me...lifting off was much easier once I got the heli up QUICKLY to about 3 feet. The blades are pushing all that air downward and it comes back up off the ground "weird"...pushing your heli around weirdly. Now you still have to be trimmed properly and the heli set-up right.
Hide Signatures
       Post #: 8
RE: WHen lifting heli goes left..... - 9/4/2012 8:46 PM
madmorgan
Score: 100
Status: offline
i would love to see a video of that no hands on the right stick  taking off  and the heli not wanting to go left trim or no trim!
Hide Signatures
(in reply to Real2You)
       Post #: 9
RE: WHen lifting heli goes left..... - 9/4/2012 10:52 PM
Solman
Score: 100
Status: offline
I am not sure why you find that so hard to believe.  Not trying to put you down, but it doesn't sound like you have much experience with heli's.  I have a Trex 450 Pro and Trex 600 and I don't have that issue with them.
Hide Signatures
       Post #: 10
RE: WHen lifting heli goes left..... - 9/5/2012 6:24 AM
madmorgan
Score: 100
Status: offline
not trying to put you down but if you have to add any trim then you need to go back through your mechanical setup!  PEACE!
Hide Signatures
       Post #: 11
RE: WHen lifting heli goes left..... - 9/5/2012 7:23 AM
Solman
Score: 100
Status: offline
You aren't putting me down by any means because I have confidence in what I say.  The purpose of trim is to make minor corrections.  When dealing with a flybar heli, it isn't unusual to make a few minor adjustments after making the larger mechanical adjustments.
Hide Signatures
       Post #: 12
RE: WHen lifting heli goes left..... - 9/5/2012 5:08 PM
madmorgan
Score: 100
Status: offline
yeah well we could go back and forth all day long  your helis fly so great  the op has a problem on take off  he is new  so i called you out since your a hero  and you have to use trim  to get it to fly decent lmao.   i called you out i want to see your bird take off perfectly with no cyclic input is all. sounds like to me your the one that doesnt have a clue !
Hide Signatures
       Post #: 13
RE: WHen lifting heli goes left..... - 9/5/2012 6:38 PM
dadragon
Score: 112
Last Login: 3/14/2013
Status: offline
I read all this stuff on setting one up my problem is where to start with putting all the numbers in the TX,I have no idea on the settings.I totally destroyed a nexes 30 about a week ago just trying to get it off the ground.I fly giant scale planes no problem,I'd love to fly choppers I would not need an air field.there is not anyone around to get me started.oh well.
Hide Signatures
       Post #: 14
RE: WHen lifting heli goes left..... - 9/5/2012 8:35 PM
Solman
Score: 100
Status: offline
If you want to do a video chat via skype or yahoo, let me know and I can walk you through it.  What radio are you using?
Hide Signatures
(in reply to dadragon)
       Post #: 15
RE: WHen lifting heli goes left..... - 9/5/2012 9:56 PM
ATVAlliance
Score: 113
Last Login: 5/16/2013
Status: offline
If any heli with a right mounted tail rotor doesnt go left on liftoff...that means you have the mechanical setup off a bit to compensate.
ALL helis that are right side tail rotor, go left on liftoff.  It shouldnt be extreme or your mechanical setup is off in the other direction.
Most of us dont really realize this after learning to fly as our thumbs (and/or pinch) compensates or we just "jump" right into the air and dont lift off slowly.
Not trying to be argumentative here...its a condition that real helicopter pilots have to compensate for as well...given that their tail rotor is on the right side of the boom looking from the boom to the canopy.
A left side tail rotor would do the inverese, make the heli want to go right on takeoff.
SpeedDemon
ATVAlliance.Com
Hide Signatures
       Post #: 16
RE: WHen lifting heli goes left..... - 9/5/2012 11:00 PM
BrettOssman
Score: 100
Status: offline
What are the settings you got for your heli and TX, and what TX do you have?
The TX manual should tell you how to enter the settings.  If you don't have a manual, I'm sure you can get one online.  I could possibly you find one.
Hide Signatures
       Post #: 17
RE: WHen lifting heli goes left..... - 9/7/2012 3:48 AM
Kwekwe
Score: 100
Last Login: 9/20/2012
Status: offline
my first WL Toys V911 would go left everytime I took off no matter how much I trimmed on Radio, having raced RC Cars years ago I SHOULD have remembered that I could adjust the tie rod ends on the servo arsm instead of coping with the left pull by adding some right stick. watched a youtube video on setup and Sproing, pop tie rod off, adjust up or down a couple of turns and Voila!
Hide Signatures
       Post #: 18
RE: WHen lifting heli goes left..... - 9/7/2012 7:45 AM
Solman
Score: 100
Status: offline
Well there  you go, we are not flying full scale heli's.  A lot of the issues that full scale has to deal with doesn't apply to us.  Don't forget that if you are flying fbl, the gyro also compensate for those changes.
I was going back and reviewing as to what may be a misunderstanding, are you talking about the tail rotor or cyclic going left?  After looking at all the posts, the original post does not mention if it is cyclic or rudder going left.
Hide Signatures
(in reply to Kwekwe)
       Post #: 19
RE: WHen lifting heli goes left..... - 9/10/2012 6:55 PM
ATVAlliance
Score: 113
Status: offline
quote:
ORIGINAL: Solman
You may be correct when you say that a lot of the issues that full scale pilots have to deal with that doesnt apply to us...but this isnt one of them.
I just reread my comment and I probably was somewhat unclear.  So let me explain better.
When I said "go left" I meant only during liftoff.  This is why some people think that their heli is "leaning" to the left.  The reality (model or full scale) is the tail rotor's horizontal "wash" is pushing the entire helicopter to the left (given its a right side mounted rotor).  When the heli gets "light on its skids" but not totally lifted off...it appears that the helicopter is tipping to the left or what otherwise would look like someone input left cyclic.
There is only 2 ways to counter this.
1.  Lift off very fast or "jump" into the air/hover
2.  Compensate with right cyclic input when lifting off (this is what I prefer as I like to slowly lift off for appearance).
Again...full scale helis react the same way.  Its something called Physics that is responsible for this.  lol
Once the heli is in the air...you dont notice this.  ONLY DURING LIFTOFF.  Or if you do notice it...something is out of trim or mechanical setup is wrong.
If your heli is actually turning right or left....then you have a gyro issue or setup issue with your rudder servo/endpoints/ect...  Yaw has nothing to do with what I was trying to give input on.  Sorry if I confused anyone.
SpeedDemon
ATVAlliance.Com
Hide Signatures
       Post #: 20
RE: WHen lifting heli goes left..... - 9/10/2012 7:40 PM
phillyD
Score: 120
Last Login: 5/18/2013
Status: offline
All ATValliance said.
If you use a swash leveler in your set up, and everything is level right through the pitch travel range, you will find that. Sometimes levelers are not used in set up and the plate is a little off in the correct direction, that would make the slow take off drift- to- the- left not as pronounced.
Cheers
Belt CP Day and Night helis, DX6i, 401 gyro, 9257, HS65MG cyc, 30A, CNC 7075 tail/head,Gaui 550 in hughes fuselage quark gyr
Hide Signatures
(in reply to ATVAlliance)
       Post #: 21
RE: WHen lifting heli goes left..... - 9/26/2012 11:23 PM
hrjrkr
Score: 100
Last Login: 3/29/2013
Status: offline
I had the same problem with my Walkera Genius CP. No matter how much trim or stick movement it would bank to the right so bad
that the main rotors would start hitting the floor. After no replies from the Chinese website I noticed an instruction booklet with separate
from the instruction manual, and put these settings with no instructions into the transmitter and everything worked "BETTER".
Hope this helps
Joe
Hide Signatures
(in reply to phillyD)
       Post #: 22
RE: WHen lifting heli goes left..... - 9/27/2012 12:50 AM
Solman
Score: 100
Status: offline
Well the original poster hasn't come back, so this worked out well.  I am curious as to whether he was talking about yaw or roll.  If he was talking about yaw, that would make much more sense.
Hide Signatures
(in reply to hrjrkr)
       Post #: 23
RE: WHen lifting heli goes left..... - 9/27/2012 12:49 PM
ATVAlliance
Score: 113
Status: offline
If he was talking about yaw, which Im pretty sure he wasnt...it would mean that his gyro is not setup correctly or malfunctioning.
I already explained why a helicopter would seem to "lean" to the left when getting light on the skids IF it is set up pefectly level in the swash and all of the rest of the head is properly adjusted.
SpeedDemon
ATVAlliance.Com
Hide Signatures
       Post #: 24
RE: WHen lifting heli goes left..... - 10/4/2012 7:26 AM
rob.rice
Score: 100
Last Login: 10/27/2012
Status: offline
22 bucks will get you a sim controller
this web site will get you a sim http://www.marksfiles.net/HeliSim/
at least you will have some idea of whats going on when you pick it up
it simulates the perfictly dailed in 450 with a mild responce
and can be dailed up to an insane it wants to CRASH it can't wate to CRASH 3d model
Hide Signatures
       Post #: 25
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.031RCU1
