ProX 260 .90    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Glow to Electric Conversions >> ProX 260 .90
Page: [1]
Login
ProX 260 .90 - 9/4/2012 1:59 AM
rem0.061
Score: 102
Last Login: 6/13/2013
Status: offline
I'm converting my Prox 260 .90 glow plane to electric. It has a flat profile fuse, so how do I mount an electric motor to it in a sturdy way?
Hide Signatures
       Post #: 1
RE: ProX 260 .90 - 9/4/2012 2:55 AM
blvdbuzzard
Score: 123
Last Login: 6/19/2013
Status: offline
If you look at how they did the small planes, you can do the same thing on a larger scale. You could also pin the ply mount the fuse with 1/16" dowels and glue.
http://www.nitroplanes.com/02a-016-yak54-depron-kit.html
http://www.nitroplanes.com/02a-014-malibu-ii-depron-kit.html
Buzz.
Hide Signatures
(in reply to rem0.061)
       Post #: 2
RE: ProX 260 .90 - 9/5/2012 1:15 AM
rem0.061
Score: 102
Status: offline
Here is a picture of the mounting area.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to blvdbuzzard)
       Post #: 3
RE: ProX 260 .90 - 9/5/2012 2:45 AM
blvdbuzzard
Score: 123
Status: offline
Does the motor fit the cut out? If so you could cut a piece of ply to fit the s cutout and then use some triangle stock on the back side vertically to add strength.
Buzz.
Hide Signatures
       Post #: 4
RE: ProX 260 .90 - 9/5/2012 2:59 AM
rem0.061
Score: 102
Status: offline
It might need a millimeter or two shaved out to fit, but I also want the mount to reach around to the engine mounting holes, because fast tight 3D moves stress the mount alot from the gyroscopic resistance from the prop. I think I could just bolt a thick layer of ply in there like you said. I will be using a 4258 500kv motor, a 5000mah 6s lipo, and a 100A HK ESC. (one of the few conversions that costs less than buying an engine).
Hide Signatures
       Post #: 5
RE: ProX 260 .90 - 9/6/2012 1:21 AM
blvdbuzzard
Score: 123
Status: offline
If you used the X mount on the ply wood at the rear, the ply wood pinned and supported by triangle stock, it should hold as well as anything.
Buzz.
Hide Signatures
       Post #: 6
RE: ProX 260 .90 - 9/6/2012 12:23 PM
rem0.061
Score: 102
Status: offline
I will find out towards the end of the month if it works.
Hide Signatures
       Post #: 7
RE: ProX 260 .90 - 10/12/2012 2:21 AM
rem0.061
Score: 102
Status: offline
I finished the conversion and have pictures for anyone else interested in converting their Prox 260. It isn't the nicest looking setup but it should get the job done. I have not flown it yet.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: ProX 260 .90 - 10/13/2012 12:40 AM
rem0.061
Score: 102
Status: offline
Flew it today, it works. The ESC has less precise throttle in the upper range. It is nose heavy. I don't know how well the motor can handle the gyroscopic forces of 3D flying, the can/bell flexes. The 15x4W prop has just enough thrust to pull it up. It could probably turn a 16-17x4W at under 50 Amps.
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
