RE: Saito FG57 Fourstroke    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: Saito FG57 Fourstroke
Page: <<   < prev  1 2 3 4 5 6 [7] 8   next >   >>
Login
RE: Saito FG57 Fourstroke - 10/4/2012 2:21 PM
Old Fart
Score: 158
Last Login: 5/20/2013
Status: offline
Lunatics ain't bad company friend,specially with bathurst coming up
_____________________________
Watch out for the ground eh?
Hide Signatures
(in reply to the pope)
       Post #: 151
RE: Saito FG57 Fourstroke - 10/4/2012 2:27 PM
Old Fart
Score: 158
Status: offline
Hi ernie thats a big thing to consider am doing it now.I want to make sure that there is a lot of incoming air directed over the exhaust side of the engine been reading about that a lot.Anyone with pics is welcome to post them,will do the same with mine next week if i can get the bloody thing to work
Hide Signatures
(in reply to Ernie Misner)
       Post #: 152
RE: Saito FG57 Fourstroke - 10/4/2012 8:41 PM
Ernie Misner
Score: 130
Status: offline
Hey pope, what planes are your mintors going on? I'll need a home for my DLE 20cc.
Thanks, Ernie
Hide Signatures
       Post #: 153
RE: Saito FG57 Fourstroke - 10/4/2012 10:41 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Ernie Misner
How do they keep the Saito gassers from running too hot on gasoline? Different valve seats or? Doesn't gas run hotter?
Thanks, Ernie
My testing W/glow ignition/glow fuel, CDI ignition/glow fuel & CDI ignition/E85 on an FA150 showed the following.
Cylinder Head Temperature between the rocker covers @ the rear:
CDI/GF +20*F from GI/GF + 150 RPM W/18X8 prop
CDI/E-85 +60*F from CDI/GF - 350 RPM W/18X8 Prop
CDI/E-85 +80*F from GI/GF -200 RPM W/18X8 prop.
I woudld expect gasoline to run even hotter than E-85
< Message edited by SrTelemaster150 -- 10/5/2012 12:08 AM >
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 154
RE: Saito FG57 Fourstroke - 10/4/2012 10:53 PM
Ernie Misner
Score: 130
Status: offline
Thanks for the great data. E85 is ethanol free 85 octane gas? From what source?
Thanks again, Ernie
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 155
RE: Saito FG57 Fourstroke - 10/5/2012 12:07 AM
SrTelemaster150
Score: 229
Status: offline
Thanks again, Ernie
E-85 is 85% ethanol 15% gasoline.
You can FIND E-85 STATIONS HERE.
It is higher octane & will tolerate higher compression & more spark advance. It does require about 30% more delivery volume than straight gasoline. An engine can be tuned for more HP on E-85 over gasoline if the compression ratio is high enough to take advantage of the octane.
Hide Signatures
       Post #: 156
RE: Saito FG57 Fourstroke - 10/5/2012 12:39 AM
the pope
Score: 101
Status: offline
Thanks, Ernie
Howdy Ernie , one is going in a phoneix katana and the other in a SF 60 size trainer. With the trainer Ive moved the fire wall back about an inch and with the battery and servos moved to the rear no added weight will need to be added.
I must say the quality of the last couple of phoneix arfs Ive bought have been very good, theyve lifted their game alot . Cheers the pope
Hide Signatures
       Post #: 157
RE: Saito FG57 Fourstroke - 10/8/2012 4:23 AM
MKnutson
Score: 100
Last Login: 5/19/2013
Status: offline
Just a quick update to the percieved bearing problem..... the bearing is fine, and the notchy feel is coming from the way the straight cut cam gears mesh with the crank gear. All is fine and it runs like a top!
By the way, what planes are all you guys using this engine (FG57T), on. Mine is currently on a Great Planes Ultimate bipe 160.
Mark.
Hide Signatures
       Post #: 158
RE: Saito FG57 Fourstroke - 10/8/2012 12:50 PM
Old Fart
Score: 158
Status: offline
Good news mate,if you are really fussy they can scare you sometimes eh?
Good question mines in a blackhorse models edge 540 90".How does it fly your gp160?
Hide Signatures
(in reply to MKnutson)
       Post #: 159
RE: Saito FG57 Fourstroke - 10/8/2012 12:53 PM
affas
Score: 105
Status: offline
Mine is in a well used Carden Yak 54 for breaking in and are then going into my almost finished SisT FW 190
Best regards
Alf Hansen
Hide Signatures
(in reply to Old Fart)
       Post #: 160
RE: Saito FG57 Fourstroke - 10/8/2012 11:33 PM
kwik
Score: 105
Status: offline
Mine is used in an ESM 50cc Corsair.
I got the replacement ignition, 2 off them, free of charge from Advantage Hobby.
Here are some pictures, in case anyone is interested. They seem to be an exact copy of the original ignition, I am afraid.
You can see the RcExl logo on the third picture from left.(Lower right corner.)
You can see that feeble spring in the fourth picture, in the center.
So, this is the third ignition for this engine;
-First the original, similar to this one.
-Secondly the wrong version.
-And thirdly this set.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to affas)
       Post #: 161
RE: Saito FG57 Fourstroke - 10/9/2012 2:05 AM
j lauria
Score: 100
Last Login: 5/16/2013
Status: offline
I have just installed a Saito FG57 Twin in my 1/3 scale Ercoupe replacing a Fugi 63. I made the change in the hope of reducing vibration which was effecting my twin vertical stabs. The engine started very easily with my large electric starter and ran well on a rich setting for about one tank of fuel. I am using the reccomended 20:1 mix with Stihl Ultra oil. The exhaust is quite messy and black. Using a 22by10 prop the engine appears to have plenty of power. I am wondering if I can get rid of some of the exhaust mess by leaning it out after break in or by using another oil.
The vibration particularly at lower throttle settings appears to be less than the Fugi 63. The sound is very appealing.
Hide Signatures
       Post #: 162
RE: Saito FG57 Fourstroke - 10/9/2012 4:30 AM
MKnutson
Score: 100
Status: offline
Old Fart,
It flies my gp160 ultimate very well!
No real mods to the plane to get CG right. Smaller tank mounted aft, and radio battery mounted between wing and tail.
It flies real smooth.
I'm thinking about getting a large Decathlon later on for it.
Mark.
Hide Signatures
(in reply to j lauria)
       Post #: 163
RE: Saito FG57 Fourstroke - 10/9/2012 12:59 PM
Old Fart
Score: 158
Status: offline
Me too plus a spare,i reckon i'll crash the first one cause it sounds so good
Hide Signatures
       Post #: 164
RE: Saito FG57 Fourstroke - 10/9/2012 1:03 PM
Old Fart
Score: 158
Status: offline
quote:
ORIGINAL: kwik
Jeez mate don't half mean to be rude but whatya ****in at?? ignition systems for free which you don't seem that greatfull for and don't acknowledge some backup id t6he way i read it,apoligies if i went down the wrong track there.
Hide Signatures
(in reply to kwik)
       Post #: 165
RE: Saito FG57 Fourstroke - 10/9/2012 1:16 PM
Old Fart
Score: 158
Status: offline
Hi j i like your descriptive powers when you explain how your engine is going so far.Swinging the benchmark 22x10 got 6500 easy then i overloaded it with a 24x10.The reason was the right cylinder ring would'nt seat and now the same black goo is coming out of both pipes the same although the right pot seems to run a fraction leaner.Had to run it hotter at full throttle than i liked and rich as well.I know the ercouple beautiful looking aeroplane.Running klots200 syn in mine @20.1.Hav'nt touched the low speed needle yet.
Hide Signatures
       Post #: 166
RE: Saito FG57 Fourstroke - 10/9/2012 5:22 PM
kwik
Score: 105
Status: offline
Old Fart, I bought the second ignitions for $222 x 2 . But they were the wrong type.
The third set of ignitions ( its 2 of them) are free replacements for the second replacement.
So, yes, I am happy with that, but only mildly overjoyed.
Hide Signatures
       Post #: 167
RE: Saito FG57 Fourstroke - 10/9/2012 5:24 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Old Fart
quote:
ORIGINAL: kwik
I think he had bad experineces W/the replacement EI systems too.
Hide Signatures
       Post #: 168
RE: Saito FG57 Fourstroke - 10/10/2012 5:02 AM
JamesPool
Score: 100
Last Login: 5/14/2013
Status: offline
Hello all:
I know this has been discussed, but perhaps someone could point it out to me or help me out.  I'm breaking in my57t and one of the cylinders is dumping heavy black oil out of it.  My white wing on my t-28 was black!! Anyway,  I have about 1.5 tanks though it and I've been running it between 2 and 4.3k rpm.  Note. I'm running it very rich. Probably 6.5 turn and +1 turn above factory on the low end.
Other than the oil and that it's rich, it runs and starts on the first flip!
Thanks for the help.
James.
Hide Signatures
       Post #: 169
RE: Saito FG57 Fourstroke - 10/10/2012 5:10 AM
Ernie Misner
Score: 130
Status: offline
What kind of oil are you running? No loose or vibration muffler or header pipes, right? They used to use a black assembly grease sometimes but I don't know if that would show up coming out of the exhaust so much. We do get some black residue when something is worn or wearing inside the engine or when they are simply breaking in.
Ernie Misner
Hide Signatures
(in reply to JamesPool)
       Post #: 170
RE: Saito FG57 Fourstroke - 10/10/2012 5:19 AM
JamesPool
Score: 100
Status: offline
 I'm running klotz synthetic with castor.  Yes all coupling are tight.  I do get spit out of the other cylinder, but about 1% of what the other is producing.
Hide Signatures
       Post #: 171
RE: Saito FG57 Fourstroke - 10/10/2012 5:42 AM
Ernie Misner
Score: 130
Status: offline
Seems like that could be worrisome coming out of one cylinder. Try removing one plug at a time and comparing compression on the two jugs.
Hide Signatures
       Post #: 172
RE: Saito FG57 Fourstroke - 10/10/2012 7:04 AM
kwik
Score: 105
Status: offline
If you mean its coming out in the exhaust, then mine has done that all the time, too. And many others has mentioned it.
The first youtube video I found of it running showed us the case by holding white paper under the exhaust.
One got blackened quickly, the other not.
Here the problem is gone, after 4000 cc ( Thats 40 litres ! ) gasoline running through it, he says;
http://www.youtube.com/watch?v=Or0zOk670H4
His videos can be found by searching for
herrisonwang FG-57
on youtube.
For Nudgers videos on FG-57, search for ;
66nudger FG 57
For those interested, you can find my FG-57 videos by searching for
wikeroy FG-57
on youtube.
Mine still spits oil on one cylinder, and thats after 45 flights.
< Message edited by kwik -- 10/10/2012 4:16 PM >
Hide Signatures
       Post #: 173
RE: Saito FG57 Fourstroke - 10/10/2012 1:44 PM
Old Fart
Score: 158
Status: offline
James i think kwik is talking about "supermontanamike's you tube vids,please watch if you have time.It's all about his experiences flying an aeroworks supercub with the fg57 and he does it so well,enjoyable to watch.You will notice he gets just as nervous as we do when you first fire this engine up.
Sooner or later i had to throttle it up and get it hot enough to avoid that tenative first stage "oh my God nothing is coming out of the other pipe" syndrome,good luck with your's mate
Hide Signatures
(in reply to kwik)
       Post #: 174
RE: Saito FG57 Fourstroke - 10/10/2012 4:26 PM
sharam
Score: 105
Status: offline
Hi,
The break-in procedure outlined in the FG-57 manual is quite unusual.  Did you guys follow those steps?
Trex 700 OS105 Vbar
Logo Xxtreme 800
Hide Signatures
       Post #: 175
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: Saito FG57 Fourstroke
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
