airplane gyro updated    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Futaba 18MZ - RTF
Seller:  Newgadgets
Details:   $2,900.00   |  5/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> airplane gyro updated
Page: [1] 2   next >   >>
Login
airplane gyro updated - 9/5/2012 2:35 PM
mvarzoni
Score: 100
Last Login: 5/19/2013
Status: offline
Hello folks!
I've been out of flying fields for a while, but now I'm back.
I would like to have a gyro on my 25% extra 300 rudder and maybe on ailerons too.
I've been searching on this forum and Google, but it is all old talking. I'm looking for something more up to date.
The gyro must have the turn off option via some spare channel on my Aurora 9.
Thanks!
M.
Hide Signatures
       Post #: 1
RE: airplane gyro updated - 9/5/2012 2:40 PM
rc4flying
Score: 100
Status: offline
Look at the PowerBox "iGyro"
_____________________________
rc4flying
Joe
Hide Signatures
(in reply to mvarzoni)
       Post #: 2
RE: airplane gyro updated - 9/5/2012 3:00 PM
mvarzoni
Score: 100
Status: offline
I thank you very much,but 500 buck on a gyro is just too much for my tight budget.
Do you know something more affordable?
M.
Hide Signatures
(in reply to rc4flying)
       Post #: 3
RE: airplane gyro updated - 9/5/2012 3:06 PM
motomike
Score: 100
Last Login: 5/17/2013
Status: offline
The Eagle Tree Guardian is 3 axis and has an aux channel.  It can be operated via a spare channel.  It goes for $63 to about $75 from what I have seen.  If you forsake the aux channel and  turn off feature the Eagle A3 and the Orangerx three axis gyro are around $30 and $15 respectively.
Hide Signatures
       Post #: 4
RE: airplane gyro updated - 9/6/2012 3:48 AM
mvarzoni
Score: 100
Status: offline
Motomike, thank you, that is exactly what I need.
But I have a question.
The Guardian has 3 axes and 3 channel.
Only one channel for the aileron, but I have two aileron servos on my extra 300.
How would I connect it?
M.
Hide Signatures
(in reply to motomike)
       Post #: 5
RE: airplane gyro updated - 9/6/2012 1:18 PM
landeck
Score: 137
Status: online
The AUX channel on the Guardian is used for the second aileron.
Bruce
Bruce L. AMA# 54227
Ultra Sport Brotherhood #15
Hide Signatures
       Post #: 6
RE: airplane gyro updated - 9/6/2012 2:48 PM
motomike
Score: 100
Status: offline
Most recent MAN has review of the Guardian on page 70.
Mike
Hide Signatures
(in reply to landeck)
       Post #: 7
RE: airplane gyro updated - 9/7/2012 6:58 AM
mvarzoni
Score: 100
Status: offline
The device seems to be perfect, but could anyone tell me where I could buy one?
Nobody has it on stock.
M.
Hide Signatures
       Post #: 8
RE: airplane gyro updated - 9/11/2012 5:08 PM
motomike
Score: 100
Status: offline
Mvarzoni
I see that.  If you go to Eagle Tree website the guardian is on back order and expected in late September.  From what I gather if you wait until they show in stock, they will be gone before you can place the order.  Same is true of Hobby King which has them for $63.  might be worth ordering them to make sure you get in line.  Otherwise, I see some EBay vendors have the A3 flight stab in stock for $24 to $45.
I know that if you get the Eagle Tree, there is a rather extensive manual possibly written by someone for whom English is their first language, which takes you through the set up as well as a tutorial on the unit.  The Eagle Tree offers a lot of customization via your PC if you are so inclined.  The Eagle Tree Guardian has a separate aileron channel.   Eagle Tree has options for in flight adjust for gain and in flight switchable from 2d/3d/off.   Eagle Tree has a presence in Washington state and a phone number where you can talk to a person.  All of that is definitely worth something when compared to the other less expensive options.
How much difference there is between the $15 Hobby King Orange 3 axis flight stab, the $25 A3 and the Guardian in quality and performance, I don’t know but at $15 the orange unit has some pretty extensive forum discussion.  That might be worth a try as well.
Good luck
Mike
< Message edited by motomike -- 9/11/2012 7:03 PM >
Hide Signatures
       Post #: 9
RE: airplane gyro updated - 9/29/2012 11:58 PM
verendrye
Score: 100
Last Login: 3/14/2013
Status: offline
Hi, I have two of these Guardian units which I need to mount upside down, as indicated in the manual as being OK. I have been unsuccessful in resetting level flight and trims via the "toggle" operation, even with many tries. The knob is being used as the gain control.
Both units work in the same way.
As a result (and in confirmation), the elevator moves in the wrong direction in 3-D, and in 2-D, it wants the ailerons to roll the airplane.
I must be doing someting simple wrong. The toggle, I presume, using a three position flight mode switch on a DX-8, is to go from 3-D to off to 2D and back thru off to 3-D. The center position turns the Guardian off. Any suggestions?
thanks...
Hide Signatures
       Post #: 10
RE: airplane gyro updated - 9/30/2012 2:21 AM
dirtybird
Score: 173
Status: offline
quote:
ORIGINAL: verendrye
Hi, I have two of these Guardian units which I need to mount upside down, as indicated in the manual as being OK. I have been unsuccessful in resetting level flight and trims via the ''toggle'' operation, even with many tries. The knob is being used as the gain control.
thanks...
You are correct on the toggle.
If the unit causes the control to move in the wrong direction. Reverse the gain setting. See the manual. It discusses that.
A correct set up guardian makes flying about like driving a car. You don't need to keep the wings level. And if the elevator is correct you don't have to bother with that either.
Hide Signatures
(in reply to verendrye)
       Post #: 11
RE: airplane gyro updated - 9/30/2012 2:44 AM
verendrye
Score: 100
Status: offline
Yes, of course, the elevator is easily reversed, but in the 2-D mode, the (inverted) Guardian insists that the aircraft is upside down, and tries to roll it to upright. Reversing the aileron would only make the roll from counterclockwise, to clockwise, or the reverse.
It was suggested to me that the one-toggle operation would fix it, but it doesn't.
thanks.
Hide Signatures
(in reply to dirtybird)
       Post #: 12
RE: airplane gyro updated - 9/30/2012 5:00 AM
dirtybird
Score: 173
Status: offline
What is your airplane attitude when you toggle it?
Call Eagletree.
Hide Signatures
       Post #: 13
RE: airplane gyro updated - 9/30/2012 12:59 PM
verendrye
Score: 100
Status: offline
 Upright and level.
Eagle Tree advised me that the one-toggle would set things in order. It doesn't.
Hide Signatures
       Post #: 14
RE: airplane gyro updated - 9/30/2012 2:38 PM
dirtybird
Score: 173
Status: offline
Do both units do that?
If so call Eagletree and rant.
Hide Signatures
       Post #: 15
RE: airplane gyro updated - 9/30/2012 6:44 PM
verendrye
Score: 100
Status: offline
 Yes, the behavior is identical in both units, which were from different manufacturing runs.
Do you have units which you operate upside-down?
What sort gains ae you using?  I mounted one in a 60-sized pulse (right side up so that the pots are not ascessible) and flew briefly this morning. I was conservative, with gains on all three set at 40, and only tried 2-D.
thanks
Hide Signatures
       Post #: 16
RE: airplane gyro updated - 9/30/2012 11:23 PM
dirtybird
Score: 173
Status: offline
I have never tried to operate it upside down.
My gains are set to maximum. I think its maximum. Its hard to see those little dots. I get a little oscillation in the elevator at times.
Hide Signatures
       Post #: 17
RE: airplane gyro updated - 9/30/2012 11:35 PM
verendrye
Score: 100
Status: offline
Thanks, your info is helpful.
Hide Signatures
       Post #: 18
RE: airplane gyro updated - 9/30/2012 11:45 PM
DougV
Score: 110
Status: online
quote:
ORIGINAL: mvarzoni
Hello folks!
Thanks!
M.
Here is another gyro: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCNFS&P=ML
Doug.
Hide Signatures
       Post #: 19
RE: airplane gyro updated - 10/1/2012 2:45 PM
dirtybird
Score: 173
Status: offline
The Hobbyking unit came available but before I could get the order finalized (Its unbelievable the hoops you have to jump thru to pay for something on a credit card on an international order) the units were on back order again.
Hide Signatures
(in reply to DougV)
       Post #: 20
RE: airplane gyro updated - 10/2/2012 3:22 PM
dirtybird
Score: 173
Status: offline
There is no information given on the tower unit. There appears to be no way to turn it on or off during flight.
Hide Signatures
       Post #: 21
RE: airplane gyro updated - 10/2/2012 6:10 PM
dirtybird
Score: 173
Status: offline
I lost my test airplane today. The gyro had apparently shifted on its mount and I did not have enough control authority to get it straight.
lesson learned: Don't mount the gyro on velcro. Tie it down good.
Hide Signatures
       Post #: 22
RE: airplane gyro updated - 10/2/2012 6:36 PM
sat2002ca
Score: 100
Last Login: 3/27/2013
Status: offline
Try Futaba GYA350
GYA351
GYA352 any of these work !
Hide Signatures
       Post #: 23
RE: airplane gyro updated - 10/3/2012 4:47 AM
dirtybird
Score: 173
Status: offline
The only Futaba three axis gyro I find on the tower hobbies inventory is not available until some time this month. They have no information on it . They refer you to the Futaba web site. A search of the Futaba site does not locate any information.
It appears to be like the Hobbyking unit at three times the price.
Hide Signatures
(in reply to sat2002ca)
       Post #: 24
RE: airplane gyro updated - 10/3/2012 3:47 PM
BarracudaHockey
Score: 280
Status: offline
quote:
ORIGINAL: dirtybird
hehe ya, don't tie it down though.
Two layers of 3m Outdoor mounting tape (gray tape, red backing). You dont want anything transmitting airframe vibration directly to the gyro sensor. You don't want it coming loose either
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
