CHURCHILL BRIDGELAYER    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> CHURCHILL BRIDGELAYER
Page: [1] 2   next >   >>
Login
CHURCHILL BRIDGELAYER - 9/5/2012 9:40 PM
flamme
Score: 110
Last Login: 5/25/2013
Status: offline
I need your help. I'm trying to realize a churchill bridgelayer...but i've got a problem. When I make the kinematic of the system, i found that the bridge system works in two parts. To make the elevation I need to pull since the bridge is straight and to push to put it down. Hope you understand. I try to put photo to explain it
Hide Signatures
       Post #: 1
RE: CHURCHILL BRIDGELAYER - 9/5/2012 9:49 PM
yellowshaker
Score: 183
Status: offline
Someone on the rc tank regiment built a working model some time ago...I think it was Septon. perhaps search there for some info on how hhe made it?
_____________________________
Armorcreations.weebly.com
Hide Signatures
(in reply to flamme)
       Post #: 2
RE: CHURCHILL BRIDGELAYER - 9/6/2012 7:43 AM
CCC2012
Score: 100
Last Login: 4/9/2013
Status: offline
VERY NICE.....
TAMIYA LEOPARD 2A6~WIP
Hide Signatures
(in reply to yellowshaker)
       Post #: 3
RE: CHURCHILL BRIDGELAYER - 9/6/2012 9:09 AM
Elefant
Score: 100
Status: offline
Hi,
I spoke with my friend Flamme on the phone and we came to the conclusion that we do not have all the elements to well understand the cinematic of this system.
First, the piston course does not seem long enough to extend the bridge from the stored position to the laid down position. This point taken into account, it seems obvious the deployment of the bridge is done in two steps :
- the bridge arm, in stored position on the tank, is PULLED by the piston rod until the the vertical position (90° angle). Then the rotating pivot that allowed this movement is unblocked to let the bridge arm go to the laid down position (180° angle), the rotating pivot being now the wheels axle. For this last step, the wheel structure must be temporary attached to the front of the tank and this time, the piston PUSHES the bridge arm.
What do you think of this theory based only on the study of the resin model seen above...?
Hide Signatures
(in reply to CCC2012)
       Post #: 4
RE: CHURCHILL BRIDGELAYER - 9/6/2012 12:24 PM
borealis
Score: 103
Last Login: 5/20/2013
Status: offline
I think your deduction is correct: pull until the wheels touch the ground (better, until the triangular support structure touches the front hull), then stop, unlock the pins and then it's just a matter of controlled release, since the bridge weight will lower the arm itself.
Since the bridge is hinged at its center of gravity, it will stay horizontal during deployment.
A well studied cinematic.
About the piston: the real piston is just the first segment from the cylinder. It pushes the central sliding link along the rail. The second segment is a fixed-lenght pushrod hinged at both ends (one in the central sliding link, the other is between the locking pins), not the piston itself.
edit: an image to better explain the above text
Hide Signatures
       Post #: 5
RE: CHURCHILL BRIDGELAYER - 9/6/2012 1:53 PM
mustclime
Score: 106
Last Login: 5/24/2013
Status: offline
here is the churchill biuld.....he built the front mount one....
http://www.rctankregiment.com/rctankforum/viewtopic.php?f=34&t=540
That which does not destroy me just makes me more irritable
Hide Signatures
(in reply to borealis)
       Post #: 6
RE: CHURCHILL BRIDGELAYER - 9/6/2012 2:08 PM
borealis
Score: 103
Status: offline
That is much simpler than Flamme's one, and definitely less interesting.
Hide Signatures
(in reply to mustclime)
       Post #: 7
RE: CHURCHILL BRIDGELAYER - 9/6/2012 3:43 PM
Rex Ross
Score: 237
Status: offline
I think the bridgelayer that Septon is building is very interesting. It is a different design from the one that flamme is working on, and each has it's own special operational problems to be solved, IMHO. In either case, I applaud both projects. They both require skill levels I wish I had.
Rex
R/C T34-76 T34-85 KV-1 T17E1/E2/E3 Bren M26 M41 LVTA-1 Hetzer Greyhound M5A1/M8 Jeep Dingo DUKW SdKfz7 Shermans Panther M3A1
Hide Signatures
       Post #: 8
RE: CHURCHILL BRIDGELAYER - 9/6/2012 5:38 PM
flamme
Score: 110
Status: offline
Thank for your help.
So The piston rod push the main arm it stays at the center of gravity...then at the locking pin (natural movement or humain action?) the reverse side of the piston for the second side of deployement?
The locking pin works just at the finish of the movement of the triangulare stucture or it's locked by an mechanical action(or human?)
thank you
Hide Signatures
(in reply to Rex Ross)
       Post #: 9
RE: CHURCHILL BRIDGELAYER - 9/6/2012 7:25 PM
flamme
Score: 110
Status: offline
If someone got the triangulare dimensions? etc....
Hide Signatures
       Post #: 10
RE: CHURCHILL BRIDGELAYER - 9/7/2012 7:17 AM
borealis
Score: 103
Status: offline
Sorry I don't have any dimension.
The pins would be both hydraulically operated (for easier operation) and manual (in case of hydraulic failure etc.). I dont' think they were automatic, too much dangerous in case of mis-disapplication.
Difficult to replicate on a model, though. Maybe mini-electromagnet as pins....
Hide Signatures
       Post #: 11
RE: CHURCHILL BRIDGELAYER - 9/7/2012 4:56 PM
flamme
Score: 110
Status: offline
I finally understand where it was locked.
Hide Signatures
       Post #: 12
RE: CHURCHILL BRIDGELAYER - 9/8/2012 6:33 PM
flamme
Score: 110
Status: offline
My work
Hide Signatures
       Post #: 13
RE: CHURCHILL BRIDGELAYER - 9/10/2012 9:17 PM
flamme
Score: 110
Status: offline
Fist run
http://www.youtube.com/v/6wR_L6jQVHw
Hide Signatures
       Post #: 14
RE: CHURCHILL BRIDGELAYER - 9/10/2012 9:25 PM
Elefant
Score: 100
Status: offline
Incredible !!
How did you achieve the transition between the two different pivots ?
Hide Signatures
       Post #: 15
RE: CHURCHILL BRIDGELAYER - 9/10/2012 9:29 PM
mustclime
Score: 106
Status: offline
WOW, that is nice.
Hide Signatures
       Post #: 16
RE: CHURCHILL BRIDGELAYER - 9/10/2012 9:56 PM
heavyaslead
Score: 100
Last Login: 5/13/2013
Status: offline
You could disguise the hydraulic as a motor worm gear system for both elevation and laydown.
Cheers
Eric Scott
Hide Signatures
       Post #: 17
RE: CHURCHILL BRIDGELAYER - 9/10/2012 10:02 PM
flamme
Score: 110
Status: offline
For the moment, with one gear motor I can make the two parts. I'm going to work on the system to lock the triangulaire pivot with one servo
Hide Signatures
(in reply to heavyaslead)
       Post #: 18
RE: CHURCHILL BRIDGELAYER - 9/11/2012 12:26 PM
flamme
Score: 110
Status: offline
Second test with the bridge(not finish) to look if it was able to run.
http://www.youtube.com/watch?feature=player_embedded&v=u8BMkr3BSwc
Hide Signatures
       Post #: 19
RE: CHURCHILL BRIDGELAYER - 9/11/2012 1:41 PM
borealis
Score: 103
Status: offline
Where is my jaw?
Hide Signatures
       Post #: 20
RE: CHURCHILL BRIDGELAYER - 9/11/2012 3:03 PM
Rex Ross
Score: 237
Status: offline
OMG!
Hide Signatures
       Post #: 21
RE: CHURCHILL BRIDGELAYER - 9/11/2012 4:18 PM
yellowshaker
Score: 183
Status: offline
WOW!!!!!!!!!!!!!!!
Hide Signatures
       Post #: 22
RE: CHURCHILL BRIDGELAYER - 9/11/2012 5:26 PM
karel47
Score: 149
Status: offline
nice work of art man, it works just fine ... am curieus how it would end up
PanzVI-J,ShermanM4A4,PershingM26,KTPorsche2x,KTHenshel Late3x-Early1x,TigerI 3x,JP,Panther,Jagdtiger;PantherIIta;PanthHL;Stu
Hide Signatures
       Post #: 23
RE: CHURCHILL BRIDGELAYER - 9/11/2012 8:19 PM
Buckeye36
Score: 110
Status: online
Incredible!
Tam Tiger 1, Tam Sherman M4(105), Tam Jagdpanther G1 under construction
ElMod Jagdpanther G2, ElMod KV-1E, ElMod StuG 4
Hide Signatures
(in reply to karel47)
       Post #: 24
RE: CHURCHILL BRIDGELAYER - 9/11/2012 10:19 PM
flamme
Score: 110
Status: offline
An other test
http://www.youtube.com/watch?v=NsX1AtO8dKs&feature=youtu.be
Hide Signatures
(in reply to Buckeye36)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
