Story of Two StuG's    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> Story of Two StuG's
Page: [1] 2 3   next >   >>
Login
Story of Two StuG's - 9/6/2012 5:37 PM
MAUS45
Score: 100
Last Login: 5/25/2013
Status: offline
Hi All,
I have been working, slowly maybe Snell speed, on two HL StuG III G's. One is a conversion from a HL Panzer III L/M while the other is an HL StuG III G tear down rebuild as a Late StuG III G. So here we go, photos on the progress I have. I have been working on the Saukof Mantlet for the Late StuG most recently. I used a Bandai StuG IV as a guide to scratch this one for the StuG III. I have textured the engine deck and lower hull on the Early StuG based on the Panzer III M hull. Also added weld beads to the engine deck. Removed the smoke/self defense grenade launchers from the front of the Late StuG III upper hull and filled the space/recess that was left as well. I have added the track tension upgrade to the StuG III based on the M hull as well. I have tried a product that you can get from Michael's to age/rust the exhaust/mufflers. Looks really cool. let me know what you think. Hope to do more to both StuG's this weekend!!!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
3 Tamiya''s Tiger I, Tiger II, Panther G, 3 HL Stug III G, 1 HL Panzer III M, 1 Jagdpanzer IV L/70, 1 1/8 Tiger II
Hide Signatures
       Post #: 1
RE: Story of Two StuG's - 9/6/2012 5:42 PM
MAUS45
Score: 100
Status: offline
More Photos...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to MAUS45)
       Post #: 2
RE: Story of Two StuG's - 9/6/2012 5:44 PM
MAUS45
Score: 100
Status: offline
Exhaust/Muffler stuff......
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3
RE: Story of Two StuG's - 9/6/2012 5:49 PM
MAUS45
Score: 100
Status: offline
A few more views of the Saukof....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by MAUS45 -- 9/6/2012 6:12 PM >
Hide Signatures
       Post #: 4
RE: Story of Two StuG's - 9/6/2012 7:21 PM
Rebellion13
Score: 120
Last Login: 5/24/2013
Status: offline
Looking good. I have used that product also, uses an actual metal in the gray solution then you add the other solution to rust the metal flakes. I like how you can vary the effects by adding more or less. Also you really need to do that in a very well ventilated area, that is some nasty smelling stuff, which you already know. I read on the product it can cause kidney damage, if you inhale too much. But the results are nice.
Cheers
Wade
N.E.A.D Member
All my tanks are in the project stage
Hide Signatures
       Post #: 5
RE: Story of Two StuG's - 9/6/2012 7:37 PM
MAUS45
Score: 100
Status: offline
Yes, it stinks, but I like how it looks. I had a fan running to exhaust the fumes away from me and out the window, so I should still be able to filter water. I was able to get the look I wanted by adding more of the rust solution in spots and layers. It gives a more dark brown rust or yellow/orange rust look by adding either more or less to get the look you want. Also do not need to add baking soda or sand to achieve the rough rusty surface. The metal partials in the paint do that for you.
Hide Signatures
(in reply to Rebellion13)
       Post #: 6
RE: Story of Two StuG's - 9/10/2012 6:11 PM
MAUS45
Score: 100
Status: offline
Worked on the lower hull add on armor for the StuG III G /M hull. tried to add photos, but have not been able to get them to upload. I will try again later today when I get off of work. Basically I used scale thickness plastic card stock and cut it to size. Next i textured it to give it a rolled steel look.
Hide Signatures
       Post #: 7
RE: Story of Two StuG's - 9/11/2012 6:01 PM
MAUS45
Score: 100
Status: offline
Here are the photos for the Add on armor for the front of the upper and lower hull of the StuG III G /M hull.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: Story of Two StuG's - 9/11/2012 9:02 PM
ausf
Score: 105
Status: online
Outstanding texture on the rolled armor plates as well as the cast of the pig's head. I really like where you are going with this. I have the Panzertracts on these as well as some other StuG books if you need any info, just ask.
Another rust option if the solution is too much is putting some 0000 steel wool in a jar with some water and letting it rust. After a week or so, you'll have all the rust you need.
Looking forward to more progress.
What, me worry?
Hide Signatures
       Post #: 9
RE: Story of Two StuG's - 9/11/2012 9:10 PM
mustclime
Score: 106
Status: offline
quote:
ORIGINAL: MAUS45
I like the texture, how did you get it?
That which does not destroy me just makes me more irritable
Hide Signatures
       Post #: 10
RE: Story of Two StuG's - 9/11/2012 10:48 PM
MAUS45
Score: 100
Status: offline
Thanks for you kind words ausf!!! I've got two going on the work bench. The pig's head is going to be used for my late StuG III G. It's going to be based on an actual vehicle that saw combat. The white you see shining through on the pig's head is Milliput. I used a dark brown rust color to prime it just to be sure the texture looked right. I will have to try the still wool method. I will pm you about your book reference material. Thanks again, ausf.
mustclime, I did the texture on the pig's head with a small ball scribe/cutter bit in a variable speed Dremel tool. By changing speed and bouncing it all over the surface I was able to get the look I wanted.
I was able to get the rolled armor plate look by using a medium stiff tooth brush and liquid cement. I brushed the cement onto the surface of the plastic card and then used the tooth brush by pressing it into the surface. It has taken a lot of trial and error to get that technique right. That said once you get it down it can be replicated with ease. It is just a matter of timing, i.e., when has the liquid cement melted the surface of the plastic enough for one to attack the surface with the tooth brush? Once you get the feel for that it is easy.
I will try to get more done so I can at least prime some parts to show the texture even better.
Hide Signatures
(in reply to ausf)
       Post #: 11
RE: Story of Two StuG's - 9/12/2012 11:16 AM
tthompso
Score: 100
Last Login: 3/11/2013
Status: offline
 Looking great, I'm really enjoying this build and learning some new techniques in the process. What kind of glue are you using for the toothbrush texturing? I'd like to know more about that techmique, it looks very good.  Ausf thanks for the steel wool idea, that is a good one that I will definitely put to use.
Hide Signatures
       Post #: 12
RE: Story of Two StuG's - 9/12/2012 1:52 PM
YHR
Score: 204
Status: offline
Thanks for posting. You have supplied a couple of new techniques that I will be sure to use.
Dan
Battle Armor R C
Hide Signatures
(in reply to tthompso)
       Post #: 13
RE: Story of Two StuG's - 9/12/2012 4:24 PM
MAUS45
Score: 100
Status: offline
tthompso and YHR thanks for your interest. I use Testors liquid cement and have tried Tamiya's liquid cement as well. These both work on polystyrene which is what most models are made of. If you want to use this method on the HL tanks I use Plastruct's liquid cement, because HL uses an abs plastic and Plastruct works better.
Hide Signatures
       Post #: 14
RE: Story of Two StuG's - 9/12/2012 10:04 PM
tthompso
Score: 100
Status: offline
 Thanks for the info Maus45. Hoping to do some work on my HL Tiger1 & II when winter sets in. Still trying to get them mechanically like I want them to be now. Over the winter I hope to break out the dremel & airbrush to get a more authentic look. Keep the pics coming, your Stugs are going to look great.
Hide Signatures
       Post #: 15
RE: Story of Two StuG's - 9/19/2012 5:35 PM
MAUS45
Score: 100
Status: offline
Have closed off the switch and screw holes on the side of the lower hull. Also completed the texture work on the lower hull I had started some months ago. Will post photos tonight. Camera needed charging.
Hide Signatures
       Post #: 16
RE: Story of Two StuG's - 9/19/2012 11:00 PM
WLY22
Score: 161
Last Login: 4/3/2013
Status: offline
looking good. I'.m building the STUG 42 and Pz IV together . I made  again the front lamp for my STUG  yesterday.
Hide Signatures
       Post #: 17
RE: Story of Two StuG's - 9/20/2012 3:46 PM
MAUS45
Score: 100
Status: offline
I would like to see your NoTek light for the StuG42. Here are the photos of my progress on the StuG III G based on the M chassis...
I cut the battery box out of the lower hull and re-installed the gear boxes. I will replace the plastic stock TU's with 3:1 metal when I get the chance.
Plugged the switch holes on the left side of the lower hull and the the bottom as well. Also closed and filled in the gaps on the battery box cover.
Replaced the chain on the tow hook with a more scale chain and made it so it could be removed. Need to make the clips that hold the pintel in place.
Added weld detail to the fighting compartment of the upper hull and textured the armor plate.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to WLY22)
       Post #: 18
RE: Story of Two StuG's - 9/20/2012 5:28 PM
DaveBcool
Score: 105
Status: offline
Looks great.
What are you using for the welds?
Hide Signatures
       Post #: 19
RE: Story of Two StuG's - 9/20/2012 10:27 PM
MAUS45
Score: 100
Status: offline
EverGreen quarter round plastic rod. Here is a hobby shop that carries it. http://www.dhcinc.com/evergreen.htm
Click to see the file in new window.Attachment.pdf Click to see fullsize image.
Click for fullsize
< Message edited by MAUS45 -- 9/21/2012 12:20 AM >
Hide Signatures
(in reply to DaveBcool)
       Post #: 20
RE: Story of Two StuG's - 9/22/2012 12:32 AM
WLY22
Score: 161
Status: offline
A great and nice job! I will upload the light pictures.
Hide Signatures
       Post #: 21
RE: Story of Two StuG's - 9/22/2012 2:58 AM
MAUS45
Score: 100
Status: offline
Thanks, can not wait to see them.
Hide Signatures
(in reply to WLY22)
       Post #: 22
RE: Story of Two StuG's - 9/23/2012 8:44 PM
MAUS45
Score: 100
Status: offline
Did some work on the tracks today. Used a product called "Blacken It" to soak the tracks in. These photos show the result. The process gives the tracks a more realistic look. The tracks are from Impact.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 23
RE: Story of Two StuG's - 9/23/2012 9:56 PM
1sgt
Score: 118
Last Login: 5/21/2013
Status: offline
Maus,
The tracks look good. I wonder if the color will wear off on the high areas. I had a pair of metal colored PZ IV tracks that I soaked in vinegar for about an hour each. Scrubed them down and colored them with gun bluing ( don't know why they call it bluing when it;s really a black color ) Came out great with the recessed areas black and the higher areas still showing a bit of tarnished ( vinegar effect ) metal. I had a thread on here somewhere, but using the search here gives more headaches then help.
Looking forward to the completed STUG.
Jim
Hide Signatures
       Post #: 24
RE: Story of Two StuG's - 9/24/2012 6:07 AM
MAUS45
Score: 100
Status: offline
Thanks Jim, I only used the Blacken It. Does the Vinegar do something to the metal to change the color as well? I will try that on my next set. I will have to see what kind of wear happens when I get one of these StuGs running.
Hide Signatures
(in reply to 1sgt)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.031RCU1
