Getting gears to mesh straight    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> Getting gears to mesh straight
Page: [1]
Login
Getting gears to mesh straight - 9/6/2012 8:19 PM
Mysterious
Score: 101
Last Login: 2/25/2013
Status: offline
My friends kid ruined the gear on the motor and the one it meshes with on my Savage Flux....I changhed both but I'm having trouble getting the motor lined up straight with the brackets and screwed down... it keeps ending up a tad turned because when I rotate the gears without the set screw tightened it gets pushed down the length of the shaft after some rotations. I don't want to tighten it down crooked cause that'll wear the gearings down. Is there a triclk to getting the motor and brackets square?
_____________________________
XR10, TC6, CRC Gen-Xi, Losi Ten-T(e) & 8ight-T(e) v2.0, HPI Savage Flux, Esky Belt CP, Lama V4, 40" E-Yak-54 & 40" Edge 540
Hide Signatures
       Post #: 1
RE: Getting gears to mesh straight - 9/7/2012 2:55 AM
Mysterious
Score: 101
Status: offline
no suggestions?
Hide Signatures
(in reply to Mysterious)
       Post #: 2
RE: Getting gears to mesh straight - 9/7/2012 3:09 AM
SLAYERDUDE
Score: 414
Last Login: 1/9/2013
Status: offline
Read it twice, sorry I run nitro.
Did the kid crash it and bend anything?
How did the "kid ruined the gear on the motor and the one it meshes with on my Savage Flux." happen?
This don't happen from just driving it unless it wasn't set right in the first place, I would imagine...
Hide Signatures
       Post #: 3
RE: Getting gears to mesh straight - 9/7/2012 2:00 PM
Mysterious
Score: 101
Status: offline
going reverse and punched throttle, tore up the teeth on the 2 gears
Hide Signatures
(in reply to SLAYERDUDE)
       Post #: 4
RE: Getting gears to mesh straight - 9/7/2012 6:18 PM
The Mad Modder
Score: 341
Last Login: 5/22/2013
Status: offline
I don't think I understand the situation. When you tighten the pinion(the gear on the motor), it looks crooked comparing it to the motor plate?
God bless America
Hide Signatures
       Post #: 5
RE: Getting gears to mesh straight - 9/7/2012 9:13 PM
llkoolskillet
Score: 100
Status: offline
Sounds like somethings bent or cracked. Pull the motor and check the motor plate, it could be cracked causing the mill alignment. Same thing with bent TVPs.
ERCM Picco/ Endbleed power should be the only combo allowed in a Savage.
Hide Signatures
(in reply to The Mad Modder)
       Post #: 6
RE: Getting gears to mesh straight - 9/7/2012 10:38 PM
BKoz559
Score: 164
Status: offline
I'm having difficulty understanding the question also.  The way I interpret it is that he's referring to the hex-head screws that hold the motor clamps to the chassis plate.  If you crank them down in the same spot over and over then they can create small indentations in the plate.  So, when you need to shift the motor the screw tend to work their way back into the old position which can make aligning the motor and setting mesh more difficult than it needs to be.
RDD Raceway Hobby Shop / Madera, CA
Slot Cars - RC - Models - Toys
Hide Signatures
(in reply to llkoolskillet)
       Post #: 7
RE: Getting gears to mesh straight - 9/8/2012 4:52 AM
Mysterious
Score: 101
Status: offline
quote:
ORIGINAL: BKoz559
More of less yes... I'm trying to re-tighten the motor in place and the pinion just seems to be at the slightest angle to the other gear it meshes with... can't seem to square it away perfectly...worried it'll wear those 2 gears over time.......don't think anything is bent, both gears are brand new.... just have trouble lining everything square and screwing it down as so
Hide Signatures
(in reply to BKoz559)
       Post #: 8
RE: Getting gears to mesh straight - 9/8/2012 6:42 AM
The_Shark
Score: 494
Last Login: 5/6/2013
Status: offline
best thing to do is just get the motor mount JUST snug and then twist the motor so its alligned and meshed, and then tighten it down.
very common issue that t-maxxes have, there is just a bit of side to side play so you have to finagle it to get it right.
a little bit of a angle wont hurt, just make sure the mesh is right with just a TINY bit of play.
Signature
(Max. 125 chars. 2 lines max)
Hide Signatures
       Post #: 9
RE: Getting gears to mesh straight - 9/10/2012 3:01 AM
SLAYERDUDE
Score: 414
Status: offline
quote:
ORIGINAL: Mysterious
quote:
ORIGINAL: BKoz559
Take a piece of emery cloth and sand it smooth again so the indents from the old mounting spots are gone, install washers so the bolt heads don't sink back to the same spot.
When I tighten engine mounts, I snug them in place and get perfect gear mesh, fully tighten, recheck the mesh, then remove one at a time and loctite.
Let dry overnight.
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.358RCU1
